Ring. Interaction. Bee.
Малика
Has thanked: 251 times
Been thanked: 110 times
Re: The Ring. Interaction. Bee.
Post by Малика » Sat Aug 13, 2016 16:59
I put pull the root chakra, the feeling was just indescribable..but the feet are not attached, will have to try.
The first time when I was working with aku-WAC in the hands of a point in the middle of the palm started to inflate and a lot of ache...Now this happens from time to time.
Пчела
Been thanked: 146 times
Post by Пчела » Sat Aug 13, 2016 17:00
2. Times had such questions, he continued his experiments.
Alternately, for about an hour, took the product and on the South side were placed in the center of the palm, pinched fingers, relaxed. The feeling that included a vacuum cleaner and started sucking the brains out of the skull. Now massage the brain, so massage. Hand, the continuation of the brain, or what?
Do I have the knowledge, though not conscious I have received from teachers. Our karmic blocks are in the area of the throat chakra, the Vishuddha. If so, then maybe we get the practice of reducing karmic blocks problems.
You need to work with two products. To take in both hands, relax, meditate and pay less attention to what processes in my head, and catching sensations in the area of Vishuddha.
Пчела
Post by Пчела » Sat Aug 13, 2016 17:24
And another experiment today.
Still 144 is the impact on the physical body. But here's the thing. Nothing hurts.
Lay on your right side, the product laid on the bed, the South end directed towards the liver. After about a few moments of silence, inside began some jerks. As will be inside strung some strings of rope. The strings of the rope alternately began to break, and the fact that they had attracted, have the freedom. After a few jerks of breaks, went deep into touch. Woke up an hour and a half. Pillow is wet and I'm in the same position on the right side. Very deeply failed.
My guess. We all know that our internal organs have their own consciousness. In case of a serious threat of death of one of the bodies, others begin to share with them their own energy. Moreover, different people, different bodies.
Then those who have not quite healthy, but leading in this field on, you need to start intensively, so to speak, to irradiate this on Aku-VAK. Then all the rest.
Пчела
Post by Пчела » Mon Aug 15, 2016 1:08
An interesting result from the next appointment. Sharing rings and Aku-Waka.
Yesterday I went to bed and everything was arranged in the following way.
On the back of the bed, his head ring. 188, size 3.5 wire 4mm. In the legs between the feet ACU-VAC. 144, size 3.5, 4 mm. wire South side facing you.
The ring works top-down from head to feet and from the feet ACU-VAC pulls to itself. Somewhere very deep fast and far flew to six hours. Came back cheerful and relaxed pofigistka. Don't know where to put myself now. Six in the morning.
Пчела
Post by Пчела » Tue Aug 16, 2016 12:35
Aku-VAK 177, size 3.5 wire 4 mm weight 403 grams. One more unit.
My present understanding about products slim. On one hundred percent completeness and truth does not pretend. Just my personal opinion.
1. Ring. Designed to clean and restore our Etheric Body outside. That is, our Aura.
2. Aku-WAC. Designed to clean and restore our Etheric Body within us, including the separate Auras of our internal organs.
3. Harmonizer. Harvester. Combines the functions of the rings and Aku-Waka together.
Сабрина
Has thanked: 97 times
Been thanked: 10 times
Post by Сабрина » Tue Aug 16, 2016 19:46
Dear Bee. Thanks for sharing your experiments ..))) it is so nice ;;))
I would like very much to have stayed in their jobs and continued to share
It really helps )))
It is wonderful that all interested in the topic of the rings and all on the forum in the first place SHARE THEIR EXPERIENCE AND EXPERTISE
IN A DISPUTE ROZHDAETSYA TRUE ))) :o :o :o
ЮрС
Has thanked: 6 times
Been thanked: 5 times
Post by ЮрС » Thu Aug 18, 2016 15:52
Пчела wrote: Aku-VAK 177, size 3.5 wire 4 mm weight 403 grams. One more unit.
