New session for the Navigator
Session "Mind Healing 2" (MndHlng2.ses) - for the recovery of alpha activity in the brain after a traumatic brain injury and illness with a high fever.
Diffuse axonal injury (DAT).
Diffuse axonal injury is a common result of positive, negative, or rotational accelerations, often associated with road traffic accidents (RTA), or when playing sports. She also often accompanies contusions, during the fighting, and various diseases accompanied by extremely high temperatures (or prolonged exposure to subfebrile temperature).
This injury is called diffuse because unlike some other brain injuries, with a clear localization, it is common in a large volume of the brain in the form of numerous microscopic breaks of the substance of the brain, which interferes with the normal patency of nerve impulses.
In the US, per year, given different traumatic brain injury (TBI) approximately 1.6 million people. Of these, 50,000 people die a year later, 125000 become more viable. A study of more than 300 anamnesis it was established that the basis of many neuropsychiatric diseases also have different effects DATES.
As a result of DATE is often a suppression of, or a significant weakening of the alpha rhythm, leading to depression and chronic anxiety, sleep disturbances, and cognitive dysfunction (memory, attention, analysis and synthesis), and, oddly enough, was anorexic.
To restore the alpha activity of the brain clinicians have undertaken numerous attempts to apply ABC. Unfortunately, the presence of DATES, the usual adjustment of the brain, the frequency of flashes in the range of the alpha rhythm, does not occur.
This bleak situation persisted until, until Dave Seiver nor developed a method of audiovisual stimulation when the left field of vision (right hemisphere) is stimulated with a frequency twice lower than the right. It has enabled people suffering from various consequences of DATES greatly improve the quality of life by the end of the first week of regular classes for the AVS session created by the method of Dave Savera.
Thus, if you have the following symptoms:
— you always fall asleep when using beta sessions (category "E");
— you have a diagnosis of add or ADHD;
— you have anorexia;
— you quickly get tired at the slightest effort;
— you regularly run into furniture and other people;
— you regularly drop things from his hands;
— after the incident (head injury, accident, illness with high fever) had problems with reading and clear expression of ideas in communication;
— after the incident (head injury, accident, illness with high fever) had problems with memory and attention, learning something new;
then you have every reason to work with session "Mind Healing 2" (MndHlng2.ses).
Standard rules:
— not more often 2 times a day, with a break of not less than 3 hours;
— not less than every two days;
— not later than 4 hours before a night's sleep;
it is advisable to drink a glass (at least half) of pure water before and after the session;
— DATES — "serious thing", so the cycles optimally choose the following: 15 15 and so on, up to 3 months.
In this case, we are not talking about treatment, and rehabilitation after DATES.
note: Disc "Healing 2" for this session has nothing to do. This session is similar to a CD "Brain Massage 2"
Download: "Mind Healing 2" (MndHlng2.ses)<
Standard rules:
- Максим Данилушкин
- Has thanked: 18 times
- Been thanked: 2 times
Re: New session for the Navigator
Andrey Vadimovich, peace be with You, this session is placed in the folder "special", right?
Maxim Danilushkin
And You do not fall ill.
They can go only if You remember where it is.
Andrew please tell me the CD "Brain Massage 2" and the session "Mind Healing 2" video for the same purpose, based on the description.
For those who have GPS, does it make sense to take the course "Massage of the Brain 2" without the Navigator or the Navigator or "Mind Healing 2" on the Navigator will be all the same?
viewtopic.php?f=8&t=6474 "The program lasts 27 minutes.митек wrote:For those who have GPS, does it make sense to take the course "Massage of the Brain 2" without the Navigator or the Navigator or "Mind Healing 2" on the Navigator will be all the same?
Format: wav.
Audiostrobe (for mind machines) is no.
You can listen to on any device (player, computer, tablet)."
MiTek
With the Navigator (not a disk, and session) two times-four more effective (due to light).
Andrew please tell me, is there any need/sense for the course of the session, Mind Healing 2 on the Navigator, go to first alpha course sessions?
I'm finishing the second course of treatment/conditioner and I read somewhere that it is commensurate with the course alpha to mindmachine.
Still mindmachine I have not used.
Does it make sense to start with the session until it's done healing/conductor or in parallel?
Well, as they say, "haste is needed only when catching fleas," but, if you can not wait,митек wrote:does it make sense to start with the session until it's done healing/conductor or in parallel?
Listened to "Mind Healing 2" 3 times. While much noticed nothing.
Andrey, tell me, I was thinking, but if a person has no DAT, specifically, no such diagnosis is not put,
any recommendations then on a session?
As always listen to myself?
MiTek
The recommendations of the standard are spelled out in the regulations (see above). The differences for DATES - only long-term (up to 3 months) timing of application.
I wonder what You wanted to see two times?Listened to "Mind Healing 2" 3 times. While much noticed nothing.
Nothing certainly did not expectАндрей Патрушев wrote:MiTek
The recommendations of the standard are spelled out in the regulations (see above). The differences for DATES - only long-term (up to 3 months) timing of application.I wonder what You wanted to see two times?Listened to "Mind Healing 2" 3 times. While much noticed nothing.
MiTek
Turn headphones.
Turn headphones.
MiTek
Sorry, misspoke. Switch to the Navigator settings: Settings/Session + audio mode from right-handed to left-handed.
So then listen to this session or always feel to change back?Андрей Патрушев wrote:MiTek
Andrew please tell me, "Mind Healing 2" as I understand it is the drive "a Massage of the Brain 2". How this session applies to "Massage Brain" (the earlier version)? They model?
No, it is not necessary to change. The depressed should not be, Vice versa, euphoric effect that is not worse than that of the Endorphins. Depressed can only in one case to appear - when the hemisphere is inverted (well, even if the "hardware" channels reversed, which is unlikely).митек wrote:So then listen to this session or always feel to change back?
You are absolutely right.митек wrote:Andrew, please tell me, "Mind Healing 2" as I understand it is the drive "a Massage of the Brain 2".
They have the General direction of the rehabilitation.митек wrote:And how this session applies to "Massage Brain" (the earlier version)?
What do you mean?митек wrote:They model?
MiTek
No, MM2 is more directed at the mental functions. It is rather superior Starfighter (Star Wanderer).
Andrew, I listened to this morning MH2 as "Lefty".
Covered now alarm. Relaxation was perhaps stronger than usual. I'm still long in this relaxed state came.
And the excitement and fears all amplified. Trying to understand that fear, but never understood. Fear that something is coming. Not exactly. Then fell asleep and it was scary then. Yes, so sleep was terrible. Woke up in a cold sweat. Now everything is shaking inside. This happened with a guide. But now the feelings are stronger.
All it should be? Or maybe I'm still right-handed?
By the way, does the ratio of the reverse sides of the brain to which hand I leading or not?
I.e. MH2 in Pathfinder this is even more amplified Starfighter?Андрей Патрушев wrote:MiTek
Well, from the point of view of neurophysiology is a more appropriate response to the program than depression.митек wrote:All it should be? Or maybe I'm still right-handed?
Use the method of EFT with specific manifestations in the body of this condition (while breathing deeply and evenly is very important). From the point of view of the physiological manifestations of fear, for example, delight produce the same changes in the nervous and endocrine systems, so you can simply change a "plate" and enjoy the release of endorphins.
In some way, so. Only session missing high frequency working by themselves, so to compare is not correct.митек wrote:i.e. MH2 in Pathfinder this is even more amplified Starfighter?
http://www.koob.ru/xannaford/dominantaby the Way, does the ratio of the reverse sides of the brain to which hand I leading or not?
