СК1М
Владмосква
- Has thanked: 1 time
- Been thanked: 7 times
Michael_, a couple of questions for СК1М:
1) How to be located СК1М and Stabilizer from each other by distance?
a) as close As possible;
b) as far As possible;
C) doesn't matter.
2) What is the maximum size of paper with the goals/objectives for СК1М?
a) No more dark small circle;
b) nothing more than a big Golden bagel;
C) Not more than the upper square edge of the device.
C) doesn't matter.
Re: СК1М
1. it does not matter. But still better to post a meter or two (the stabilizer may be a little fonit their sector), but only slightly (i.e., you can push the IC in an accident, stabilizer SIGNIFICANTLY stronger than SK).
2. can be folded several times. So that doesn't matter.
Re: СК1М
1.Vlad is not a homemade stabilizer.
2. no, not right. A weak paper may be almost not noticeable. And can be extremely strong. Operator-dependent and manufacturing technology in the sum. Someone has improvised a multimeter size.
In this case, the answer involved two industrial appliances.
Re: СК1М
АКВО wrote:When writing goals for СК1М on a piece of paper... fall in light of ISS(slight positive intoxication appears) so - is this normal?
Normalno. I sometimes have the thought -the desire already formed ,I then take a clean sheet of paper and something to paint on it and even sometimes do not notice where the leaf and flomaster and how I did it.And then I realize that I'm holding the figure, and that it is urgently necessary to put. And it's all on autopilot.But time was on the subway in such a case. As I sit at work ,reading the forum ,but here in the subway read a book ,have an idea,I used them to crust the inside was written in pencil ,so I write down my thoughts,then to look to what is now matured, and as was previously thought. So at work I usually keep the table clean or not quite up sheets.Well something on the forum +what else ,then to see more. So here is amusing. The idea originated, and on the back of the crust and let kalyakat and people see the side glances,but did not attach importance to(of course after all ,the office is normal and can often be seen) But when drawing I was going to fold the sheet ,that is, a book to put on SKМаг.нет wrote:Normal (maybe the subconscious is activated), but do not have (individually).
Presented right? Like crazy or ...Yeah..So watch your detachment from the process.
Re: СК1М
It's called estimated dependency is to draw attention to the fact that others noticed
When it is not-they do not notice even if something is happening completely out of the ordinary. I gave an example - one of our friends the day he went to work in a torn shirt, pinned up on the pin (broke accidentally at some effect), no one noticed And we, too, as he later communication to us is not shown - and the gap was huge
Re: СК1М
In connection with the arrival(finally, thank mail our
) the most part of components for the Programmer (panacea), guided by the delivery of the first devices at the end of the month. By mid-December I think will have them the serial presence everywhere.
In this regard, December 15, the cost СК1М and RF consoles will increase in two times.
Владмосква
Re: СК1М
Stickers Panacea fully cope with cleaning the premises? Ie СК1М it is not necessary to use for cleansing of premises? СК1М now for only goals and objectives?
Stickers Panacea is not only clean, but also not allowed to be a new "dirt".
Re: СК1М
And how to disable myself СК1М?
Just as I understand СК1М is a constant booster of my mental energy,my ie any negative thought or desire,for example with anger can materialize automatically,and you can be so confused,then that does not understand che's happening to you.
Re: СК1М
1. СК1М is not an amplifier of any mental trash. On the one hand he is "proofreader". Ie removes the roughness while moving towards the goals. On the other - it takes a target either via a table or via audio, or mental, but it's got to be a team, not just thought about anything.
2. СК1м included in the total system of devices and in extreme cases (danger to the operator is real, and so on) can its potential to operate without direct command of an operator. But it's rare.
3. СК1м always configured for a single operator, it has a standard authorization module (used in all products). May be transferred temporarily to use another person, donated, given, sold etc. Then control will pass to another operator. Either temporarily or permanently.
4. You can configure the device not to accept mental commands without paper or other physical evidence.
So not see a problem. Hundreds of sold devices and one of such problems was not complaining.
м-р Фримэн
Re: СК1М
Still, something like that heard about BJ 2.5.... If that's true or not?Шломо wrote:Just as I understand СК1М is a constant booster of my mental energy,my ie any negative thought or desire,for example with anger can materialize automatically,and you can be so confused,then that does not understand che's happening to you.
