Appeared in the sale of rims from Andrei Patrushev
Better to listen to separately!:),then the effect will be better and faster!I tried to mix a session with the programs on the disks - sometimes horrible state caught up and never could...I have the feeling that before drunk alcohol..not nice...And water you need to drink pure (filtered or regular purchase)...
About theta meditation "Lucid dreams":
Dimas asked: so, 1,5 weeks "dreams": what was first - the first couple of days I could do certain actions to control within the dream, but it seemed that it infringes on me that I have large manipulation; in a few days it began to decline as with alpha records Patrushev - no conscious control of the dream: the battle began, the attack on me, naselenie feeling of fear, anxiety, guilt, the attempt of inciting me to murder in my dreams (couple of times, inflicted the fatal blows). Only now it is all beginning to end.
If the "Conductor" of change felt in the space around them (my outer circles), when the theta meditation are already internal changes of some structures. :!:
>and one horror-like,God forbid anyone ...
You just realize that critical moment of fear that this was just a dream and nothing more. And then you'll see that all this illusion disappears and appear actors. However, you then either will take back to reality or will attempt to hurt. If the basis of feelings in the dream is fear, then so be it.
Suppose theta meditation should listen to regularly: deep/deep conversion requires a lot of time, and one listen gives the initial shear and all sorts of distortion associated with it.
: :!: :idea:
Zdrastvujte, Andrew!
I have strange sensations while working with the drives "Healing" and "file Explorer." Are 30 minutes normally, and then there is some strange uneasy feeling (in the solar plexus) and not the strength to lie there, not moving, and hear the end of it. Is it possible to interrupt the listening to like 5 minutes, and then finish?
And another question - If to think about something else while listening to disc Explorer, it's not too hurt efficiency?
Hello, Lev!
It is not necessary to lie still. Usually pulls "to curl up in a ball" (the fetal position). This is perfectly acceptable, but like any other poses. It is also good to listen to while sitting back on the seat of the chair or sofa (in some ways it's even more effective to listen to posture, since it is not associated with the usual sleep). The program is better not to interrupt, but if it is absolutely unbearable, then again, nothing bad will happen. Most likely it will have to do times two or three at the most.
You can't think about something extraneous while listening to the guide, any thought will be "in theme". Most importantly, do not cling to thoughts, and observe them as if from the outside - to let free flow.
Good Luck Running!
Good Luck Running!
I have about the same feeling - something like listen to the end - that just makes you want to move (shake) feet and that's it.Lie about 30 minutes fine, and then appears a strange uneasy feeling and not the strength to lie there, not moving, and hear the end of it. Is it possible to interrupt the listening to like 5 minutes, and then finish?
And another question: the manual says that if you listen to the conductor just before bedtime, you need to hold a stage of relaxation,
What does it mean? After the conductor listen to a relaxing session or something? Because I, after the conductor I think this rasslabuhe that any longer, but am feeling like all night my muscles were tense, like something woke up and forced myself to get out of bed.
But anywhere does it say that you have to be completely still while listening. On the contrary, the text specifically says: "move if necessary...".
Stage of the relaxation is at the very beginning. Meaning that You focus on her, and follow everything it says, and then you can let yourself go to sleep. Really the handler gives the reduced need to sleep for 1-2 hours. But in the beginning, when there is a large debts for the rest, it is possible such phenomena as You describe.
Thank you!
Just when you make even one small movement, then spontaneously go from the state of relaxation, and to back the efforts ofАндрей Патрушев wrote:Yes because it hasn't said what need to be completely still while listening. On the contrary, the text specifically says: "move if necessary...".
Can only podtverdite feelings leva and SDen. Oppressive oshushenia when listening to "Explorer" was not, but when we started singing, the beginning of the sausage. This is my third audition. First time sausage beginning with the ankle of the left leg, seized the left thigh (pull start). Today it was the same with the right leg, just picked up the sternum and in the end even the entire breast. Feelings, for those who are experienced, there is a "symptom of restless leg", so this is a typical manifestation when not twirling, not something - some longing, desperate to change the posture, moreover, by the end of all was to pull off the headphones and glasses off. At the end we could not decide with the feeling - not relaxing, but not anxiety. Indeed, the feeling of confusion and razdobudete.
For myself, I determined that in my head and in the body as a whole is not all Ok. We need to continue, even after the session even Murasaki ran through the skin.
