Noopendants psychic series
Favourite Helen Any way, the shading of pendant may vary , and the color and transparency of the coating may be different , because to say that these pendants is dark , such as bright ..and this difference is impossible. When buying at the office we remind you to mark at once, and multiple copies of the ID numbers did not to lose. In this case, probably only flashing if you fundamentally know what 2 which.
Любимая Элен
- Has thanked: 9 times
- Been thanked: 1 time
Re: New! Neocolony psychic series.
I bought not in the office, and in the Witch's happiness, there did not say anything. MMN is pouring from me, I just remembered. Others see the scheme through the fill, so I would like to here someone posted a picture... so you can distinguish them. Flashing is not an option, I don't trust the firmware... So please if someone can help.ЛИЛИЯ-Р wrote:Favourite Helen Any way, the shading of pendant may vary , and the color and transparency of the coating may be different , because to say that these pendants is dark , such as bright ..and this difference is impossible. When buying at the office we remind you to mark at once, and multiple copies of the ID numbers did not to lose. In this case, probably only flashing if you fundamentally know what 2 which.
- Has thanked: 1 time
- Been thanked: 182 times
Favourite Helenscheme everywhere looks the same, adjusted for manual work.
Любимая Элен
The pictures in "Witch's happiness," they look different. Understood, thank you.Андрей Кабанков wrote: ↑Thu Nov 15, 2018 16:48Favourite Helenscheme everywhere looks the same, adjusted for manual work.
Hello, still not used neocolony. Can I purchase nookular MMN? Or better Cencentrate for a softer effect. Task - activation of their abilities.
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
Ирина23, will fit both the Hub is more versatile and easy to operate, MMN - a more advanced level.
Got Nookular Hub 31.12., wear 5 days of no sensations. Is this normal?
Also purchased nookular Hub. No sensation and no change.
Aura
By itself, the format of the report speaks volumes. What kind of tasks were set, how, how was the interaction with the pendant, what tasks were set as performed work with pendant, is not clear. All very short and clear. Respectively and result.
The hub itself is a package of psychic, that is, at least, should be that concentrated. It is not clear that concentrated, respectively, and an unclear result.
Yes,nothing is clear... the Problem of course is, if you purchased this nookular more concentration.
Aura
Мария1712for development of concentration, as the quality of work attention, would suit a Mental. Nookular responsible for focus (concentration) already gained psychic abilities may increase the power of thoughts, words, intentions (given that they have at least some actually are!) connects to extra energy for realization of this task, is responsible for personal power, increases sensitivity to subtle energies and others Need to understand what energy tools and how they work. The fact that just hang nookular/map/artifact and wait for the result a little. Freebies in any field, and especially in the development of psychic abilities, no. Moreover, in the psychic sphere must have an appropriate sensitivity level or frequency, to clearly perceive the result, the pendant has a lot of "rude" by the high standards of work, something pulls-pulls, something patches, depending on the initial conditions the work can be solid and long...and the user is reviled pendant a couple of weeks, but still without much effort, and concludes that "no results"
Nookular is a tool, that is, it works if you use it, and not work if they do not use it. I can tell that the user is doing wrong, if the situation is clear, the overall picture, the intent and actions of the operator. With such a scanty description - can't help you. Tool, know as the hammer
That is, if in this analogy the user writes "hammer nails", then you need to make sure the hammer is properly used...but primarily that it generally "picked up"
I'm not saying that nookular not working. I just Express my opinion about his work personally for me. Before you buy nookular,I have studied its characteristics, etc. neocolonial. If I wanted a "Mental"I would have bought it,not the hub.
Aura
Then I apologize for interrupting Your process of Expression.
If there is a need to speak more to other topics, welcome to the Club of Self-development
Then tell me how to use it properly.
Aura
Aurawhether the release of a production (not custom) plastic with all programs of neocolonial psychic series? If so, can you provide guidance on time? Thank you for your answer.
Aura
- Виталий Куклин
Colleagues, really nobody is talking about this pendant? Still no interest in this pendant?
ЛайфОператор
- Has thanked: 27 times
- Been thanked: 14 times
I have interest in this pendant. But I wait for him in the form of plastic "Alchemy". Maybe for the may holidays will appreciate the release of this card, I hope so)Виталий Куклин wrote: ↑Mon Mar 25, 2019 12:02Colleagues, really nobody is talking about this pendant? Still no interest in this pendant?
- Виталий Куклин
Lol, I do the same when I wanted to take plastic, even the 1st map, very cool to wear in itself, in General, some pluses, not bought on financial issues, take the pendant, to wear of course not always pleasant, although it may be the path I incite so... I have now in the group, a microcosm of the cloud and a cornucopia...ЛайфОператор wrote: ↑Tue Mar 26, 2019 0:09I have interest in this pendant. But I wait for him in the form of plastic "Alchemy". Maybe for the may holidays will appreciate the release of this card, I hope so)Виталий Куклин wrote: ↑Mon Mar 25, 2019 12:02Colleagues, really nobody is talking about this pendant? Still no interest in this pendant?
Would be best split up to track down... But a microcosm had been physically injured, so I decided to take cloud and as you know they are very powerful couple and collect them in a group, well, RI then decided to add... Maybe make a Cornucopia in a separate topic, who will support?
ЛайфОператор
Aura, good day! Tell me this is a specialized card with all pendants psychic series? Or just all programs of pendants psychic series will be added to the software library card "Alchemy 1" and will include a choice of mixed in with the programs standard series of pendants, any card "Alchemy 1"?
Hi! And nookular psychic line how soon can I start wearing? I have a pendant of the first level, a Corsair, with the new year, i.e. about 4 months of wear..I want to also buy a Magnet of Love.
And both to wear or the first to be put in a box.
Can be worn at once, both or separately.
For all Your(Aura) answers gratitude! 5 years of using the products from quantum magic, but only neocolony (NK) <<filled my soul>>. On the merits: working with 8
NK <<raped>> questions and I ask You, if possible, to answer.
1.The feelings of the NC are noticeable at a distance to feel private extension of EI field. Does this sound like the plan of the Creator NC ?
2.Think of <<nationality>> unscientific term. And what a scientifically sound concept <<genotype>>? Is it possible in this context to argue about some predraspolozhennost-
areas to the specific programs of different NK (without decryption) ?
Remain sincerely Amateur.
Magnet love nookular, began to emerge in the work, points to the doorsteps of perception. There were two bonus, there is a lingering sense of universal love, the question remains, how is energy consuming for the operator and what to do in this state or walk of love that requires certain rules and conditions of behavior and perception of the world, the conditions for staying in love. The question how to live in this state, to be in a state of love to the world is another form of perceiving the world,and how safe it is.Or the state of love itself exists, and the picture of the world to this what is relevant.
