The Egg Of Nostradamus
Седой
Has thanked: 13 times
Been thanked: 36 times
Re: The Egg Of Nostradamus
Post by Седой » Thu Jul 07, 2016 1:52
Bioenergetic properties of popular metals. Don't want to spoil the magic word.
Copper - malleable, friendly person. Programmed and cleaned easily and repeatedly. It is better to apply as nakaplivaetsya device. Takes the surplus energy of man. (copper oxide poisonous)
Bronze neutral.
Aluminum is easily programmed and cleared but keeps the information not long, better to use as the emitting device.
Gold Reflects the energy. Not programmable almost neutral to the energy of the person. More often harmful than helpful.
because of the properties of reflection it makes sense to apply gold plating in designs to reflect the action, like an egg.
Copper in the egg will absorb all the energy to pick up then slowly re-emit or take (depending on design and intent)
Silver is the Most useful and supportive of the metal. Pliable, easily programmed and cleared.
The problem of silver in a very quick impact of the program and erase, respectively. Actually one-time actions. It, like a letter.
Read and thrown out. Programming for a harm to humans silver is impossible. Unlike gold and copper...
Iron is The hardest metal. For the development of programming iron mage requires 20 years.
The novice magician, makes no sense to mess with that metal. As it is the last in a series of all metals.
Iron can be programmed Archmage, call it so. Once and for all. (before the destruction of the object in the fire, melting)
About magicians able to program the chromium and Nickel is legendary in small circles. :wiz
lead, tin, alloys of such soft metals, the dirty dark metals with very low vibrations. Favorite metal dark people.
in particular cadmium.
Don't keep them home, not one of them. And not only because of toxicity.
A little about the shielding properties of metals.
The screen concept is very distant from the concept of metal. That is, any metal in any quantity and the form is not the screen.
This is not to invent tools able to replace the gold.
Gold able to escape, reflect the energy and other metals no.
The same applies to the purely electromagnetic nature. The screening, which is very difficult. No one wondered why the phone receives calls even in a closed iron pot? All are convinced that every metal box has a screen, alas it is not. So as to effectively screen attached tail. (hooves and wings) in the form of grounding or diversion of energy. But this case is already so complex that doing it individual specialists in electronics and a method scientific. If someone has the experience in making sensitive RF devices, it must start from the words "correct wiring" and "shielding", even worse from the phrase "minimizing EM interference" And since knowledge is considered as the most expensive (measuring equipment) on this day in the world and only interested in military and other abstruse professionals and Amateurs is neglected at all. This very concept screening by a specialist is associated with headache and for the student something very simple, like a tin can.
Since I offered to cover the miracle of the egg with gold leaf, now constantly have to defend their point of view.
Can I had your personal idea about the design of the egg and the author is not obliged to follow the same path. Although I have eggs then and there and have no idea of what stump is planed, however I am interested in the communication and exchange of experience. Maybe my knowledge of anyone in need will be.
On account of perfectly polished surfaces.
Undoubtedly, than a perfect surface, the better it is. And the most ideal is of course mercury amalgam. But of course, not in cases of this good man. Mercury shyutka usually end a long and painful illness and death. Believe in the word, all this panic and shiz because of the broken in house thermometer not from ignorance and stupidity. (distracted)
So. The first thing you need to decide is what we expect from a certain device and the principles on which it operates.
This energy storage device, the emitter or the reflector. Or Uvse in one. After should choose appropriate components for its kind of the parameters for this case and then think about improving, polishing to perfection, and so on.
For example, if you make an egg of steel with perfect polishing to get into it, it will absorb all the energy of a person in a matter of minutes, and soon will kill and drive crazy. It has been experimentally proven!
If coated copper it will be inertial, will be slow to pick up then slowly radiating, so-so's kind clumsy stupid giant. Little and offend the mind. Another problem with copper, it oxidizes quickly and the oxide is toxic. Really poisonous. If varnished, it is a polymer that creates an additional surface layer of orgonite, which will make it even more inertia. If God forbid you want, as you have already started to think about it, to cover the copper powder with the varnish, get a very inertial organic able to very quickly absorb the energy of the person, to the same Polish in a not-ventilated enclosed space. In one word it's a torture chamber, and very likely with fatal outcome either from poisoning or from energy depletion. Leave the choice for the pathological anatomist.
Reached aluminum.
Aluminium, as a woman of easy virtue drunk LSD. Will focus all the noise from outside into focus. Concentrate on your own thoughts it will be incredibly difficult. But this is the best receiver available metals (zinc even better but it's toxic...)
