Deck Alpha-Vit
арте:м
Been thanked: 8 times
Re: Deck Alpha-Vit
Post by арте:м » Sat Oct 18, 2014 0:34
Волька wrote:This is the bounce or I something not so made? Someone tell me how to fix it?
Judging by the description, in the cases of unpleasant anomalies, disable your deck and to reformulate the purpose of considering a safer and harmonious development of the affected aspects, i.e. financial or conjugated.
Re: Deck Alpha-Vit
Post by Михаил_ » Sat Oct 18, 2014 6:07
Well, it is not clear what was the main goal and so on... I am absolutely not sure that this is the "bounce", it could be anything, up to the beginning of a trend or nothing to do with the deck.
Deck - means increased power, and like any "nucular bomb" requires some skill work.
Usually it is grafted previously on more simple products.
What happened in your case - it is hard to say. Because it is not clear what came before, connected the incident with the deck and where really moved You trend from your wording.
So the answer is - if You don't know the answer to my questions (and your too) deactivate first the deck and practice on something small.
Расторгуев
Has thanked: 6 times
Re: Deck Alpha-Vit
Post by Расторгуев » Sat Oct 18, 2014 23:22
And I have the opposite my deck is still in transit and I have virtual with her work and have a couple of transactions made through alpha-Vit just a mental goal +visually with a deck of virtual cards on the target.Interesting fun was with the purchase of the money went to Moscow the amount that was sent,actually it goes to me tomorrow apparently in Sochi already is.More dreams and a lot of that even the little things,and Yes there is a difference in achievements of objectives through the IC, Y4 and Stabilizer...here is a little bit different can't describe but on another,if so rough it through alpha Vit goal is achieved faster in most cases, a probability of using other products Michael in achieving goals polishable yourself.Many that I have ceased to move assimilation algorithms using the above devices.We need new angles,new levers. See next:)
Расторгуев
Re: Deck Alpha-Vit
Post by Расторгуев » Sat Oct 18, 2014 23:41
And now there was a sense from both the broadcast alpha-Vit and power still growing, and growing,or rather I more and more learn more there is a wave where there are imbalances in the body.
ведьмочка
Re: Deck Alpha-Vit
Post by ведьмочка » Mon Oct 20, 2014 10:15
Расторгуев wrote:... it is likely that many of the likelihood of using other products Michael in achieving goals polishable yourself.Many that I have ceased to move assimilation algorithms using the above devices.We need new angles,new levers. See next:)
I think it's not in the goods of Michael, and in particular the person who uses them. sometimes the person does not notice or does not want to see the problems that he has, well, or is lying to themselves and others constantly, as an option. I do not mean You specifically, it's my General vision of the situation.
Любознательная
Been thanked: 7 times
Re: Deck Alpha-Vit
Post by Любознательная » Mon Oct 20, 2014 10:47
Hello, I'm here to work on the experiments. forced to work on weekends,and it turns out that 3 weeks all without a single output,I'm sick and tired and decided to write the matrix a panacea to all available surfaces, on Windows,on the walls, here and there in hidden places. wrote and on the modules. piglets to normalize the situation, not to work on weekends and so we paid it all worked and the boss is coming at 11 o'clock. sat I worked and then she suddenly and said: Yes, spit on the CEO and his orders.all tired tomorrow do not go))) I do not know the modules are helped or everyone is tired)) but still)))
Расторгуев
Re: Deck Alpha-Vit
Post by Расторгуев » Mon Oct 20, 2014 16:08
I think it's not in the goods of Michael, and in particular the person who uses them. sometimes the person does not notice or does not want to see the problems that he has, well, or is lying to themselves and others constantly, as an option. I do not mean You specifically, it's my General vision of the situation.[/quote]
And I think about me and You don't need to deceive ourselves
Moon
Re: Deck Alpha-Vit
Post by Moon » Mon Oct 20, 2014 22:09
Расторгуев wrote:... it is likely that many of the likelihood of using other products Michael in achieving goals polishable yourself.Many that I have ceased to move assimilation algorithms using the above devices...
Or are you something not written, or what is "learned algorithms using the above devices"? You have learned the algorithm Y4 or СК1М or Stabilizer ? More simpler and understandable language to write these phrases, that it was clear what it was about?
