The UKE Selishcheva
Has thanked: 478 times
Been thanked: 264 times
Re: the UKE Selishcheva
Post by ЛИЛИЯ-Р » Thu Oct 25, 2018 16:02
Логик wrote:I suspect that these runes should radiate energy, even apart from the UAB. And can be carry as a pocket source of energy. Although there are other ways to take the energy with them.
Gotcha all the Runes can be used separately, but only these 4 Runes work with the ASD devices . It was under them configured devices.
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Thu Oct 25, 2018 16:19
And if UAB would not runes, it will cease to work or become as the UKE?
Post by ЛИЛИЯ-Р » Thu Oct 25, 2018 16:51
Логик wrote:And if UAB would not runes, it will cease to work or become as the UKE?
It is configured to work with the Runes.
Post by Логик » Thu Oct 25, 2018 16:53
ЛИЛИЯ-Р wrote:It is configured to work with the Runes.
Do you mean stop working?
АЛЬФИЯ
Been thanked: 8 times
Post by АЛЬФИЯ » Thu Oct 25, 2018 17:32
Runes and Devices complement each other.
You are absolutely right that it is possible to wear the Runes and they will also work on cleansing and healing. ASD without investing Runes is effective too. But not converted to the UKE.
But the development of the devices was in the following sequence: initially there was the UKE, then UAB and then it was revealed that in combination with the Runes of the device even more harmonious.
And the Runes description abstract because it can not be. Runes - a thing sacred and they will always be a mystery.
Post by Логик » Thu Oct 25, 2018 17:39
ALFIYA thanks for the reply.
I understand that UAB is working with the runes inside are stronger than without runes?
АЛЬФИЯ
Post by АЛЬФИЯ » Thu Oct 25, 2018 18:44
Логик wrote:ALFIYA thanks for the reply.
Yes, along with the Runes more powerful.
ММ
Has thanked: 185 times
Been thanked: 40 times
Post by ММ » Thu Oct 25, 2018 23:32
And if you put the device in the car, will decrease the number of gasoline consumed? How much?
АЛЬФИЯ
Post by АЛЬФИЯ » Fri Oct 26, 2018 7:07
To date, a decrease in gasoline consumption by 15% with the installation of the UKE.
As for the cars, and when installed on the truck. This happens due to the fact that the devices organize the structure of your liquids, and, accordingly, it is consumed in smaller amounts.
The greatest effect noted partners engaged in cargo transportation, for them, the savings are considerable.
UAB is more powerful and the effect of fuel economy should be roughly about 25%. But while observations continue, because ASD there is only 2 years.
The effectiveness of the UKE to save gasoline is confirmed by numerous reviews for more than 15 years of existence.
Post by Логик » Fri Oct 26, 2018 7:21
АЛЬФИЯ wrote:UAB stronger
Any ASD is mightier than the UKE?
АЛЬФИЯ
Post by АЛЬФИЯ » Fri Oct 26, 2018 13:32
Yes, UAB is inscribed or included all the properties of UKE plus additional. So Yes, more powerful.
Post by Логик » Fri Oct 26, 2018 20:36
Here moderator cleaned it up a bit. Sorry to have erased some information about runes. Restore:
Runes which are supplied to the UAB kicking themselves energy. They can carry as the additional source of energy.
Post by Логик » Tue Oct 30, 2018 10:33
On the website Selishcheva found the following description
UKE "Baby-fullerene"
Extends the UKE "Baby" and amplifies its effect by connecting to one of the universal structures of the Universe.
Important not only the effect of the presence of the UKE, but the effect of contemplating it.
Can you explain why it contemplate what it gives effects. Why you need to contemplate precisely fullerene. About the UKE ASD design the other of such information is not in the description.
АЛЬФИЯ
Post by АЛЬФИЯ » Tue Oct 30, 2018 15:50
Because the structure of the fullerene at the sight of it harmonizes the person.
A second person comes into direct frequency and communication with the crystals, which are assembled fullerene.
Post by Логик » Tue Oct 30, 2018 17:31
АЛЬФИЯ wrote:person comes into direct frequency and communication with the crystals, which are assembled fullerene.
it seems not all fullerenes are collected from crystals
АЛЬФИЯ
Post by АЛЬФИЯ » Tue Oct 30, 2018 17:59
That is all fullerenes harmonize, and those with crystals give an additional effect.