But his passion for the fleeting relations... in Short have to worry about the environment, to Refine it and Lilith, then as a means of receiving information from the outside, this egg will be the best possible. Of course a portable or public such a construction should not be done. With ORGANICA of aluminum powder, simply multiply everything said on 10. And don't forget about poisonous varnish.
In such a camera is very convenient and comfortable to go crazy. The feeling will be similar to taking LSD. And if you do everything right and harness that will vision. And so what...
How to behave in the gold foil.
Gold reflects the broad spectrum of energy and information. It reflects that mean all your thoughts will focus and strengthen you in the head. This can lead to clairvoyance and re opening or disclosure of their own capabilities and knowledge.
If you make a small diversion of energy, as I wrote, stuffed in a tiny hole in the top of the radiator. This concentrated energy can be directed. But if developed sensation the answer will need to wait out the eggs.
Well. I tried to explain what was happening, ready to argue and discuss, without Hamsa. This is my attempt to explain the unexplainable based on personal experience.
Good luck.<
аВАЛОН
Post by аВАЛОН » Thu Jul 07, 2016 22:35
Седой wrote: ready to argue and debate without rudeness. This is my attempt to explain the unexplainable based on personal experience.
Good luck.
honestly with all due respect but it's hard for me imagine how that is theoretically present and to repeat correctly and beautifully almost uniform, without wrinkles and overlap the pieces of gold tinsel with respect to the form of such a complex is quite :? 8) tried to stick evenly without wrinkling the aluminum foil. to resemble the shape (sphere 15 cm) as he tried without folds and without overlap to realize I've failed, like hands not curves :) here form more but nevertheless will be quite difficult I think, what do You think?? to spend those resources of time, money, etc to create the form and stoning is not aesthetically pleasing as the house is built from expensive material and "tarugado" from the inside, not the outside cheap beautiful way :)
РамД
Post by РамД » Thu Jul 07, 2016 23:46
аВАЛОН wrote:what do You think?? to spend those resources of time, money, etc to create the form and stoning is not aesthetically pleasing as the house is built from expensive material and "tarugado" from the inside, not the outside cheap beautiful way
So, when creating a new always inevitable errors which were corrected or in the process or taken into account when creating a new sample.
In fact this is why you started the topic, hoping to hear practical advice based on experience.
P. S. the creation of the pyramid was more than 20 prototypes before you get what we have.
But still, for the dream has to always pay and thank God that the money you can pay)))
РамД
Post by РамД » Fri Jul 08, 2016 1:45
Седой wrote:Aluminium, as a woman of easy virtue drunk LSD. Will focus all the noise from outside into focus. Concentrate on your own thoughts it will be incredibly difficult. But this is the best receiver available metals (zinc even better but it's toxic...)
But his passion for the fleeting relations... in Short have to worry about the environment, to Refine it and Lilith, then as a means of receiving information from the outside, this egg will be the best possible. Of course a portable or public such a construction should not be done. With ORGANICA of aluminum powder, simply multiply the everything said on 10. And don't forget about poisonous varnish.
To Rusalka went need to varnish, I don't think?
Юпитер
Been thanked: 2 times
Post by Юпитер » Fri Jul 08, 2016 2:13
Rand
with susally a lot of trouble a few layers of primer coating itself is not easy ,
then grinding , the work is manual and not cheap , and a varnish more questions .
possible other options are chemical and electrochemical gilding to consider .
equipment is not cheap but compared to susally may be cheaper to go out and the surface smoother ,
only here in the egg is it possible to handle such equipment probably need the developers to ask .
immediately important concave mirrors in the device , if we consider the seal and focus the energy time , not the infrared sauna style eggs.
Kozyrev's followers say that aluminium gives better effects, but not the fact that they are gold tried.
РамД
Post by РамД » Fri Jul 08, 2016 2:25
Inside the egg is smooth , grinding is required.
gold leaf, too, with primesyami and 24K square 6kV to cover only if there is no other alternative.
aluminum,copper also eat leaves as Rusalka but a lot of doubt on these metals.
РамД
Post by РамД » Fri Jul 08, 2016 2:28
Юпитер wrote:only here in the egg is it possible to handle such equipment probably need the developers to ask .
shramirovaniye,spraying is not an option for mirror in divorces due to the concavity of the egg.
and aluminum as in the mirror?have napoliroma??
Юпитер
Post by Юпитер » Fri Jul 08, 2016 2:39
shramirovaniye, spraying is not an option for mirror in divorces due to the concavity of the egg.
