Card Chronos Delta
Prayer is such a thing... a breath of alchemical air, which is mixed with light that can be deduced from the dark state of the soul of Nigredo, statics, pitches (this is not about you, but in General). From the air, actually, and it begins the transformation, the transformation (air, light goes into the body, changing it, then there's fire, water and copper pipes)
Some are afraid of prayer, afraid of some imaginary thought forms, but physiologically it's all just concentration on the upper gives you enhanced blood flow in the parietal lobe of your brain, well, and then everything happens by itself. Trying smart prayer (she practiced continuously, 24 hours a day, in parallel with other background) for a couple of weeks from my crown/the crown popped up the paperclip, and then off we went, top down and flying clips, even in areas that are not described anywhere... an Alternative way to breathe in light through the center of the forehead with the breath inside the body. Or normal breath through the nose but very deep and slow, it felt like breath comes to the center of the brain (yogic breathing, prana, just physiologically, stimulation of the olfactory areas of the brain that lies most deeply in the subcortex) - the mind clears like pepper breathed, well, sleepy begins by breathing - it wakes up the pineal gland, producing the hormone. Physiologically, the purpose of prayer and similar breathing is the stimulation of the pineal gland and the receipt of "heavenly water", is there then its heart and even pull/pull.
Sorry off topic ))
Sorry off topic ))
Re: New! Card Chronos Delta
passing
Explain amps.(in my branch)how to do smart prayer, and how do you manage not to touch the egregore,although in this case, the word egregor probably does not reflect the essence.
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
Worked with all three situations simultaneously?АндрейСу wrote:I found for study 3 situation and started working with them. Before deep roots are not reached yet no one (so make it "with nothing to confuse")
Only You can decide. Any inharmonious structure causes an outflow of energy. At the point of unwinding because I wanted to remove? Recently, the PM addressed a similar situation, found that the point of unwinding of the variant lines were selected “from the head”, the logical decision to change so-and-so, and not based on emotional reactions. This cause could result in described below.АндрейСу wrote:each "problem" has different "levels" and the study was including the idea that maybe there doesn't need to clean? Ie there are blocks that limit me, but wouldn't it be worse if not limited?..
АндрейСу wrote:as an experiment, a situation in a situation of manifestation of the unit card has not removed the effect of the block. Upon contact with the map and the relaxation of thought, the condition has stabilized, the negative symptoms are gone, but a minute later, when you return to the situation, the unit is immediately returned.
passingUnder all subscribe - APPROVED! ))But there's still something to think about , so as to realize something else needed. Oh, young and wise, honestly. From the side it is more visible,but inward to look all scary)),we're wrong , we're not "oil"))in the inside)) well, angels . And here to get acquainted with them is stranovedenie sometimes ...someone ...and almost everyone.
Because basically teach us to see childhood outside and not inside. But they taught those, too, who taught. Who started the cutoff of watching yourself from inside your on the world? The world outside , say, but we all feel instinctively. Because all your rodimenkogo blocks that porazhdaet their "cockroaches" inside, we believe, is the external evil. There is nothing in the out,correctly, everything inside goes to the outside, to contact and back.This is the inverse to filter. Sent , then come back.....but often send one, and returned , with the development of apponenta , and possibly more. The aura of prednaznachalas to protect from such"gifts" if we have her full understanding. As on autopilot she of course accepts, and reflects and passes need inside an animal's brain(as he wrote in passing), but the relationship of GM with a brain of sapiens ...this is where it all began...the implant . Who , when, why , something useful on this planet in this body-conscious? Or use or restrictions? No one really knows the rumor said. I think while at it....
From what sistemine push off, from what point of view nor look ..and all can be customized under the system and prove. Tried different))) and it turns out , however.
The conclusion is(IMHO only) all the fantasies of our mind??? Or not ours???Again looking outside)))
Well, to yourself is necessary to know, at least for someone to see God, and he has created a copy to yourself of course))). Dig in faster than digging in someone else outside. Even though all that is out ,we are still using their experience and miss their evaluation this give.
In passing, here to clarify :"
"..The bottom is cut off from the top, the brain currents constricts the vascular system,..." is that the brain was not information on the action, so it is not "made":)) Then it turns out the autopilot protects the brain-consciousness , in the form of blocks , from experience? Probably watched this when some action is involved banging hurt, but it did not even have time to understand and feel involved, and the pain somehow fades away, but the effects can manifest by bruising and pain. The brain builds a protective barrier fuse ?Or the subconscious?<мимоходом wrote:What happens to the blocks? The bottom is cut off from the top, the brain currents constricts the vascular system, impaired blood flow to the brain (transfer of energy) and the nervous system is filled with currents (disturbed transmission of information). Relationship falling apart. In the end, because of the violation of circulation of energy of the bottom settles "oil" in the stomach, in the unconscious man into the bright top and dark bottom. A fuse of the psyche (soul) is cut off the understanding and awareness of it, so as not to injure the soul (which is still knows this, which is unfortunate). So the oil accumulates at the bottom and life is actually "the flow of energy in the past", which is actually now enshrined in man.
