In General Healing does not contain the hypnotic rhythms, but it will podoydet for the purpose of self-programming (as with any relaxation technique). Lying can be anything you like.Татьяна_Я wrote:Andrei Patrushev
Andrew, good day!
To heal you can set goals, as with Explorer? If Yes, to what extent - only the health, or in General? And need to lie down without moving? Just in the process of listening really want to put your hands on the sore spot. You can?
I finished a 21 day Guide and start Healing, I really like it. You can continue the same purpose, that was the Conductor?![]()
By the way,
a fly or bee (as Lily wrote) really buzzing about 38-39 minute, and is quite noticeable)))
CD "healing: the magic river"
Andrew, Hello! My friend listens to the CD "Healing." She complains that the 50 minutes she is on pins and needles, she has a constant desire to take off your headphones and stand up:) Why such a reaction? While health is clearly improved, headaches gone, which tormented her for years. And the second question - how often should I repeat this 21-day course?
Well, lying is necessary - let him dance, for example.Anonymous wrote:Andrey, Hello! My friend listens to the CD "Healing." She complains that the 50 minutes she is on pins and needles, she has a constant desire to take off your headphones and stand up:) Why such a reaction? While health is clearly improved, headaches gone, which tormented her for years. And the second question - how often should I repeat this 21-day course?
How often? - On demand (you can never repeat - this is the Healing, not the pill
Interestingly, while listening to Healing, and began to speak installation for reducing the amount of food consumed and the weight loss... weight change is small, but there really was less after the second listenАндрей Патрушев wrote:Татьяна_Я wrote:Andrei Patrushev
лин
Hello, Andrey! A month ago I listened to the first time Healing, the effect of this was covered in about twenty minutes, that Mama do not cry. In General terms - did you feel the acceleration as if the bed takes off, and a very strong sense of the rapid rotation soputstvuyuschie spills heat and cold. This is me then so impressed that nasoloda with emotions, my brain probably just chickened out(pardon the expression, but it seems that is what and heart so restorations). the next 4-5 auditions had brought absolutely no sensations on a physical level, the psychological balance of the day while listening to in the morning. I read somewhere that the brain can block the binaural effects of not "understanding". I asked you once about it in the branch conduit, but you never answered. I decided not to give up, delayed healing, and began to listen to the guide. in one of the sessions has set a goal to trust the contents of disks Patrushev. Yesterday morning finished the three week course conductor and was healing. after 15-20 minutes started
again, these accelerating, twisting, UPS and downs. in General, I was able to fly only to grasshoppers, then I realized that I'll just throw up in bed, took off the headphones and began eagerly to seize the water and air. I suspect that it is the vestibular apparatus can not withstand such "flights". What do you think, Andrew! Vryat I was in a past life Gagarin
Серж82
Will allow you to cut in?This is possible because the vestibular apparatus is located near the ear.Rarely,but some of my friends have very similar listening experience as Healing and sessions on relaxation on mind-machine,over time, these "phenomena" disappear,becoming with every listen less intense.
Most likely, it's in Your personal trance stories. As I wrote, people go into trance in the situations dangerous for life (or evaluated them as a threat to life). This Gestalt (all the sensations, feelings and images) is stored and activated on subsequent occurrences. If no back-up, then gradually the other feelings go away. Feeling tied to the vestibular apparatus, are usually very powerful...Серж82 wrote:hi Andrea! A month ago I listened to the first time Healing, the effect of this was covered in about twenty minutes, that Mama do not cry. In General terms - did you feel the acceleration as if the bed takes off, and a very strong sense of the rapid rotation soputstvuyuschie spills heat and cold. This is me then so impressed that nasoloda with emotions, my brain probably just chickened out(pardon the expression, but it seems that is what and heart so restorations). the next 4-5 auditions had brought absolutely no sensations on a physical level, the psychological balance of the day while listening to in the morning. I read somewhere that the brain can block the binaural effects of not "understanding". I asked you once about it in the branch conduit, but you never answered. I decided not to give up, delayed healing, and began to listen to the guide. in one of the sessions has set a goal to trust the contents of disks Patrushev. Yesterday morning finished the three week course conductor and was healing. after 15-20 minutes startedagain, these accelerating, twisting, UPS and downs. in General, I was able to fly only to grasshoppers, then I realized that I'll just throw up in bed, took off the headphones and began eagerly to seize the water and air. I suspect that it is the vestibular apparatus can not withstand such "flights". What do you think, Andrew! Vryat I was in a past life Gagarin
Andrew, thank you very much for the answer! Later listening really had a milder form, have virtually no unpleasant effects.