I understand and aluminium foil glued to plastic , and aluminium sheets twisted .
and copper probably tried.
here are some videos
Седой
Post by Седой » Fri Jul 08, 2016 3:50
Clambered sites selling Spalko. M yeah. Well, the prices.
Because in my opinion no matter what the thickness of the coating, and as you can see with susally gold will be crap, maybe just make gold dust and RUB the entire surface. Bronze powder sticks to any surface very easily, I think gold will be the same.
But the quality of gold to do not difficult. Refining in Aqua Regia or dissolve in mercury, then evaporate the mercury, it turns out the slurry, powder.
Really don't know how many will leave metal on the entire surface, but it is certainly cheaper than gold leaf.
Dear fun turns.
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Fri Jul 08, 2016 19:01
РамД wrote:shramirovaniye,spraying is not an option for mirror in divorces due to the concavity of the egg.and aluminum as in the mirror?have napoliroma??
Gray just thinking out loud))) But maybe there is just a mirror, i.e. the reflecting surface is needed , no matter gold or silver? After all, mirrors were covered before silver, and that all this device use I could not, it is covered with gold whose reflectivity when polished excellent. Copper tarnish with time and polishing it is difficult, aluminium and lead. Not thought about it?
аВАЛОН
Post by аВАЛОН » Fri Jul 08, 2016 23:40
watched videos on YouTube for working with szalkai, this individual an art and a separate direction. I do not understand another point can anyone explain the Church's dome today is covered with gold leaf not susally and the effect is too (Yes of course the issue worse, better, difficult to solve practical need to try different options), approx moving to Ukraine at the prices of tinsel I got about 120 dollars, equivalent to approximately approximately. I asked for it etc. the idea is to create a cap, a hemisphere of half the globe , from the middle of the veneer, tinsel gold, inside optical fiber or other source, or without anything, because most likely probably presumably the main result of the prediction, clairvoyance, etc is the work of the upper chakras, why do we need the bottom of the lower centers of energy in the whole body is placed in the space an can the top enough to achieve the result will be? :wink: :wink: :wink:
Седой
Post by Седой » Sat Jul 09, 2016 3:50
I will answer at once.
There is a scale polishing. From 1 to 12. Previously, it was up to 10 now, 2 more added in connection with the development of technology.
So the level of 5-6 can be achieved by manual polishing. There is a 6 m2 it work for a few weeks.
Glass for household mirrors are chosen on the surface defects at least 8-9 years on the same scale. Good and expensive 10. 10 and above is a mirror of the telescopes and similar spec. technique.
Polish in hand to a mirror surface state, the more concave is simply not realistic.
As for the need for this. I personally doubt very much that makes sense more than 5 on the same scale. But to call it a mirror... By the way during the experiments with the Kozyrev mirrors are always telling that there is mirror polished, and sat down to judge by the videos there polishing 2-3 at most.
That is to touch smooth shiny surface that will reflect light. But to shave in front of such a mirror I would not. :wink:
By the way, very easy and cheap can put on any surface of the copper by chemical means. Copper sulfate and a reducing agent in the form of Hydrazine.
Copper quickly tarnishes and becomes poisonous, and if varnished, have to breathe the same varnish. This is considering that the chemical deposition of copper will cost about 10-20 dollars and a couple hours labour to make the process reusable.
Or at least try it once with a copper full of happiness. And then rinse.
Tell an old joke about this.
My grandfather in the village of sick geese. Causes the vet, he comes, busily taking goose, tugging back and forth for legs, goose dies.
The grandfather says wait there is another option, takes a second goose pulling the beak behold, the goose dies again. The grandfather says wait there is another option, and so several times until all the geese have died. At the end the grandfather says the son options that is and geese are no more.
Кремень
Post by Кремень » Sat Jul 09, 2016 10:24
Gray,what do you think, what level of polishing is sufficient for the product(which we discuss).Here, for example, coating with gold leaf,as you suggest,to which class according to the above scale can be attributed?
The only thing I wanted to add that concave aluminium(silumin)lends itself well to mechanical polishing(personal experience,details small but many),magnisoderjasimi alloy steel and of course much more difficult.Yes,silumin tarnish,polished much more slowly,but do not see this as a problem,I by the nature of their activities often Polish such a surface,even if he(silumin) after a while(weeks)faded "passed"drill with a felt tip, and again, the surface of the source.
Артфан
Has thanked: 516 times
Been thanked: 22 times
Post by Артфан » Sat Jul 09, 2016 12:11
димыч wrote: keep their shape due to the tension of the ropes
Cable-stayed suspension?