АЛЬФИЯ
Post by АЛЬФИЯ » Thu Nov 01, 2018 11:21
Device Updating Being formed by three Fibonacci spirals, in the plane of the circle, and out of Runes, located in the center of the device, with a dot inside , which has the function of actualization of the fullness of New life that includes rational and irrational aspect.
АЛЬФИЯ
Post by АЛЬФИЯ » Thu Nov 01, 2018 14:22
What is the difference between the spirals of the Golden section and Fibonacci spirals.
The Golden spiral is perfect. It corresponds to the Source of harmony. This spiral has no beginning and no end. It is infinite.
The Fibonacci spiral has a beginning from which it begins to "unwind". This is a very important property. It allows Nature after another closed loop to construct a new spiral from scratch. All natural spiral is the Fibonacci spiral, and in works of art used both spirals, sometimes at the same time.
АЛЬФИЯ
Post by АЛЬФИЯ » Thu Nov 01, 2018 16:24
The Fibonacci spiral is observed everywhere (in nature and not only):
the seeds in most plants and are located on a spiral;
- a spider spinning a web in a spiral;
- spirally twisted hurricane;
- a frightened herd of reindeer scattered in a spiral;
- DNA molecule is a twisted double helix;
- embryo develops in a spiral shape;
the Galaxy has a spiral shape.
Магирани
Has thanked: 3 times
Been thanked: 2 times
Post by Магирани » Tue Nov 06, 2018 5:15
Hello. I have a question. Looked aaisina the UKE, well, for example, the uke kid with the star-the radius of 75 meters. Ie if you put the apartment on the 6th floor in odnopodezdny 12-etazhke, it turns out it will work on all occupants of the house?
АЛЬФИЯ
Post by АЛЬФИЯ » Tue Nov 06, 2018 9:26
Reviews of children's institutions:
Children's Center at Pokrovsky Hills purchased 3 Devices of concentration of Energy in 2006.
Since the acquisition of the UKE group for Children Center was a significant positive change in the behavior of children to parents to teachers, in particular, and to the entire Center as a whole.
Teachers felt the positive impact of the UKE for yourself. Many were able to establish family relationships, to improve appearance, become less sick, feeling a surge of energy.
АЛЬФИЯ
Post by АЛЬФИЯ » Tue Nov 06, 2018 9:28
Магирани wrote:Hello. I have a question. Looked aaisina the UKE, well, for example, the uke kid with the star-the radius of 75 meters. Ie if you put the apartment on the 6th floor in odnopodezdny 12-etazhke, it turns out it will work on all occupants of the house?
You are absolutely right! Hello! All the occupants of the house. And over time, the entrance will start positive changes, the troublemakers, the bullies move in, and others will improve the physical condition, mood, it will be pleasant to live.
АЛЬФИЯ
Post by АЛЬФИЯ » Tue Nov 06, 2018 9:30
In the State educational institution kindergarten № 2177 Rostok SZOUO Moscow since the opening of the preschool (24 April 2007) was established devices of energy concentration of spiral type in the amount of 8 pieces.
During this period of time the kindergarten has achieved a high rating among companies not only in kindergartens of the district, but district.
The staff of the preschool believes that with the UKE, in the preschool institutions there is a concentration of favorable energy, which positively affects the microclimate and the work of the team.
Магирани
Post by Магирани » Tue Nov 06, 2018 12:10
Then it begs the following question: judging by the reviews and photo agencies, where the UKE, their number is clearly more than one(in the same school as many as 8 PCs). Why so many? After all, the logic can be set to one of UKE El with a star, its radius of 400 metres-enough to cover the entire territory of the school.
АЛЬФИЯ
Post by АЛЬФИЯ » Tue Nov 06, 2018 12:39
The house is usually up to 4, 5, even 10 people who voluntarily live together with common interests and common energy field.
In school, the concentration of people per square metro much more!! Also in shopping centers, railway stations, etc. In such cases a single UKE or ASD not to handle, on average, in places of a mass congestion of people 1 UAB or UKE 40 square meters.
That is buying a device home, the main goal for you is to establish family environments. The neighbors, too, will be better, but for you it is not an end in itself. In institutions buy the device in order for anyone to feel comfortable in the room.
