Discussion of InnerPulse sessions
Installation and discussion
Развивающийся
Post by Развивающийся » Tue Oct 16, 2007 15:05
Евгений Кош wrote:I mean to him in dreams he came?
Yes, that's a Caretaker. I think for the first time, he said to him in a dream came...and kept a conversation with him about freedom of choice.
Евгений Кош
Has thanked: 2 times
Been thanked: 2 times
Post by Евгений Кош » Tue Oct 16, 2007 21:53
Surprised..
And where.. in what book Zeland about the Caretaker can be read?
Развивающийся
Post by Развивающийся » Wed Oct 17, 2007 10:10
Евгений Кош wrote: Surprised..
It is at the beginning of the first book, in his dream came the Caretaker.
Евгений Кош
Post by Евгений Кош » Wed Oct 17, 2007 10:47
Thanks..
like the first I bought.. now I try to read..maybe something I find interesting for yourself.
Развивающийся
Post by Развивающийся » Thu Oct 18, 2007 12:11
Please, Eugene!
I looked...it's really, in the first book.
Александр_
Post by Александр_ » Sat Dec 15, 2007 23:08
Seeland done, just read slow.
Well impressions ?
Князевский
Post by Князевский » Fri Dec 28, 2007 23:34
Good day!
A question.
You need to write a session is not typical for MM. Needed glasses means with a frequency of 6 pulses per second, and 6 pulses per minute, like a garland. Perhaps do such a thing? Or the device itself will not pull.
Is it possible to audiostrobe drive? Specifying such an algorithm is flashing?
Post by Андрей Патрушев » Sat Dec 29, 2007 17:34
Князевский wrote:Good day!
A question.
And what prevents?
There is a possibility to adjust the brightness and volume...
Князевский
Post by Князевский » Sat Dec 29, 2007 18:50
And what hinders?
Little experience.
And maybe I wasn't clear enough - I need it to be not blinking in MHz and turns the diodes (on/off) :)
Post by Андрей Патрушев » Sat Dec 29, 2007 21:49
Князевский wrote: And what prevents?
Little experience.
And maybe I wasn't clear enough - I need it to be not blinking in MHz and turns the diodes (on/off) :)[/quote]
And do it in the editor, choose the segment length to the half life. Then in one segment brightness and volume at maximum, the second at zero. The frequency is also at maximum.
Князевский
Post by Князевский » Sat Dec 29, 2007 21:58
if Maxim frequency, it is 42 MHz, the idea is a solid shimmer and brain stimulated frequency is not?
I need it not stimulation frequency(this is important), and the response to on-off light.
I'm a pervert. :)
Post by Андрей Патрушев » Sat Dec 29, 2007 22:20
Князевский wrote:if Maxim frequency, it is 42 MHz, the idea is a solid shimmer and brain stimulated frequency is not?
I'm a pervert. :)
Frequency, which is able to follow the brain are in the range 8-25 Hz
Александр_
Post by Александр_ » Sat Dec 29, 2007 22:30
Андрей Патрушев wrote:Frequency, which is able to follow the brain are in the range 8-25 Hz
how, then light stimulation of the Delta ?
means for Delta glasses not suitable ?
Князевский
Post by Князевский » Sat Dec 29, 2007 23:42
Explain the essence of what I was talking about, and that I am pursuing.
Practiced walking with my eyes closed and I noticed such a thing – the sun was shining through some trees and through closed eyelids, I saw a very colorful spot that reminded me a variety of pictures. They were much more distinct, clear and zapominaniya than using MM.
It so got me that I almost nose was bloody, when I had to turn.
I thought it over and repeated in the car(car), got to the window, the blinds moved and when riding they swayed. Happened the same with pictures. I spotted how much hesitation there was in minute 37.
Here I have worked the idea on the MM session to do something like this, but MHz the way, already tried. If not for the flickering during turn on of the diodes, it would have worked. Now I want a garland to use.