Taken out of contextГуфест wrote:Lily-P
Very true.....Pruning easier by itself, without emotional problems
ЛИЛИЯ-Р wrote:Pruning easier by itself, without emotional problems , compartment and all. AND awareness of them helps to do the following...
It was originally. That's why I wrote to cut just without awareness-identify root easier , sparing for the psyche, but does not solve future problems, not realizing the root(not dig))) you can spawn on blocks
Who is man - the most interesting question. Either nothing, or everything, or both. Whether neither one nor the other. Either both and neither (this is the highest level logic of the four steps completely abstract and paradoxical, when all true statements and they are contradictory - and it all fits correctly)But there's still something to think about , so as to realize something else needed.
I think it's easier every one of the blocks (implants) everyone puts themselves according to their experience (good question what is "its", don't know). Helps in the production blocks the whole environment from birth, sharing their limited experience, solely out of love (from it is without exception, it is possible to uncover logical) - as a teaching consciously and unconsciously, acting (copy of internal States and imitation). Newborn kittens are clawing at each other - who are they implants put...implant . Who , when, why , something useful on this planet in this body-conscious? Or use or restrictions?
From the position the top person can be thought of as consciousness, sinking deep into the energy to understand her, this strange and completely opposite. Dive into darkness, into chaos and at the same time density, NetCast, inertia.
From the position of the bottom of the person can be thought of as the seed (the DNA molecule) growing into grass, then a tree (roots and feet, the trunk - the spine, the crown of the brain). The energy that is drawn to such a strange and incomprehensible top who knows how to think, not to perceive that the bottom is quite unclear.
Man is simultaneously both ( and neither) - structure, the result of the penetration of the poles into each other. The structure, which is able to build itself, to improve, to complicate things, which is potentially all the information the top and all the energy of the bottom of the question in experience, development, dock. No one intentionally puts the implants in, it's just a cosmic love and a different level of exploration of the space of the Kama Sutra, the positions of the occurrences of each other. At someone it turns out the sex is worse, well... there malice here, no one. There is a suspicion that the Earth is just very young and not very experienced (her experience stored in DNA of different individuals), and the top is probably also a different experience.
Probably they block each other, protected each other, fearing and wanting at the same time. Because the opposite pole - he totally other, incomprehensible, unclear what to do with it at all... So in the process of life and learn to understand each other, and maybe even love. In gender relations in ordinary life - all the same, it is appropriate to recall the hermetic principles.<the Brain builds a protective barrier fuse ?Or the subconscious?
in passing
"What you sow,....."
so to speak, and can:"... the end of the one-himself thought that even if someone is, in himself and put aside the "aftertaste".All in all the process...
Right to vent, Yes
and once in the right channel that energy. Often -angry and the object of "evil"
-triggering the reflex patterns-the autopilot......Conscious letting off steam-can be very interesting and even healing, which is actually divided in passing. Understand who this is for today or not, every valuable experience , not fantasticheskogo.
WellГуфест wrote:Quote: love And kindness a person feels only himself, the rest just projects its condition.You could,and that in return on the other end?
IMHO , a psycho wielding, and in fact, just the original ability to control the energy as thought, and Vice versa, to think correctly, not pravilnoe important, it is important to feel the effect of that thought within yourself. Then think won't be destructive)) It's like eating bitter pepper and think about Bulgarian sweet - will not workГуфест wrote:Everything else requires a revision of concepts,because it is not the psycho.To let off steam or to do the right thing appropriate to the situation
Right to vent, Yes
Гуфест wrote:then after some time it's just another irritant that can itch,cry,and holler, it's all in the shuffle.
Guest This is something that everyone should know and teach their children. We have not learned them too . Then the blocks will not be prepromote through the years, when one day awareness-letting go(forgiveness) and to sleep on the study of a different reality. And here shablonchik ))"tomorrow is another day"))) many people think that it is necessary to think in the morning -light comes to mind ....type..)) in the Morning comes the additional realization yesterday. Navi reconciliation with reality, in all entities or in all States of the person as a whole-consciousness-the subconscious mind-body and other ...мимоходом wrote:Quote:doing This meditation?Simply a relaxed state that is best achieved by lying in bed in the dark, before sleep. Like all psycho like forgiveness to do better in this state. In my experience, is the best meditation that may be because it lies on the border of sleep, and sleep is so unconscious thinks just, images, this is the second way of human thinking, which is quite possible to bring to reality and to associate with logical thinking. And mood before going to sleep will continue in sleep, and much to be worked out "by itself", as the unconscious is also the person half.