Владмосква
Re: СК1М
The goal is set СК1М realized. However it happened, by the fact that I broke my elbow very seriously (offset, broken, surgery, hospital). But this goal helped.
To all: don'T FORGET to add "type in a safe manner...", and then I have to target any security or favorability was not
Goal I adjusted.
Gained experience. Well, that's the price but purchased. No complaints - the fool, about the conditions and safety and then written.
Goal I adjusted.
м-р Фримэн
Re: СК1М
Yes it has been a year with little wear...Шломо wrote:individually,try it and see.
There is a feeling that before the end of this version did not understand, originally wanted a 2.6 kernel, but on the advice of Michael took 2.5, so this time I would like to find out for myself, to correctly interpret what is happening...
Re: СК1М
The bracelets are very different from СК1м because they are (starting from 1.0) respond more quickly to user requests. The subconscious mind responds more precisely. The bridge of consciousness-the subconscious is improved, and the capacity of performance goals.
Ie the difference is. СК1м, still stands apart from the operator, and the bracelet is not a separate object, but only setting the state of the operator.
2.5 not fundamentally different from other versions, but the actual settings 2.5. Just his own feature - find new ways, probabilities and create them where as if this is not possible. In the playful hands that can undoubtedly create some chaos, but it is well to search for new solutions, ways of creativity. And yet he is the most soft effects of the series of senior 2.x. IMHO.
Impact 2.5 in shot form very much less than in dressed, although some communication with the operator of the BZ from 1.0 if it is not turned off deliberately.
I don't remember why recommended 2.5, apparently so was the situation described is that it came 2.5
Sometimes, if a person gets a bracelet of that quality which it is less developed for a long time he could not begin to fully control, but it's worth of development (manifestations of different facets of yourself).
Vlad, it's not just the wording. Though perhaps the wording on the safety and would help. It's in the balance.
The thing is that sometimes the intrinsic value of our desire above other factors. It consciously otherwise we can judge. And inside can prioritize absolutely without evaluating side factors.
Further, if different there is only one (e.g. through injury) and the rest for one reason or another, rested in a dead-end path, it is possible that such a paradox. When we do estimate the cost of the desired literally seldiko "at any price" or so.
The wording on security is important and necessary, but in most cases the device is oriented in a favorable way, or hinders the implementation, looking for the rounds, albeit slower. Such a situation is often possible, when the operator pushes the device constantly constant complaints about "well, when I have been waiting for, this is important" and so on.
I.e. the assessment factor can bring down a security path, if it is literally not described.
In other cases (relative to the neutral according to the operator goals), it is difficult to obtain in the UK unsafe ways of implementation. The very essence of the device always generates the desire for trajectories where the injury rate (from all points of hrenia) less. Not only physical.
Otherwise what happens if we are exhibiting some strange priorities.<
м-р Фримэн
Re: СК1М
I hope it's not fatal?Михаил_ wrote:In the playful hands that can undoubtedly create some chaos
Re: СК1М
There is usually no
BJ save the fatality.
In General, from what "I thought, and it came to pass" people are not insured, and without any devices and this is the normal state of things, which will only increase in the whole world. So to escape from the UK and their thoughts is somehow a dead end.
Just need the results to assess more critically and not overload yourself with thoughts of what I was thinking and it came to pass, and to live.
Владмосква
Re: СК1М
I forgot to add that the Stabilizer on the same task worked (without wording on safety in the journal, alas). And the Stabilizer thing is more acute than the UK.the essence of the device always generates the desire for trajectories where the injury rate (from all points of view) less
Владмосква
Re: СК1М
not my case. My goal was a bit of a hold/delay a inevitable process, win some time.the operator is constantly pushing the instrument constant complaints about "well, when I have been waiting for, this is important"
not worth it because the time spent in the hospital is approximately equal to the winning time.well, I hope the goal was worth it
Along the way, there are still a few of the layers was:
- the injury itself could be the global sign because occurred in a very symbolic place for me;
- the injury itself gave a couple of lessons (or even more) likely useful in the future;
on the day of the injury mark on her was, but it is very weak;
- incentive to quickly get to the courses right brain drawing because sleeping so deeply subconscious and intuition is simply dangerous to live...
- theoretically it could protect me from something more dangerous, is more dangerous could happen if I stayed in the usual rhythm of life.