If anyone think about it – you need to do is flash the light, and as if the main lighting, but during the pulse the power increase. As the camera flash when using day.
Pavel
Post by Pavel » Sun Dec 30, 2007 0:15
Knyazevsky, I feel my new self-made points with six diodes.
At the moment, those images that appear when these glasses, very much like your description of the desired result. You can also make yourself like that?!
By the way, I also noticed that if you just lie back on a Sunny day with your eyes closed on a firm surface and slightly tilting the head sideways, then over time through the sun spots are amazing and beautiful paintings and nature landscapes.
The closest to this vision I have it till my new self-made glasses. Probably because of the location of the diodes.
Князевский
Post by Князевский » Sun Dec 30, 2007 0:24
Thanks, I'll try anything
Post by Андрей Патрушев » Sun Dec 30, 2007 11:12
I'm a pervert. :)
I just have a sneaking suspicion that You Christmas garland from mindmachine going to run... :)
Post by Андрей Патрушев » Sun Dec 30, 2007 11:15
You can also connect the Z-rhythms (super slow), it can be like a dream nice to encourage, but the Delta is in principle nothing is synchronized...
Post by Андрей Патрушев » Sun Dec 30, 2007 11:20
Князевский wrote:Explain the gist of what I was talking about, and that I am pursuing.
Congratulations! You again (15 years later) discovered a technique EMDR (EMDR - in Russian) after the American Shapiro. This method incorporated into the design of my 12-and diode points and the program rainbow-arch.
Pavel
Post by Pavel » Sun Dec 30, 2007 12:04
So, knyazivs'ke, you will have to do a self-made points with six diodes on the eyes. :)
Князевский
Post by Князевский » Sun Dec 30, 2007 20:29
+++++I just have a sneaking suspicion that You Christmas garland from mindmachine going to run...
I also thought to please the family a magic pill that brains right and fun for a celebration will do.
And read more about this method?
uzho lighter on the LEDs (Beli) apart.
Князевский
Post by Князевский » Sun Dec 30, 2007 21:54
Wrote a similar session, but it did not justify ideas. I wanted was a background light 56% (i.e., permanent) and a pulse of 100%. Ie that would not blink and would highlight more strongly the already existing light. But it turned out not so. Turned flashing from 0% to 100%, from darkness to full illumination.
I have something not properly done? Could you tell me?
The second question is how to specify the looping algorithm? And the session eats up a lot of space.
The third question, read but not understood:
Programm download, Download the Session(Clear) - set a single session, removing the first set
Removes and native session? Or just the ones that I have installed?
Thank you
1 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
2 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
3 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
4 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
5 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
6 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
7 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
8 0:01.0 PFr 0.25 IN 240 50 100 100 none none 0 0
9 0:01.0 PFr IN 240 0.25 50 0 0 none none 0 0
10 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
11 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
12 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
13 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
14 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
15 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
16 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
17 0:01.0 PFr 0.25 IN 240 50 100 100 none none 0 0
18 0:01.0 PFr IN 240 0.25 50 0 0 none none 0 0
19 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
20 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
21 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
22 0:01.0 PFr IN 240 0.25 50 56 56 none none 0 0
:evil:
Лилка
Post by Лилка » Sun Jan 27, 2008 22:36
I started using session R5 "Left brain" (.. Gee.. well, the name))..)(from the series Special application). Cool!!. What is unusual: when the sound only from one earphone. :ap :wink: :)
Сомневающийся
Post by Сомневающийся » Mon Jan 28, 2008 0:29
You know me all the time gets my old "friend" all the time in my head, how do I get rid of the talker, well enough already in the end of it all :evil: :evil: :evil: :evil: :evil:
Post by Андрей Патрушев » Mon Jan 28, 2008 10:08
Сомневающийся wrote:You know me all the time gets my old "friend" all the time in my head, how do I get rid of the talker, well enough already in the end of it all :evil: :evil: :evil: :evil: :evil:
The world is ruled by LOVE... :)
