The System Of Pandora. Modules/Condition/Modes.
And the digital sequence {SKIPPED} is a numeric matrix of Pandora? (not tried it - but interesting to know
Re: The Pandora System. Modules/Condition/Modes.
no, this digital sequence is a unique personalized code to each card and cannot be used by people who do not have this card, otherwise something will be
this was discussed on the last webinar
- Has thanked: 1 time
- Been thanked: 182 times
Then I removed the pictureСтАвР wrote:no, this digital sequence is a unique personalized code to each card and cannot be used by people who do not have this card, otherwise something will be![]()
Thank you for the warning! (Pandora only use as a component in the map Masculine)СтАвР wrote:no, this digital sequence is a unique personalized code to each card and cannot be used by people who do not have this card, otherwise something will be![]()
PS - and all the same intuition did not fail
And no matter interested or not, to embed photos suitable only in certain maps.ММ wrote:not Even had time to see the photo as it was removed.Well, at least in lichku throw.Codes the mod are not interested.
Yes, I have a special photo to post, I'm just in the process of labor forgot to publish them. Now will do.Андрей Кабанков wrote:Then I removed the pictureСтАвР wrote:no, this digital sequence is a unique personalized code to each card and cannot be used by people who do not have this card, otherwise something will be![]()
Photo (the photo card) has no dangers of "bad use", but working with numbers can only operator that owns the card, so I took a photo of her and warned on the webinar to use someone else's sequence is impossible, it will cause a technical "out".СтАвР wrote:no, this digital sequence is a unique personalized code to each card and cannot be used by people who do not have this card, otherwise something will be![]()
This is a photo of MY cards VIP Pandora. The use of a numeric code cards other people is unacceptable (to be profitable), image viewing/setting the map - quite possible, of course to operatorsthe they will not let You
Michael, don't leave unattended!!!Михаил_ wrote:short version of the description - all the same as the normal Pandora but much more powerful. The long version of the description on the specifics will come later
Michael, again, we must first meet separately with 2.5, 2.6, 2.7 to effectively to use it?Михаил_ wrote:New modules/modes:
- little elephant - hard interactions in soft-infant/harmless form. Soft but very massive analogue 2.6
- leopard - hard interaction signs of rapid selection of variants need high extra energy, the signs eventually built in so to speak. It is both analog 2.6+2.7 supplements+ some quality 2.5
- wind - working with probabilities/worlds/versions (analog 2.5 advanced)
As these modules can be a substitute for States?
Status in Pandora are full analogue and replacement of the States in the BZ.
Explore state 2.x is not required.
Just implemented it differently - Pandora changes the course of the processes in the surrounding reality, and the status of FPL - changing the operating mode of the mental operator. It is quite different. Although further mental operator and affects reality, but this is not so, as in the case with Pandora. One can complement the other.
Like a flasher or as the probability to meet a dinosaur on red square. T/e either works or not
I have no idea of the t/e Pandora can work with anything that does not modify the cocoon of a person without his consent., I can't on this account to say anything about any other products - there is no desire to study them and it is not correct to comment on it.
So that can only be tested experimentally
