Tranlate - remote virtual artifact(test dir)
Re: Tranlate - remote virtual artifact(test
Post by bofara » Fri Nov 08, 2013 12:55
Today I have /still early in the night/ started with glitches - OHM open 50/50. i.e. once open, it is not /says that the site is temporarily unavailable/. Internet connection sometimes gives a window that 'need to pay Internet dostawczych', and after a few minutes - it is normal /I am using a completely free Internet / wifi/. The phone is not working, completely dead, changed for the old, it still works. However phone glitches started yesterday posleobeda. While the touchscreen on the e-book that use fine. :)
Also charged with reusable batteries /rechargeable/ as expected by the instructions - no charge to him..
PS by the way processing and paleorrota of Butugychag turned out to be significantly energozatratam for me, still there is a partially directed my content. Much happened /had the throat for a few days, caught a cold, although the weather is not conducive to the disease, the likely cause of me/ and the stream is felt as a kind of centre inside of me /Anahata - Anahata and why, it can be a personal perception, no one wrote like/ of which are double-sided energoinformative connection.. It's like the mirror - through the Anahata external relations is reflected in the body and Vice versa. About building those relationships /it's like Voznesenie new nerves or blood vessels after a load is prevailing in the dream - today just slept over 12 hours.. there's a LOT for me.
I understand - explanation: gluing twigs + energozatratno = the above pieces..
Post by bofara » Sat Nov 09, 2013 2:54
Complementing glitches: it turns out that at work for a few hours stopped all banking transactions with all sorts of Bank cards and machines, it was possible to pay only in cash - cash.. :?
димыч
Has thanked: 7 times
Been thanked: 16 times
Post by димыч » Sat Nov 09, 2013 4:11
for me, the sleepiness attacked last time, Spry all-night sitting
on situations all more or less works well, while the uncertainty after the new year, but
wait and see.
the dreams are frightening and realistic, don't try to pull away like that.
At the same time realized how the volume of work remains to be done to significantly change the body and spirit, figuratively speaking.
so some depressed rolled. Freebies and magic wands, there is only pinks and job. :)
Петрос
Has thanked: 45 times
Been thanked: 9 times
Post by Петрос » Sun Nov 10, 2013 13:48
A strange night, half-asleep bright ideas come up and down while it's fresh. Michael, the modes are not changed?
Post by Михаил_ » Mon Nov 11, 2013 2:09
no, nothing has changed... well acre nature around them.
Post by bofara » Wed Nov 13, 2013 16:15
bofara wrote:chaos, as, for example, in the center of a tornado everything is fine and calm, and in the periphery - :wiz
UTB continues. I calmly and smoothly while. But the sort of chaos around could become something really decent, at least to see me out of the 'here and now'.
Post by Михаил_ » Wed Nov 13, 2013 16:21
so it should be - a sea of opportunities, which you can just "get it out of the sleeve" how does fakir... because there is no reasons why not - all the possibilities are.
Post by Михаил_ » Wed Nov 13, 2013 16:36
most fun - aspects of the broadcast order, give approximately the same capacity, strange as it sounds, although it is all a bit contrary.
Петрос
Post by Петрос » Wed Nov 13, 2013 16:51
So, why not "order" ? :)
Petr99
Has thanked: 3 times
Been thanked: 15 times
Post by Petr99 » Thu Nov 14, 2013 5:28
I also have a chaos around a very decent and quite far (even his wife), and inside the mind. Even though I have mode 6 is not broadcast. Maybe this mode has no relationship to the chaos around
Petr99
Post by Petr99 » Thu Nov 14, 2013 5:31
Михаил_ wrote:the most fun - aspects of the broadcast order, give approximately the same capacity, strange as it sounds, although it is all a bit contrary.
Changes go through the chaos inside, leaving the order around? And the danger is that not everyone will be able to cope with the chaos inside?
Визард
Post by Визард » Thu Nov 14, 2013 10:33
More chaos inside and you're in the cocoon from the chaos, but you don't touches, but BJ pulls out of this chaos is necessary for development and transformation, and you consciously can also navitelauto there any :)
Петрос
Post by Петрос » Thu Nov 14, 2013 19:00
Today, suddenly found myself in a dream. Unusually colored. I looked down at my hands, feet, and realized that it was a dream, there was some kind of children's mischief, ran all to consider... the Dream was short but impressive.
Petr99
Post by Petr99 » Fri Nov 15, 2013 5:53
Possibly the result of mode 6 will be broadcast (as is inevitable).
I think the chaos manageable. For example at the work place chaos outside and all around, gradually begins to revolve around me (people reaching out to me as a fulcrum - like solar system, it is better to rotate along the orbit than on the ellipsoid). Transfer the chaos inside and changing ourselves. You can change the place of work and with the chaos inside to adapt to a new place, then, having determined that I want to change in the environment, carry out the chaos and begin to change the world around them.
Post by bofara » Fri Nov 15, 2013 11:58
IMHO, the effects of the broadcast, will increase, if a person is doing physical exercise. I.e. the stream is sort of inside the cocoon, but the physical body - this is the material projection of this cocoon and if it help to develop harmoniously and then there will be more tangible /for most/ the effects of broadcast. Of course AI in the subject. :)
АКВО
Post by АКВО » Fri Nov 15, 2013 12:22
Petr99You some nonsense written, I do not understand...
And anyway, why is everyone so attached to the word 'chaos'? What does it mean?