Please tell me the inner diameter of the Assembly,if it is not a secret :)
Пчела
Post by Пчела » Thu Aug 18, 2016 17:19
ЮрС wrote:please Tell me the inner diameter of the Assembly,if it is not a secret
30 mm
ЮрС
Post by ЮрС » Thu Aug 18, 2016 19:31
Thank you!
ЮрС
Post by ЮрС » Thu Aug 18, 2016 20:28
Looked at Aku-VAK in different versions and noticed that the photo of Humpty wave going one way,and the Bees to another variant of the slim match with a twist of Humpty. Question: how to change the product?
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Thu Aug 18, 2016 23:34
30 mm
I actually like the right perms Ku-Waka 8)
or is it 177ой stol eh? che ajna pounding :?
Малика
Post by Малика » Thu Aug 18, 2016 23:56
By the way, Yes, after testing the photo I immediately determined that I have a problem with the thyroid gland because started to flatten my thyroid not too shabby... one thing is very much working..I mean right a Perm Bees..
Пчела
Post by Пчела » Fri Aug 19, 2016 0:40
Шалтай Балтай wrote:or is it 177ой stol eh? che ajna pounding
This, 144.
Honestly, it is the result of monthly experiments. And happened arbitrarily. My attempts to turn himself, resulted in a fiasco. Went to the people. Made the first kowaku wire 2,8 brought home, suggested to my wife to try. 30 minutes later returned. Yes myself like that not. And the quality too.
The second special spinning on a lathe. But Turner was indignant that the wire is stiff, etc. Patted me nerve. I brought home and not hopes suggested to my wife to try this product. There is a caveat. 25 years ago, she sprained the right leg, dislocation in the bone. Local bonecrusher with diploma of medical school, what sort of rules, then hollowed bone/low bone and as a result, the thickening of the bone, increased raising of the foot, thickening of the bottom of the legs, the problem with the shoes, impotecne and circulation.
Aku-HAC put the retractor side of the bone rod angle 90 degrees, he went into another room and forgotten. After an hour approximately, the wife calls and asks to check the temperature of the feet. Touched, cold. How cool, I have a feeling that my foot, in a fiery bag. In General, it was the only device that she felt. But previous kowaku felt.
Got to thinking and saw that the coverlet is made in the right direction. Error Turner, only. But I do not like his mood. Plus, he couldn't exactly pull wire.
In General, I now have a third spec. Him I deliberately ordered the right spin. But it is a miracle to adapt. He had a homemade machine type grinder. In the middle is the sleeve with the cut grooves. The wheels teeth. And handle like grinder. The diameter of the wire increased. Increased and the inner diameter of the product. Now clear 4 mm diameter wire, internal diameter 35 mm (I haven't been posting, I have only one product). Check for problematic leg wife showed yesterday.
Put her now on the direction of the stop, the retractor side and he was gone on business. Came back three hours later, she's in the kitchen. Well? Lost a baby. Okay, my feelings were? Yeah, like a hole in the leg from the foot up and pointing fingers, the diameter of six centimeters. I'm certainly very pleased. So much suffering. A little excess fluid drank and the leg is swollen. And here punching energocable up. The evening brought two twisted billet new Aku-Wakow. Both for my wife. In the morning, give the welder. The fact that I don't cook myself. This is the fourth special, but he is the best in the city.
And given the stuff where I Roma overpowered the latest products, the direction of Curling generally not a problem. The direction depends on which way he turns the handle of his grinder. At the same time, he previously still aligns the wire to the ideal state. And cutting grooves on the sleeve, on which the appliance scrolls.
Oh, I forgot. Current products have already a size four. Love that everything was as it was combined or something? Size four, four wire.<
Пчела
Post by Пчела » Fri Aug 19, 2016 0:47
ЮрС wrote:Question: how to change the product?
Very powerful pull, but very powerful pumps.
To answer the question, twist the left one and get on for yourself, and then answer. I feel good energy.