I own the above mentioned devices. Observe the following... the first time I plugged in the first time, "rushing", while the potential is not aligned. When "potential has leveled off" - no longer feel the difference. It is possible to compare how, while in the water do not feel, and feel it is the time of the entry/exit from the water. Here off appliances and a month to include it, and again feel that they work.
But why not there (where you want to) starts to leave energy after the potential has leveled off is not clear. Maybe it's the only way I think that it "not go there" ?
Расторгуев
Re: Deck Alpha-Vit
Post by Расторгуев » Tue Oct 21, 2014 1:09
Yes, it is feel like off,BUT when it comes to the understanding that it is possible to "move"something a little different, and the effect increases, sometimes dramatically.Yes, and "stuck" with the same skills makes us very flexible.Remember yourself when in the past I fanatically studied Karate and that even the toughest fighters in that room which went very quickly and in a "dry" couldn't defeat me,not yet met a good wing-Chun which could put me 30 seconds and I didn't understand how he did it,then this lesson is for me, it has opened up the world of Vietnamese kung fu and the beginning and study with the practical application of the treatises Manteca Chia and many other things..For me then it was a great lesson...,but Oh well what am I.?To accomplish anything well or you can win in different ways and to different situations required different, even if nobody understands them.A "stuck" progress on this is already in General you can see,for me, any achievement is as a springboard to leap to something more.And Yes, I'm not saying that learned everything that is written in the product Michael released a year earlier.
Элиан
Re: Deck Alpha-Vit
Post by Элиан » Tue Oct 21, 2014 1:25
Moon I will assume that there is not potential difference is leveled( so that the potential V4 ogogo) and the synchronization process occurs. It's like getting used to the pen and don't feel it, or not realize exactly how you're driving. Just go.
I assume that Michael_ did not mean the feel of the instrument and the way to work with them. That is, some intuitive rules of interaction with the world through devices. From the deck they in the same key. That is, produce manipulation and listen to the feedback of the world. If something, make amendments, if it is around - leave as is or increase the impact.
Universal advice for that would be aboutto feel how to work with these devices is performed a sufficient number of small targets. These are not so important and easily doable. And about the feel of the products... It's not a heater to warm about them. They need to work. You don't become fixated on the bump of the hull handle, the smoothness of her slip?
Let more experienced users will correct me if I'm wrong. :)
Moon
Re: Deck Alpha-Vit
Post by Moon » Tue Oct 21, 2014 2:18
Elian we user Rastorguyev discussed the use of V4, and understand each other. And you are not "in theme". And here's why:
Элиан wrote:I assume that Michael_ did not mean the feel of the instrument and the way to work with them
Michael still didn't comment about the devices, and you have to "guess" what he meant... :) Or I can not see this post?
Элиан wrote:Universal tip for that would be to experience how to work with these devices is performed a sufficient number of small targets. These are not so important and easily doable.
And you have that small wish will never come true?
To see the fulfillment of small desires, such devices are not needed. Small desire is well fulfilled by themselves. Such devices are purchased for more ambitious goals (not small). I have two Y4 (the most powerful), two years use them, and two large stabilizer and so much (tired to list).
Элиан wrote:And about the feel of the products... It's not a heater to warm about them.
And you have such, or you are discussing something that they themselves have not tried? You can "warm up", why Yes :)
Re: Deck Alpha-Vit
Post by Михаил_ » Tue Oct 21, 2014 4:16
Well, actually, for V4 there is a theme for V4 :)
But in fact - Y4 mechanism of flow generation for all products and operator. The operator is also passive tend in some way to stabilize himself where he usually consciously does not want to be (want to develop somewhere). Therefore, sometimes lack of self-control for active control of devices with a clear filter for your consciousness that is in control of ALL potential and revision of neglected and abandoned in limbo task.
In this respect sometimes helps magazine for the stabilizer. Success.
Юлиана
Has thanked: 61 times
Been thanked: 2 times
Re: Deck Alpha-Vit
Post by Юлиана » Tue Oct 21, 2014 14:22
Good day :) Write a review: using the alpha-Vit my Big goal achieved!!! Interesting were the "anomalies" in the form of "gate." Two identical white cat washing itself at the same time and with one voice mewing, two crows beating walnut (each), two twins, simultaneously waving his hands, two identical cars, with identical numbers... And always appeared unexpectedly before me, so I passed between them!!! When passing the "gate" lit up the back of his head and a pleasant "tingling" all over my body)))
Michael, a Huge thank-You for Your work!!!