MAG.no very aptly put about the mode 6:
"stream through the Chaos, different from the broadcast of Chaos", i.e. at the time of broadcast 6 mode (in my experience) is no Chaos in life is not introduced, and through existing (mnogokanalnosti) is "a certain (selected in the parameters) the likelihood"
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Fri Nov 15, 2013 12:59
Petr99 wrote:).
The analogy with a glass of Tea. Tea leaves randomly spin until you spoon will not spin . The centrifugal force drive them to the center, giving it (i.e. tea leaves) direction . Applied force and a specified vector is committed to organize a chaotic spinning of the tea leaves. Here it is important to set a goal.What happened. All rushed to the center,and inertia has long revolves in the center, even if the spoon is removed. A spoon can be considered a man who asked and spin and direction , and the point which tends to chaos. On your business , you are there spoon(the man) in the center and pull together the chaos on myself and ordered it inside situation, or you're outside and the chaos of inertia tends ordered. It is important that everything you need out of chaos gathered at one point you set and you need.Most importantly , to himself at Chaos to develop. Arranged in the order and stabilization. Not satisfied-again!.
To change jobs with the chaos inside ? Well,well. A reaction on your new colleagues? Zamorduyut you with your chaos. And vypirayut.Unless of course you have it as an end in itself , to undermine the already stagnant structure and create the space for yourself. It is already forcing the situation. Then to add chaos, rollback, and so on. You need to have a lot of strength to cope with this. I would not dare.
Post by bofara » Fri Nov 15, 2013 13:38
Petr99 wrote:I think the chaos manageable.
And You remember, please, as suchi showed Merlin /but after a long training/ primary, primordial chaos.. And that there happens, if the operator is 'not master'.
I then last week several times flashed thoughts on the edge of the Abyss /the Abyss/. :shock:
Post by Михаил_ » Fri Nov 15, 2013 17:48
ЛИЛИЯ-Р wrote: It is important that everything you need out of chaos gathered at one point you set and you need.Most importantly , to himself at Chaos to develop. Arranged in the order and stabilization. Not satisfied-again!.
really simply there is interaction with the broader parameters of the variables of resonances than without the parameter of chaos, not necessarily something out there in order and stabilization
[/quote]
your personal social fears, as well as any social fears are only part of the illusion and have nothing to do with the topic under discussion, except, perhaps, the classic example of "dread magician" (see fry)
and no more relationships....
Петрос
Post by Петрос » Sat Nov 16, 2013 13:43
I had noticed before that the disk A. Patrushev in the UK is somewhat different (I think talked about this somewhere on the forum). Now work through broadcast SK4. I like it.
арте:м
Been thanked: 8 times
Post by арте:м » Sat Nov 16, 2013 17:51
Petrosand it can be a little more in detail: how to throw playing a physical disk on the virtual SK? and is there a limit on the number of playbacks of the disk (as in the case of a player) or can rotate continuously when using SK? will there be a sense if to make a reproduction using SK sequentially or simultaneously Petrushevsky several discs at once?
Магистр
Post by Магистр » Sat Nov 16, 2013 19:31
Hello!
Stream goes and we have all become accustomed to it. A week ago, it was a little "tight". Condition left much to be desired. I attribute it to the fact that I added a few sheets of FRM. Wore long, almost a day. Just forgot they were on me. In the broadcast FRM there. Took off and everyone quickly adjusted.
More noticed. I wrote that no BJ in addition to AMB and Panacea couldn't wear. Yesterday I tried to add 3.0 N. Well is on my hands. I guess I broadcast already used, or rather to stick, and now the addition of BJ etc. as not previously felt.
Thank you.
Петрос
Post by Петрос » Sat Nov 16, 2013 19:35
арте:м wrote:Petros, and it is possible slightly more in detail: how to throw playing a physical disk on the virtual SK?
The UK is not virtual, it's in another spot if it is broadcast, there is a connection "and do with it what you want"
арте:м wrote:and is there a limit on the number of playbacks of the disk (as in the case of a player) or can rotate continuously when using SK?
I think that there are no restrictions, if justified, and that in fact SK "refuse" nonsense :)
арте:м wrote:will sense if you arrange a reproduction using SK sequentially or simultaneously Petrushevsky several discs at once?
Didn't even think to indulge in. What is the purpose? you can set a goal to lose at some specific time or in some cases. For example, ultramesh
.Оксана.
Post by .Оксана. » Sat Nov 16, 2013 19:41
this episode for me was the most striking of all the Chronicles... goosebumps :) hooked hard, and now, when bofara recalled, remembered :)
well, from the first part where the storm went, erasing Shadows...
Post by bofara » Sun Nov 17, 2013 3:29
But to me this area is very interesting. I have some observations about playing at the same time similar things /no rims Andrei Vadimovich or trainings, K-13, and very specific things/ and I can say that there I've got an interesting specifics - about:
- you can set each track /or track because I work with different variants of a particular character from 'six Sacco';
if you don't specify nothing, and leave /ie. to listen, to perceive, etc./ as-is, without any mental attitudes - then there is a long work of consciousness, i.e., while the mind 'digest' this information /and not only/ actually is quite a long time, in comparison if you listen to only accept one track.
We must remember that SK I does not have, and these tracks I'm listening through headphones to a computer.
.Оксана. wrote:hooked much
Yesterday I was going to write what my impression perception in connection with 'the pattern' /ie I see the current movement of energoinformative in man in connection with the broadcast, which Dvorkin 'seen' at Oberon. But while decided to give up, because just like I write here are 'bugs', it, things. :)
