АЛЕКСАНДР Т. wrote:that is until I really saw nothing in the glasses, barely etheric body, but the etheric body I saw without them. But my friends opened another spectrum of vision. They see without his glasses, well, there is not only the aura and the points they opened another range of vision. Moreover, open a new spectrum of vision, so they survived. Although it's been a few days.
Your friends are doing everything right. To deal with the fact THAT it can be seen seen whether and why it is NOT VISIBLE, you need to understand the concepts of "aura" and "see aura". The most important thing in the concept of "see the aura" is that it is not only the work of the visual apparatus. The most dense part - the etheric double the inner aura can be perceived by the physical eye. All the other layers, and the color of the aura, is in another dimension and belong to supersensitive perception, which trains and points and which was opened by Your friends. We can say that the person perceives (this term is better suited, not to be confused with physical vision) aura of another person by means of its aura. The high-frequency part of the aura and auric colors are seen not so much how I feel, discern, someone even nihayda and heard...depending on the dominant channel of perception. To interpret it in a visual channel and color or not, that's Your business, often interpretiruya, that is why I had the illusion that the aura is "colored spherical shell". Disadvantage of this interpretation is that it is possible to begin to imagine and to draw in my head images, not sverhcheloveka to develop. Still, the presence of physical sensations is a no criteria. People can't see aura colors, those that are not present in his aura. While you probably try to look and expect to see something that I saw in the picture or have painted yourself a picture in my head, like an aura "should" look like. For the initial stage of operation, the glasses suggest to start with 5-10 minutes of viewing the sky, other light sources, illuminated objects, landscapes on the window, etc. And Kilner to read. And don't expect something "special". Aura is still a breeze
The human brain is like a sponge, he needs to absorb a certain amount of experience, experience. Once a critical volume is reached, the result will be hopping. Moreover, according to statistics, most often the vision comes without glasses. Glasses are an exerciser, You're not looking at the aura through them, and through this ternura brain reaches a certain frequency it works, and it can manifest anytime. As well as the measurement of subtle energies are quite varied, the vision may be associated not only with an aura...a lot more than)<