аВАЛОН
Post by аВАЛОН » Sat Jul 09, 2016 14:24
as revising ancient Egyptian mural came across a mural which describes 12 types of radiation including today people are not studied and not open. considering the egg Nastradamus what kind of energy is it? what type of energy we are considering, what type of energy we are trying to work? :)
мимоходом
Has thanked: 66 times
Been thanked: 312 times
Post by мимоходом » Sat Jul 09, 2016 14:27
and can find and show the mural.
Седой
Post by Седой » Sat Jul 09, 2016 21:50
Flint
I think that it is enough that the surface is smooth and shiny. 3 to 5 on the scale. I'm not sure that this greatly affects the result.
About Kozyrev's mirrors, it probably is not the quality of the surface and in the absence of a film of oxide whose conductivity is much lower.
In the case of gold to think about it is not worth it.
avalon
Don't know how many forms of energy found Egyptians, modern scientists have managed to access 2000 different particles, some as much as virtual. And so called. The virtual particles.
When mathematics come into physics, you can open anything. Would be an idiot willing to pay the grants.
I believe that in nature there is only one particle of the Electron. And one type of energy is the centrifugal force of electron rotation around its own axis, with an associated mass and charge and all the other miracles.
Ланцелот
Has thanked: 33 times
Been thanked: 11 times
Post by Ланцелот » Mon Jul 11, 2016 11:16
Седой wrote:I believe that in nature there is only one particle of the Electron.
Not for the sake of argument, but simply to expand.
1. Is an electron.
2. The concave mirror surface reflects the noises that are produced by the body. Somewhere here on the forum wrote about the experiments in the polished steel, the walls of which reflected the sounds of the body back to the man. Given that these sounds can be controlled...
3. Sizes give different surface energy (as an electron fit - I don't know), and given concavity can be anything.
IMHO, to consider the energy of the camera from the position of only one electron, in advance to narrow the range of operation of the device.
димыч
Has thanked: 7 times
Been thanked: 16 times
Post by димыч » Mon Jul 11, 2016 14:20
Yes something like this, if the topic was to confirm what effects, when he will finish the egg - something to do others who want to repeat the experience
but for various reasons do not want to deal with a stationary design? Will have to move in the direction of simplification of construction-Assembly.
All you can think about what technology was Nostradamus, copper was very expensive in the middle ages.
I tend to think that it was a big barrel, maybe somehow modified, padded inside with sheets of metal,
and then make the sheet metal it was labor-intensive for the blacksmith.
Рита С
Has thanked: 4 times
Been thanked: 30 times
Post by Рита С » Mon Jul 11, 2016 23:09
Binding wire 100 rubles
The blanket lifeguard 300 RUB.
Take eggs, chickens :)
РамД
Post by РамД » Tue Jul 12, 2016 0:50
:ay :ay :ay
аВАЛОН
Post by аВАЛОН » Tue Jul 12, 2016 10:41
Рита С wrote: The blanket lifeguard 300 RUB.
Firstar emergency blanket rescue blanket the blanket is designed for the temporary reduction of heat loss of the human body in case of emergency. Is a thin film made of PET (thermoplastic) coated with a metallic reflective material (gold and silver), which reflects up to 80% of radiated body heat. the Blanket is made by coating a thin layer of aluminum on the film base. :?
Седой
Post by Седой » Tue Jul 12, 2016 23:14
1. Is an electron.
About the same as the electron fit into the theory of radio waves, antennas, and other RF electronics. Curves sideways.
Nobody knows how but still build antennas, reflectors, experimenting with form and content.
The human body changes its conductivity depending on brain activity. It is a fact.
The human body emits a very wide range of fluctuations. ELECTRONS. From INCH to GVC and deep infrared.
People during mental work radiates about 100W of energy per hour.
So the task of fixing this radiation, and / or manage a trick.
Given that the spectrum peak brain activity comes at frequencies of the order of 1-20 GHz, and the skull absorbs almost all the energy of this radiation in transferring heat, it is very difficult to record these fluctuations on the device type of the antenna and sensors. But when focusing, with the use of concave reflectors, it's still possible.
And then the task is to focus this radiation back into the head that much easier, as the receiver is the brain far exceeds the ability electronics.
Юпитер
Post by Юпитер » Wed Jul 13, 2016 9:18
a good test for material selection
РамД
Post by РамД » Mon Jul 25, 2016 1:29
To all the readers of Hello.
I want to know :
-how interesting is the egg?
-desire to experiment in the egg?
-ready to participate in the project and what role is given to yourself?
You can PM.