Why the invasion? Interaction .As yavi and Navi ,but why we share it. And again, why is bad)))), maybe it's our back?Гуфест wrote:Unable to determine? invading your sleep, other people who invade with good intentions.and in my dream, many things will worked out "by itself", as the unconscious is also the person half.
Aura
In fact, this happens infrequently. Variant line may continue in the other life only when a certain density of consciousness, when the generated structure is written on the soul level and stored after passing through the frequency filters after death. Normal reflexes do not have such density and lose their “personality” after leaving the soul body. Filtered information is not transferred to the new body in its pure form, after death, the soul also passes your information (life) cycle before we acquire the ability to form a dense body. It is clear that the more developed the consciousness, the faster the regeneration. Thus, the filtered information becomes the information for a specific condition for the continuation of the cycle of development of the soul, but not a direct continuation.Арина.В wrote:And that's interesting, this is the root episode, but he can be attracted by something similar from past lives?
The same generic program to correctly treat them as the information conditions (in this case – and on the physical level, innate, natural), a set of codes access program connections for defining existence within the physical layer, and associated at this level with blood circulation (generic programme are the "blood" in the truest sense of the word): how filled or not filled with blood (and energy) our internal organs and brain, all depend on emotions and feelings (e.g., inadequate energy supply to the spleen leads to anxiety, kidney – fear, the heart, to temper or hatred, etc.)
Aura
Emotions are one of the signs and ways of energy supply in the country. Remember any of the episodes of the successful learning of anything: learned to walk, or ride a bike. The first new experience is always vivid and accompanied by increased (positive or negative) emotional background. Yes, you can use a strong, positive emotional background for the formation and consolidation of new behaviors, it is important to state change. But this is only one of the ways of energy programs relating to energy supply to the horizontal level. Well, if the experience is accompanied by the natural positive sensual experience, but only use emotion as the sole source of energy, can lead to burnout in the truest sense of the word – our luminosity transformirovalsya in emotion. Software energopodachi can occur in other ways, each has its pros and cons. To the previous topic, the recollection of the transition of the soul from one life to another can also be a source of energy for work programs (new behaviors, the formation of neural connections). Another truly “storehouse of energy” – creative energy. The formation of new neural connections the same process that made the creatures – is also creating a new one. Why not use creative energy in building its reality, can be called the process of peacemaking. The other two sources – temporal and spatial. The first is associated with concentration, dragging a finding in any of the new state. The second experience of a harmonious state, the experience of something aesthetic, a sense of balance, equilibrium and proportion. The energy is more subtle than the energy of the emotions.<Милая wrote: Did I understand correctly that new neural connections are formed easier in bright emotional experience? Ballast lines are formed in bright uncontrolled negative emotional experience? Is it possible to consciously use the positive emotional state for the formation of a new pattern of behaviour? Like well pumped herself on an emotional high and start to do things not previously comfortable?
Aura
FirstКорвин wrote:Question on the instructions: cut off after the detection of each root ( the beginning blatnoy lines), discovered a Bay next time with this place, or once after several attempts I realized that is not deeply immersed, then cut off.
Aura
Yes, that's right foundГуфест wrote:Crystal is left in the form of a small black dot where the figure at the Windows.
Aura
Yeah, maybe on the stage between the window II and window I can connect to the background, which can lead to a small residual deployments of the line, in General, the process is positive, tells about a potentially deep level of immersion.Арт Мак wrote:At the first session with the map noted that the previously found (still no card) the root of some ballast lines deepened on a couple of points,but it is interesting that this happened not at the stage of search, and time to shut off... is This normal?
Judging by the reviews, working with the map in my sleep went well, the option of cutting off immediately after waking up does not really work, because the right moment leads received in a dream the experience with the work of consciousness – awareness of the root that may not always happen-happen. The period of sleep to effectively use the dive, you can go deeper, because lack many protective mechanisms of consciousness, but after waking up you need time to reconcile memories of the dream to real-life situations and experiences. This will depend on the quality of work of the subconscious, as information from subcortical to be "transferred" to the cortex.Арт Мак wrote:immediately had the idea (maybe without the involvement of Card): if the search box is open and make friends with the body (duct tape,for example) during a night's sleep, and on awakening to open the cutter and work found in the sleep block (and,even if the fragments of the dream is not remembered, it still work)? IMHO,of course.
Aura
Chronos card works fine on NLP recognizes the former,the concept highlights the awareness and eliminate the first window.Judging by the reviews, working with the map in the dream went well
Lily-P
Display a block in the energy zero,be indifferent to it.
