Novice Navigator
Re: Novice Navigator
Post by Андрей Патрушев » Fri Jan 10, 2014 17:05
Olegp
"A healthy head even analginum does not help"...
In my opinion, in the marathon for the exam the key is being able to quickly and fully relax. In this your daughter will help session "r" - relaxation, which is best done in the period from 16 to 18 hours. It is also important to gather and sit down for study - there will a session of "L" which Innerpulse well enough, and if necessary, additional (free) download on the website. All this can be done situationally.
Training mode - regular system classes require connection adaptive functions and the additional energy (except during a certain period, and frequency would be contrary to the actual objectives, preparation for exams), so at the crucial periods, it is better not to use (to start we had a year ago :?).
ОлегП
Post by ОлегП » Fri Jan 10, 2014 17:32
Andrei Patrushev
Thank you for your prompt response.
cibercop
Post by cibercop » Wed Jan 29, 2014 11:50
Please tell me. Version device 1.15M2, all sessions work fine, but the gate-record work only with headphones , glasses do not function. Those strobe-recordings (discs Patrushev) cat. was when buying the device, I have not changed anything - only hear the sound, flickering missing points, although I put different levels, etc. tried everything...
Post by Андрей Патрушев » Wed Jan 29, 2014 11:54
cibercop
You may not run them from there...
cibercop
Post by cibercop » Wed Jan 29, 2014 12:08
From the player ) Player - common - [ ] - strobe
Post by ЛИЛИЯ-Р » Wed Jan 29, 2014 13:31
cibercop
Go to the second window where the PLAYER , there's a line : regular ,synchrostart, strobe recording,svetanics, functions. It is in this window that the string in strobes is the conductor and other drives Andrew and noise . This work sunglasses and headphones.
Post by Андрей Патрушев » Wed Jan 29, 2014 13:32
cibercop
What are your settings strobe decoder?
In the last firmware, by the way, everything is automatically configured... :wink:
Post by ЛИЛИЯ-Р » Wed Jan 29, 2014 13:50
There is a feature in the device, if you listen to the underlying session from the first window, the color can be changed with the button with the square, there is a combination of colors, provided that the color is the color of the author. What am I... to the fact that in the gate, this function does not work if you click there to select the color, sunglasses just goes out. And to start the gate again, you have out and login again. Perhaps you have this situation? but this is only one suggestion.
cibercop
Post by cibercop » Wed Jan 29, 2014 15:11
no, in the "gate-entry-only" settings are set (for me anyway) playback does not start from there. Settings tried everything. And the button with the square (during playback)only the sound works, the color does nothing (only turns on and off upper led). ))) I'll try the new firmware put.
cibercop
Post by cibercop » Thu Jan 30, 2014 11:53
Reflash the device to version 1.6 , Everything works perfectly, except that it was before. Points on the gate zabici generally does not function. :roll: Don't know what to do... to return under warranty can be ?
МайндМашина
Post by МайндМашина » Thu Jan 30, 2014 15:04
Hello cibercop!
Let's try on the items to spread out the starting gate records.
1. Include Navigator.
2. Select the menu by clicking the arrow to the right "Player"
3. Go to the menu Player by clicking the play button "►"
4. Check the settings of the 5th paragraph "Function", E|C|50, if necessary, corrected.
5. Select "Strobe recording wav"
6. Put "[Color] occasionally." by switching the arrows left and right, "[Gate] Chords", or at Your discretion
7. Next, press the "►"
8. Select the gate entry from the folder "VOYAGE", "PDOVOD", "HEALING", "ENDORPHI", etc.
9. Suppose we choose the folder "HEALING" (Healing through the magical river, A. Patrushev©) by arrows "↓down ↑up", push the play button "►"
10. drop the cursor on the file "HEALIN~1.WAV" and press the play button "►"
After all these procedures in the headphones will have the sound recordings and in glasses in a few seconds, flickering light.
Adjusts the brightness of the light in the glasses and earpiece volume, made the relevant buttons right below the display of the Navigator.
The display will show an information window and the scale of the selected gate record.