НРР
Has thanked: 2 times
Re: Deck Alpha-Vit
Post by НРР » Tue Nov 25, 2014 13:23
Michael, when, when, will be published by the program? :)
АлексейН
Has thanked: 20 times
Been thanked: 3 times
Re: Deck Alpha-Vit
Post by АлексейН » Tue Nov 25, 2014 16:29
in my opinion, intuitively even more interesting. sometimes, though, miss the time, then in hindsight realize... Oh, crap, here he was!... we have still to notice more than usual... at least some practice at it.
НРР
Re: Deck Alpha-Vit
Post by НРР » Tue Nov 25, 2014 16:41
АлексейН wrote:in my opinion, intuitively even more interesting. sometimes, though, miss the time, then in hindsight realize... Oh, crap, here he was!... we have still to notice more than usual... at least some practice at it.
I want to try with application and without it, so to speak to compare, well, interestingly!!) Who doesn't want to let him not use it, nobody is forced)
Re: Deck Alpha-Vit
Post by Михаил_ » Tue Nov 25, 2014 18:49
Yes, You are right, it is good that reminded....
Галатея
Re: Deck Alpha-Vit
Post by Галатея » Thu Nov 27, 2014 22:11
Hello. Tell me how to correctly formulate the goal for finding a job? I used to work suited me, and I told her, Yes, a good salary and want. Can anyone have experience creating a work request. With Respect
Been thanked: 182 times
Re: Deck Alpha-Vit
Post by Андрей Кабанков » Thu Nov 27, 2014 23:53
Галатея wrote:I Want to work suited me, and I told her, Yes, a good salary and want.
So you have already formulated :)
Determine in what area you are a specialist, what kind of work can perform better than others, make a resume, post it on the sites to find/offer work. Notify all friends that you are looking for work. Then the chances of successful implementation will increase many times.
Re: Deck Alpha-Vit
Post by Михаил_ » Fri Nov 28, 2014 0:18
If you have a favorite creative thing-sometimes nothing to do, of course is where it generiruet financial component.
If it's just a job, see the basic rules, the money can't be pure in purpose (they are for something), and, accordingly, the work for the money also cannot be pure in purpose, so you should start with, what is the purpose of basic (what is money and thus the work) and to formulate.
Re: Deck Alpha-Vit
Post by Михаил_ » Fri Nov 28, 2014 0:19
And then, if the work is not work as a good expression (there would be no such problems), it turns out that to find a job just for the sake of work, because put to :)
Евгений-М
Re: Deck Alpha-Vit
Post by Евгений-М » Fri Nov 28, 2014 15:31
Михаил_ wrote:work just for work's sake
That is still come in the end (what you emphasize, for example at seminars) that we must seek a harmonious work?
Otherwise "trouble"? :)
Re: Deck Alpha-Vit
Post by Андрей Кабанков » Fri Nov 28, 2014 15:53
Михаил_ wrote:And, if the work is not creativity as a friendly and pleasant expression
Such works within existing society at all is not enough, someone has and coal mine to produce at the checkout in the supermarket to sit and wash the toilets. And this is the bulk of the workers. No creativity.
Because of this, some can afford to creatively self-actualize, leaving the dirty work to others.
We build a house! To embody creativity in the perfection of architectural forms, but to dig the ground and the concrete pour would have been tedious If all are creative work to whom? :)
Малика
Has thanked: 251 times
Been thanked: 110 times
Re: Deck Alpha-Vit
Post by Малика » Fri Nov 28, 2014 16:36
You know, Andrew, I guess Michael is right, and that's why..I came across people who loved the job that is creative and not name. For example,one friend loved to do the cleaning, and sincerely loved and always tried to persuade his friends to let her in cleaning approach, and constantly take part in to wash floors, etc. the Other was very fond of washing, and the hands, and this is a work I tell You.. what About cleaning toilets I can't say anything, but certainly in other non-creative professions, which seem to be not creative, anyone can, and finds inspiration. In principle it is possible and the toilet CREATIVELY, and with LOVE to everyday life.. :) Again, a lot of people working there, where you can DO but come back to work and do their hours...
Petr99
Has thanked: 3 times
Been thanked: 15 times
Re: Deck Alpha-Vit
Post by Petr99 » Fri Nov 28, 2014 16:46
That's for sure. To any business you can be creative or as required. The choice of the person.