What you say is correct.This valuable experience of personal development in the spiritual sense.And awareness of them helps to do the following...
honestly - difficult. But with a Map - better: practiced/cut off "communication," emotions, better awareness of the situation and the fact the man seems less and do not have such emotions when I think of him; let him go, so to speak, with God, the inner is replaced by the negative not that of indifference, but definitely not this snaidania. And yet.. when the negative "were worn in the bosom", it was a feeling that the chance to meet this man almost at every step, and now what ever our paths do not intersect.ЛИЛИЯ-Р wrote: All honest work to forgive yourself and others?If you tell yourself that it's their experience in this life..I think without the ratings for plus and minus, it is easier.
Tried a few nights before going to sleep is letting go , forgiveness of everything)). Then half the night these characters, why, then showdown))those situations that have left a negative footprint. And still have the morning to continue the re-evaluation and release. All consciousness is , almost, the accumulation and the cutoff...perhaps it is because the brain repetitive processes ,translates into the automated mode .It is possible that over time this will take up less mental space and time of accumulation-the definition of pruning,but wouldn't that be to the detriment of sensibility?Зухра wrote:honestly - difficult. But with a Map - better: practiced/cut off "communication," emotions, better awareness of the situation and the fact the man seems less and do not have such emotions when I think of him; let him go, so to speak, with God, the inner is replaced by the negative not that of indifference, but definitely not this snaidania. And yet.. when the negative "were worn in the bosom", it was a feeling that the chance to meet this man almost at every step, and now what ever our paths do not intersect.ЛИЛИЯ-Р wrote: All honest work to forgive yourself and others?If you tell yourself that it's their experience in this life..I think without the ratings for plus and minus, it is easier.
Зухра wrote:LILIYA-R wrote(a):
All honest work to forgive yourself and others? If you tell yourself that it's their experience in this life..I think without the ratings for plus and minus, it is easier.
. You can consider this: We all at some energy level are a set of different "blocks" or reflex response of our consciousness. These "blocks" is because of our attitude towards the world. These "blocks" can be called the reference points in the picture of the world. Or "cities on the map of the world" between these "cities" have connections or "roads". The World treats us exactly the same as we treat him, but rather the attitude of the World toward us, this is our ATTITUDE. And if we don't like something, it's not a problem World, and the problem of our RELATIONSHIP to Him . Changing even one "block" leads to a change in the entire "map your World" that is the rebuilding of relationships, the "new roads and highways" (infrastructure), and it is a huge job. And there is a very ancient instinct, which does not allow to ruin your life, whatever it was. Therefore, true forgiveness, is a very serious act of influencing the RELATIONSHIP to the World, and even impacting the World in General. So, really forgive, not that easy, but quite difficult.<ЛИЛИЯ-Р wrote:Tried a few nights before going to sleep is letting go , forgiveness of everything)). Then half the night these characters, why, then showdown
LILY-P Yes, at me too such was, more than once: like everyone already knew, forgive, let go, and then the dream, and again either the same emotions pop up, and once even almost broke a man in a fit of rage, live in one leap and began to choke, I've never felt, tin
But I don't remember where I read about that in the Wake can mentally simulate even forgiveness, and in the dream, like as not, at least it's harder...
that's right - a litmus test.Арина.В wrote:the missing piece of the text: so I read that these dreams don't just happen, they are like the test situation as a litmus test
Why am I so confident Vasu about it (?), probably because in practice always turns out that, if you forgive/let go of/to mogeconebat, the subconscious, the next dream will not show the same "addiction": if this happens, then a glitch in the theme or a slightly different article - "Fear".
мимоходом wrote:But overall, I can see your attempts to show itself in all its glory, I admire you, I said "that's developed man, look at him." But I can't say ))) Because I see only a gramophone.
And he asks you because you asked yourself when, maybe yesterday, your answers is also himself the answers.
And still-provocative questions-jerking situation for the emotions
Each other teaches us something, even if it seems to him that at the moment "teacher." In fact , only the student responsible to himself, to his higher and the way I am, but the cleverness and the importance it seems at the moment own.
recently asked the blonde man, while he(a) wrote(a) answers that I have found(a) the answers for yourself. That was not the first time I also noticed.
The most from what is repelled , says I'm not and I don't need it, he just does not understand, no wonder such issues and situations throw up, really need to understand them and work. There is just the unit)).In another case, not even heard such questions provocative situations would not exist. This is for all-for all.
)))) it seems that the Card is valid even in the forum thread )), even if casually did not buy anything, as someone said above in the posts.
in passing, I'm not particular about You, I'm on the combined participation in the discussions )
passing Well, that explained herself and him and everyone that everything is normal and designed this way)))All is well designed . ))And all this study of our reality.
By the way , found which part of the brain responsible for time or past lives? What "part" has such a property-appointment as the connection between the consciousness of the present and the past? To say that it is not linear, of course, but not all think so. The connection of consciousness with the part of the brain-that's what I ask. Oh ))she understood anything that was asked?))