There is now something to think about, or rather reminisce. I have a question of a purely technical nature. The signal level to the strobe decoder on your drives, especially in the healing is quite low compared to "normal" disks, like the Northern lights, etc. On the machine there is no possibility to adjust the level of EXT and starts to blink when the volume level at which you hear the breath of the flies. Well, I have this thing corrected in audizine to fit your preferences to listen. just wanted to know what purpose you guided by choosing the level of the gate signal? And by signals. On the forum I found that you proposed schemes for switching LEDs. Specifically for healing what is optimal? The channel for each eye?
The level of audiostrobe - I picked up the standard.Серж82 wrote:Andrew, thank you very much for the answer! Later listening really had a milder form, have virtually no unpleasant effects.There is now something to think about, or rather reminisce. I have a question of a purely technical nature. The signal level to the strobe decoder on your drives, especially in the healing is quite low compared to "normal" disks, like the Northern lights, etc. On the machine there is no possibility to adjust the level of EXT and starts to blink when the volume level at which you hear the breath of the flies. Well, I have this thing corrected in audizine to fit your preferences to listen. just wanted to know what purpose you guided by choosing the level of the gate signal? And by signals. On the forum I found that you proposed schemes for switching LEDs. Specifically for healing what is optimal? The channel for each eye?
For switching LEDs I Your question is not understood.
Hello Andrew and thank you to all the forum!
For a long time I was not on the forum, got the rims on 26 April and started with discs of Endorphins in the morning, Healing in the evening before bed. It was like everything is fine, no reaction, but on 2 may started, I twisted so that Mama do not cry, back pain in the area of red-footed Falcon on the right side, neither to become nor to lie, it was not possible, a little extra movement right pain squeezed tears
3 days could not even stand up, barely, barely moved, when the movement really needed to follow their movements, never such I do not feel pain. Well thought it for a long time, the sixth went to work, but you should have seen my gait, in the second half of the day the pain gradually began to subside, and then completely gone, repeat the number 10 may and 11 may, and then everything disappeared as if it was not this pain. Today finish Healing, endorphins already auditioned, Thank you very much to Andrew for his work and a great desire to help others. Now turn the Massage of the Brain and Conductor, MM every day, and the Explorer once in three days so I understand.
I don't know how it's Kundalini, but I have a question for Andrew, what did that mean? Output some pain stagnant? Four years ago my brothers decided to take the cast-iron tub, but then I overdid it while lifting in the lower back that cracked
and some days not very nice had to go, and then all is forgotten.
Yeah, who knows - all of the wheels "fell"...Ансар wrote:I don't know how it's Kundalini, but I have a question for Andrew, what did that mean? Output some pain stagnant? Four years ago my brothers decided to take the cast-iron tub, but then I overdid it while lifting in the lower back that crackedand some days not very nice had to go, and then all is forgotten.
ЮрийА
CD "Healing.Down the Magic river"
Disc listening 2 weeks. The first time I fell asleep and woke up shivering throughout the body and had cramps plus fever in the feet , legs, then trailers a few days. Listen to all the time heat in the legs after listening to small tremors throughout the body. Information has become to learn much more and read a lot. What this may mean is that a normal condition?
Евгений2008
Yes, of course, possible.Евгений2008 wrote:Andrey, tell me, and you can listen to through the day alternating between the Conductor and the Healing? Ie day Explorer before bedtime, a day of Healing before sleep. Somewhere here in the forum I read that every day to listen to the Conductor too much, need a pause for two days.
Thank you!
