Water purifier "BSL-MED-1"
vagavita, podckajite whether it is possible for example in the evening, pour water, leave for night to become room temperature and the next morning to carry out the cleaning process? I.e. can I leave the water in the device for a long time
Re: water Purifier "BSL-MED-1"
CanТяфа wrote:vagavita, podckajite whether it is possible for example in the evening, pour water, leave for night to become room temperature and the next morning to carry out the cleaning process? I.e. can I leave the water in the device for a long time
Vagavita, tell me, please, why the phones of the organization, BSL-MED, is not working.
From the site http://www.bsl-medreka.ru/pages/
Do you have them? Can't get neither to them nor to the representative.
About them can listen to the interview of potentialites Gorshkov A. S. on the bottom of the heads. page of the website www.bsl-med.ru interview on counterfeiting. It is now a matter for the FAS Peter goes plus arbitration.Терве wrote:Vagavita, tell me, please, why the phones of the organization, BSL-MED, is not working.
vagavitaI have a question for you.
The electrodes are covered with a layer of plaque. I removed not only the Central electrode, but also to promote the nuts, the entire system of electrodes. All cleaned and washed, put it back. Now found that BSL works, not like before, the sediment layer on the surface was much less. Water on the terminals of the electrodes seeps into the body, where there is food. Spacers do not hold. What to do in this situation?
This same problem was, only I have the water flowed immediately. Called factory, they said that this BSL from a defective batch, which is not the diameter of washers used(otherwise, everything is fully working). To determine from the batch of BSL or not, you can look at the mounted unit electrodes from the top, if this perspective on the left and right electrodes of the washers is not visible from the mean. Normal washers should be visible. We are talking about the washers that dress up for the screws of the electrodes and followed by a silicone gasket, and after installing the electrode Assembly into the container of the reactor, with the subsequent fastening of the nut.
I asked them to send the desired diameter washers and one gasket, in order to screw up was from the manufacturer. After installation came the West. parts problem has been fixed.
I have the water flowed immediately, and they found the nuts were not twisted
Similarly.Тяфа wrote:I Have water flowing immediately, and they found the nuts were not twisted
And there all to shoot you?Логик wrote:I removed not only the Central electrode, but also to promote the nuts, the entire system of electrodes.
Vagavita can clarify how to do thatЛогик wrote:on Monday, I will call the office where I got BSL.
Maybe I will explain, but maybe not
To remove all you can and in my opinion even necessary, since the side electrodes in a stationary position is not cleaned effectively(of course if you do not upoate on this activity). I.e. the number of cuttings with new electrodes and purified as described in the instructions in a way markedly different, I checked
and of course the water took one and the same. Design there are easy to laugh(usually, not hysterical), but as you can see the factory parts are sometimes limp. And the FIC with them! The main box itself made, but these minor design flaws in my opinion are not critical.
PS I wonder why this time the plant is called strip asked, and did not go to buy them from the plumbing. They're fashionable, some said that this rubber is used in some part of the Soviet gas mask, but I think it is not critical.
Removed only the anode. Cathodes never. If you need to clean, then carefully read the passport where it is written about a simple method of cleaning the electrodes. Pour hot water (enough 50-70 degrees) that only hid the electrodes and add the table. a spoonful of descaler for dummies or even better 2 table. tablespoons of citric acid. Leave for 3-4 hours. The cathodes will be like new. The anode need to remove and clean. Then first obtained, drain the water to remove any remaining acid. The way we have in office now is on sale spets. sponge for easy cleaning of the anode and brush for drills nylon for the same.
About leaks - no more of that, all devices from the manufacturer pass the hydrostatic tests. Large our apologies on this occasion. The manufacturer was inserted in full.
What about spacers under the cathodes - they are from the vacuum rubber, and if you turned the cathodes, it is necessary to put new. We have them in stock. So any problem will solve!!!
By the way, at the expense of the acid, could you tell me the bagel I put in kostryulku with water and acid, so very this water how often should be changed? Every time you pour a new one and add acid or once a week to change it?
Hmm, and here I took a set of spare electrodes, but pads wasn't there...
Белый Камень
On technology they are, after appropriate compression factor of losing elasticity and needs to change. Employee of the company course in counselling should be guided by technology, not flowing or not
The man himself may even leads to podmochat, his problems))
I do this plastic case don't like the idea of pouring hot water with descaler do not like even more
so and remove the electrodes. Though perhaps I am biased against the plastic as the material used in cooking.
Yesterday cleaned a pineapple! Shine!!!
It 1 time in a week, after boiling the filter.водавита wrote:by the Way, at the expense of the acid, could you tell me the bagel I put in kostryulku with water and acid, so very this water how often should be changed? Every time you pour a new one and add acid or once a week to change it?
Thank you, I do, but doubts were
