Neuro-programmer 3
Валерий Николаевич
Alas, but under Win XP on this netbook (Packard Bell dot SE) visualization doesn't work! The screen resolution is changed, the refresh rate is not adjustable (60 Hz). Video driver Manager, not signaling, not the
. Don't see WHY not imaging????
Дмитрий Никитин
- Has thanked: 10 times
- Been thanked: 10 times
Re: Neuro-programmer 3
Hello! Is it possible to neuroprogrammer record afirmatsii immediately to the left and right channel as Andrei Patrushev in Explorer?
Yes, on the page of affirmations there are checkboxes for the posted play - can be put in parallel in the left and right ear. And you can even add a third on top of them in both ears at once.
K-13
I humbly request video tutorial for the "dummies" for NP3
it is possible that this great work of esche anyone (well except me) useful )))
Дмитрий Никитин
Hello! Whether modulation fixated afirmatsii? If so, the modulation off? I need to make afirmatsii remained unchanged. Is this possible?
Yes. The modulation frequency is synchronized with the frequency at the time of playback.Дмитрий Никитин wrote:whether modulation fixated afirmatsii?
Just don't turn on the modulation.Дмитрий Никитин wrote:If so, the modulation off? I need to make afirmatsii remained unchanged. Is this possible?
I have the feeling that I wasted a week of personal time to the translation of the user only in order to confidently answer the questions unwilling to read it.
Александр Фавинк
I bought the NP3 but set installed, but not started. Error NP5. What to do ?
Александр Фавинк
So all the same who knows how to fix the problem --- bought the NP3 installed , but during sapsa failure and writes an error NP5 (twice), and then flies from the program
( Can someone tell me how to fix it (fix it). After all, there is the key, but the program never even asks !
The details is not enough.
What kind of system is that it is all of the developer tools as a set.
On the forum about this mistake of a word, letters from the developers to wait long.
Key program had to ask after the kernel is started.
Got a response from Transparent, they are very sorry that You faced such a problem and assured me that he will definitely take care of her.
Until advised two things:
- The user must login to the system as administrator, otherwise the program will not start. Log in as administrator or run the program as administrator via context menu.
If that's not the problem, try the following:
1) restart the computer after the unsuccessful launch of the program.
2) download and use this program: http://www.transparentcorp.com/downloads/ClearCache.exe
3) restart your computer again
4) try to run the program again
Hope this will help, but if You have any problems or questions, just let me know.
Александр Фавинк
Tried to 4 points of your Board ... ( not helped. But the error LP5 CBO already does not give, writes requierd .Net framework, although the frame Werk on the beech the latest version 4.5.1. I have Windows 8, respectively 64-bit, that something (is to demolish the system on XP 32-bit) ???
Дима Никитин
Hello. For Mind work station has the ability to record afirmatii and handle them? If Yes , in what page can it be done?
Hello!
Noticed that in most ready-made sessions in NP3 use of isochoric tones. That is, the creators consider them more effective than binaural beats? If I don't know what works on me better ... Can I use stimulation isochoric tones and binaural beats at the same time in one session ?
Isochoric tones work without headphones. Or in one earphone. Or two, but different stimulation frequency (at each ear and, consequently, the hemisphere of the brain separately). Any sound-reproducing equipment. That is, they are just more versatile.
For BB you need good stereo separation, including spatial, but according to some researchers they are more effective.
Most often they are used simultaneously.
Thanks for the replyк-13 wrote:Isochoric tones work without headphones. Or in one earphone. Or two, but different stimulation frequency (at each ear and, consequently, the hemisphere of the brain separately). Any sound-reproducing equipment. That is, they are just more versatile.
And here's another interesting... of Affirmatsii you can record your voice makes sense to insert in all types of sessions (alpha, beta, gamma, etc.) or only those which cause relaxation, loss of consciousness, etc. - low alpha, theta, Delta ? And what should be the volume settings on the basic sounds ? So what would they do deliberately was not heard or that would barely ?
Everyone works in different ways. It is better to try this way and that - to choose how best to continue to use the selected option.котэ wrote:And what should be the volume settings on the basic sounds ? So what would they do deliberately was not heard or that would barely ?
In the sessions on relaxation of the phrases used to improve the status and secure the installations as self-hypnosis and self-programming.котэ wrote:And here's another interesting... of Affirmatsii you can record your voice makes sense to insert in all types of sessions (alpha, beta, gamma, etc.) or only those which cause relaxation, loss of consciousness, etc. - low alpha, theta, Delta ?
In the "fast" sessions, the phrase is best used only as a reminder of goals and notifications about the transition to another mode.
Among the many ready-made sessions in this program there is a session called gamma mood elevator in which there is a Gradual increase in frequency from alpha to gamma and subsequent maintenance of the latter. So here I am during this session been able to sleep although I understand she needs to have a stimulating effect on the na. Is this normal ?
Yes, about the fact that we must start with alpha I read, but I thought that there was a view that it is not necessary to first lower the frequency (Delta, theta) , and it appears that boost is also not recommended ? Long have the alpha to train ?к-13 wrote:This is a normal reaction of the untrained brain. To start you need to work with the alpha sessions.
And here's another... Until we use it only in the headphones That is, without visual stimulation and I'm thinking about purchasing the device for audio visual stimulation. I need to buy a mind machine as a whole (if so what kind of advise to work with NP3) or is it enough to only buy glasses with my headphones, software and a laptop replacement any MM?
Dear K13, please answer my question ☺.. I read the forum but still can not understand how nominal additional equipment suitable for this program. Will there be enough for me to buy glasses type photosonix color track or points easier and I have read about a decoder ... It is required ? Can't figure out what to buy that would not melt, and the main thing that worked well! Can't afford to throw $200+ down the drain ... please Help ☺
Dear Koteall the answers to Your questions on this forum probably 10 times, no less. I answer only questions that relate directly to program and problems with its use. For all other questions can answer a good half of the veterans of the forum (and a third beginners) - they are common to MM.котэ wrote:Dear K13, please answer my question ☺..
The cheapest Sirius or decoder of maynd-Explorer.котэ wrote:I read the forum but still can not understand how nominal additional equipment suitable for this program.
Of options better innerpulse - best option, a little expensive, but universal device, allowing to solve most of the problems in stimulation (about the Nova and the Navigator to tell e'm
From very cheap (self-made) - decoder for the lm555.
Free option: - screen visualization (the plugin can be downloaded from the developers site or run from a set of bonuses to the program upon purchase).
Is normal will not work.котэ wrote:Long should alpha practicing ?
Glasses without the mind-machine will not work. In older cars with glasses only the wiring and LEDs in the new microcontroller to decode the digital stream of color and frequency for multiple LEDs.котэ wrote:I need to buy a mind machine as a whole (if so what kind of advise to work with NP3) or is it enough to only buy glasses with my headphones, software and a laptop replacement any MM?
This can be done with any session? Alpha, beta, theta?- Editor sessions (can be trite to replace the background in any session on any file, song, nature sounds, the audio lectures...)
Any. It is possible and without an editor to make the basic version - using the properties of the sessions.Виктор... wrote:This can be done with any session? Alpha, beta, theta?- Editor sessions (can be trite to replace the background in any session on any file, song, nature sounds, the audio lectures...)