At the top of the display "Player / Decoder [■]". It is the icon "[■]" means that the function strobe signal is present and recognized by the Navigator while listening to the audio file.
Respectively glasses should flicker. If the black box "[■]" absent "[ ]" this means that the audio recording has no special strobe signal, and accordingly the glasses flicker should not.
If You have all these steps done correctly and the proper result was not achieved, then we are waiting for You in our office with the unit and warranty card, weekdays, from 10:00 to 18:00!
cibercop
Post by cibercop » Thu Jan 30, 2014 15:58
:) my head is aspen... but you did and it worked! Thank you!
-Илья-
Post by -Илья- » Fri Mar 28, 2014 16:40
Tell me where is a description of the sessions, fun, morning, mindheal, ro1n, violet?
Post by ЛИЛИЯ-Р » Fri Mar 28, 2014 16:45
-Илья- wrote:Tell me where is a description of the sessions, fun, morning, mindheal, ro1n, violet?
A description of these sessions in the instructions to the Navigator ,the table base sessions.
-Илья-
Post by -Илья- » Fri Mar 28, 2014 17:13
Thank you all found besides fun, what is this session? And it is not clear why they are separate from the base sessions?
Post by ЛИЛИЯ-Р » Fri Mar 28, 2014 17:29
-Илья- wrote:Thank you all found besides fun, what is this session? And it is not clear why they are separate from the base sessions?
Alex wrote somewhere in the topics on the Navigator that was a test firmware 1.16 it was a folder in the library separately for any of its purposes, just do not remember. The new firmware 1.16 there are no such folders in the library. Sessions are the basic sessions , the rest of the folders from the library in a second window .
-Илья-
Post by -Илья- » Fri Mar 28, 2014 17:32
ЛИЛИЯ-Р wrote:Alex wrote somewhere in the topics on the Navigator that was a test firmware 1.16 it was a folder in the library separately for any of its purposes, just do not remember. The new firmware 1.16 there are no such folders in the library. Sessions are the basic sessions , the rest of the folders from the library in a second window .
It is now clear :ay
Алексей Крячко__
Post by Алексей Крячко__ » Mon Mar 31, 2014 2:34
these sessions in General and not intended for training, but rather to check the operation of the device and demonstration in different modes. Therefore no descriptions, and some type r01n are out of date or contain errors. Working sessions for those that are in the base folder of the sessions (if you have it recorded on the memory card, if not from the site you can download them).
Гарет
Post by Гарет » Mon Jul 07, 2014 21:18
Hello!
Andrewif you can begin work with "Navigator" with Your Explorer? I want to read books and the forum (so to speak scout the area) before start of the alpha, beta, etc. "Conductor" as a unified program of instruction that is important for a beginner.
Today attended 2 sessions (introductory and alpha), normal flight.
Post by Андрей Патрушев » Mon Jul 07, 2014 21:19
Gareth
Hello.
Need. :)
Гарет
Post by Гарет » Mon Jul 07, 2014 22:06
Great.
Did I understand correctly, you need to first listen to the recording in awake and comprehend content?
The use of glasses while listening to this program, give any effect?
Passing this program if I can in the morning to listen to something to raise the tone and/or anything after exercise?
Post by Андрей Патрушев » Mon Jul 07, 2014 23:07
Gareth
Yes, the manual says so. :wink:
Toning - 2nd track Star Wanderer, after physical activity is the 4th track Star Wanderer.
Гарет
Post by Гарет » Mon Jul 07, 2014 23:41
Andrei Patrushev
Thank you.
If I am not mistaken, the Traveler must be purchased separately, can it be done electronically?
And what about the use of points in a Conductor?
Гарет
Post by Гарет » Tue Jul 08, 2014 0:00
Hmm.. when you run the file from the folder strobe error: "invalid file type" :shock:
Post by ЛИЛИЯ-Р » Tue Jul 08, 2014 12:08
Гарет wrote:Hmm.. when you run the file from the folder strobe error: "invalid file type" :shock:
This folder to store the files, playback of folders gate-the entry in the second box , 3 string.