Пчела
Post by Пчела » Fri Aug 19, 2016 1:20
There is another consideration, which is now deliberately pushing me to the manufacture kuwaki with the right spin.
For a start I suggest to zahoditi in category "Talk about everything", the theme Of "the Creator of the Universe and about us..." which led Brave. There is a animation about how planets move in the Solar system. They move behind the Sun in a spiral, napravlenie rotation, twist the right side. In the right!
There is a photo of curls on the crown of the head. The direction of twist when viewed from above, the same to the right. So, my kuwaki, being twisted to the right, just, coincide with the natural movement of energy.
In General, we can say, the error of Turner, and to reflect on the theme that we were looking out some Forces.
And then it is not the fault of Turner, and the result of THEIR efforts and look closely.
Пчела
Post by Пчела » Fri Aug 19, 2016 1:33
So weld ring my welder. Wire 4 mm.
I actually, more to organize.
ЮрС
Post by ЮрС » Fri Aug 19, 2016 2:02
Пчела wrote:There is another consideration, which is now deliberately pushing me to the manufacture kuwaki with the right spin.
Great!Curiously,I'm 17 years before spinning to the right for 33 times or more,the first exercise of Eye Revival,and it somehow balances and helps to maintain the health... All the same,right rotation is the Natural rotation. :)
Пчела
Post by Пчела » Fri Aug 19, 2016 3:42
So now it looks this product.
177, size 4, wire diameter 4 mm inner diameter, 35 mm.
Пчела
Post by Пчела » Fri Aug 19, 2016 9:13
Inside the 144 and 177, size 1.5 wire 4 mm.
Next, 144 and 177, size 2.0 wire 4 mm
Outer 144 and 177, size 3.5 wire 4mm
Post by Шалтай Балтай » Fri Aug 19, 2016 10:03
Пчела wrote:this 144.
surprised myself, it does not look like 177, and in the ajna gives :?
Post by Шалтай Балтай » Fri Aug 19, 2016 10:37
right back
that lathe without reverse so clear, because the left - hardly wound
I have looked at Morse and lathe chucks
well.PA - in reverse. it is not :)
I would not hurry with the right spin, slim was no fool, certainly on the same rake to get up, however twisted the left
I'd poolitical right for a while before
and about the intention not to forget, Turner is Turner... better than most. This is the technology PIECE goods - in this principle. The production here is inappropriate, not the energy :)
although the toy all the ro will be working, that's a fact
good luck!
Пчела
Post by Пчела » Fri Aug 19, 2016 11:31
Шалтай Балтай wrote:the Production here is inappropriate, not the energy
Rings, as required, the twist itself.
Aku-Waku, after failed attempts to do not going to try. And these searches only stage, stage. While the heat.
Post by Шалтай Балтай » Fri Aug 19, 2016 11:48
Пчела wrote:Rings, as required, the twist itself.
respect
Пчела wrote:Aku-Waku, after failed attempts to do not going to try.
Cheh, I understand You. :) The snap-in needed. Chuck would be the ideal solution, but the reverse, reverse 8)
turners, blacksmiths, better enjoy snap, shake, boil - better, that is my vision at the moment :oops:
Пчела wrote:and these searches only stage, stage. While the heat.
with both hands behind
visnudutas are rife :wiz
Пчела
Post by Пчела » Fri Aug 19, 2016 12:03
Шалтай Балтай wrote:turners, blacksmiths, better enjoy snap, shake and cook
Why? For a pair of or three products? I'm looking for something that would work and helped wife! Its not sensitivity, zauberei skin on one leg and a bulge in the bone. I have this option found a couple of products she used and gave it to the welder. A couple more myself. And that's all!
But get a thrill from winding rings. It is a fact. But here an impasse. All who were here, did. Those in the picture last. You may be on the horizon wire five, then have fun. Replace four of the top five.
ЮрС
Post by ЮрС » Fri Aug 19, 2016 12:38
Maybe take a drill with reverse and used as the engine to a lathe Chuck?