This replica - not a complaint and not a question, just some statistics for Andrew. And the fact that my whole psyche parkeriana 4 years of war, awesome quite a bit of pressure at work, death of loved ones, it is clear the stump, that the head of the order can not be. By the way, when navoyevat relish, no one even hinted about psychological rehabilitation, and I mentally mowed down with machine careless crowds of Muscovites in the 90's. Now it is long gone, I don't think now with hot spots better than the people looks like.
Many people here say that someone is creepy, then sausages, then scratched here and there.
Personally, I have from listening to a disc, for example theta-"dreams" Patrushev, the beginning always starts to tear right eye and a sensation of cold on the tip of the left foot is present, and a couple of days ago confused on the mind-machine of the left ear with right (look the same) included a session on dreamlike images, so watery both eyes to the end of the session :!: Might want to be carefully with headphones
: :idea:
Yes, probably, this description more accurately describes my feelings while listeningГен wrote:I Can only confirm the feeling levs and SDen. Oppressive oshushenia when listening to "Explorer" was not, but when we started singing, the beginning of the sausage. This is my third audition. .... .... so this is a typical manifestation when not twirling, not something - some longing, desperate to change the posture, moreover, by the end of all was to pull off the headphones and glasses off. At the end we could not decide with the feeling - not relaxing, but not anxiety. Indeed, the feeling of confusion and razdobudete.
And when the game started, with the balance of the sound (move left to right and back), then I already threw surprise
It feels really strange. Not to say that I never experienced, but very rare and strange :!:
Thanks for the feedback!
The fact that our body works very efficiently. Every organ, muscle, gland have a representation in the brain, and thinking brain uses the same areas that are responsible for the organs. As a result, when we have strong emotions that we are constantly "chasing" or thoughts about the same, the brain sets the focus of excitation in a certain place. These pockets, by the way, perfectly visible on the CT scan of the brain and are taken by experts for the consequences of small strokes. The result in the corresponding place of the body there is a raised or lowered tone of muscles and vessels. This deteriorates the nutrition of the cells, supplying them with oxygen and removal of waste products. In recent years this theory is gaining more and more supporters, because the techniques of psychological rehabilitation, developed on its basis give excellent results. in the United States opened the Institute, where he studied psychological methods of treatment of various diseases.
When you are working with a guide and a Massage of the Brain, then, of course, the problem areas begin to react. When "discharged" any problem area, then there is drowsiness and increased appetite. In this case, to speed up the recovery, it is useful to make light (flexion, extension, torsion) physical uprazhneiya on the muscles of the body, to take a hot bath and a good laugh.
Good Luck Running!
Good Luck Running!
Sorry.Ген wrote:4 years of war, awesome quite a bit of pressure at work, death of loved ones
I found a solution (although it may not all fit) during the oppressive feelings - to make some deep and intense breaths.
And I was interested in the question. At the beginning of the use of the machine (with wire) I disconnected after 10 minutes of listening and woke up before "meditation is over", and then stopped off and was 70 minutes! Now I understand what it is. Just in the beginning I used 21 points Track Color mode(Right blue, left green), and then switched to 1, which could not sleep. When you sleep you do not bother
It is necessary to raise the volume on the player and adjusting to mindmachine.SDen wrote:Damn, I'm the Conduit through mindmachine "don't blink", I just listen to![]()
maybe again something with the wires, but it seems twisted spit- nifiga! The only way glimpses about thirty seconds blink. Can someone tell me what am I doing wrong?
I think for those who are listening in the morning or afternoon, this is not a suitable option because from the blue will "nod"Андрей Патрушев wrote:To support a variety of audio programs best suited blue.
By the way for your endorphins which colour will suit?
Something I'm not very good to lie on your side in standard headphones...Андрей Патрушев wrote:Usually pulls "to curl up in a ball" (the fetal position). This is perfectly acceptable, but like any other poses.
About the blue - it's not as fatal as You think. For the Endorphins, I guess - yellow (yellow-green).Лёва wrote:I think for those who are listening in the morning or afternoon, this is not a suitable option because from the blue will "nod"Андрей Патрушев wrote:To support a variety of audio programs best suited blue.
If you listen to half-sitting (reclining), it is easy to pull up to his chest.
I have a question:
In session "Healing on the magic river" with a 40-minute start clearly audible alternating-common "the chirping of a grasshopper"does not understand - is a built-in sound or distortion when recording?
Compared with the .wav, copied from DVD to hard there just as chirps, as if everything is as it should be.
The fact that it is the chirping gets on my nerves, not natural sound, Wake up and become unpleasant to listen to, if not reach poludim....
