Orgone generator with their hands (SP). The FLAME
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Mon Jun 14, 2010 14:51
And if you go during the full moon in the cemetery and collect there land and add to SP :)
And even better
The corner pharmacy is,purum-PUM-PUM,
There sits an old man,purum-PUM-PUM,
Knock him seven times,purum-PUM-PUM,
Stretch a sheet of paper and wait...
Drugs,drugs,will make it drugs,
In the mouth of your fucking will cure your attack,
And then the recipe is simple,write it small!
Frog legs,
heel old grandmother,
old Wallpaper,
grandfather's canoe,
truck bushings,
with bars, all the butts,
bow first-graders,
pigeons poop!!!
Here it is necessary to add drugs in SP and everything!
And you will have happiness!
And then candles, crosses, prayers, Holy water...
all this crap.
замечательный прохожий
Post by замечательный прохожий » Mon Jun 14, 2010 15:20
Логик wrote:Humpty Baltay, likes to kick idiots like you.
Post by Логик » Mon Jun 14, 2010 15:26
great passer,
you're still a parrot.Image
Post by замечательный прохожий » Mon Jun 14, 2010 15:28
Логик wrote:you're still a parrot.
Post by Логик » Mon Jun 14, 2010 15:30
sing, little bird!
Post by Guest » Mon Jun 14, 2010 15:30
Логик wrote:sing, bird!
Post by замечательный прохожий » Mon Jun 14, 2010 15:31
Post by замечательный прохожий » Mon Jun 14, 2010 15:35
Гость wrote:sing, bird!
Post by Логик » Mon Jun 14, 2010 15:38
And so often you go crazy?
Post by замечательный прохожий » Mon Jun 14, 2010 15:39
Логик wrote:so often you go crazy
Post by замечательный прохожий » Mon Jun 14, 2010 15:40
замечательный прохожий wrote:often
Post by замечательный прохожий » Mon Jun 14, 2010 15:41
замечательный прохожий wrote:are you so crazy
Анти3д
Post by Анти3д » Mon Jun 14, 2010 18:04
Th forum happened? :shock: Where is the seriousness :) :?
МерКаБа
Has thanked: 7 times
Been thanked: 25 times
Post by МерКаБа » Mon Jun 14, 2010 18:42
Let's not sasir@t theme.
By the way, Logan wrote that the addition of medications to orgonite, during manufacture of the generator contributed to the impact of drugs on people during switching on the device.
Post by замечательный прохожий » Mon Jun 14, 2010 21:22
:ay :ay :ay
Анти3д
Post by Анти3д » Tue Jun 15, 2010 14:58
Searched in Yandex: organic - weapons of the gods... Here's what I found: http://lib.rus.ec/b/197085/read :)
Been thanked: 182 times
Post by Андрей Кабанков » Tue Jun 15, 2010 15:15
Well,we moved,long study time).
Анти3д
Post by Анти3д » Tue Jun 15, 2010 15:20
Андрей Кабанков wrote:Well,we moved,long study time).
Study! :) :oops:
Анти3д
Post by Анти3д » Tue Jun 15, 2010 15:35
Шалтай Балтай wrote: here is a good instruction: http://www.whale.to/b/mobius_tut.html
Do everything on the site is well shown, however, a caveat is not out of my mind: in what direction is twisted wire with a drill (drill mode: tightening bolts /drills the hole or Vice versa) and 45% I do not understand :?
Анти3д
Post by Анти3д » Tue Jun 15, 2010 19:27
Do I understand correctly:
1. the density of the metal decreases from the bottom up: the density maximum at the bottom at the base of the SP, at least at the top where the epoxy ends.
2. the density of the metal increases as it approaches the crystal (to the middle): i.e. a minimum of metal in the outer boundary, the maximum of metal in the core (coil)
3. base, Foundation SP, - spiral, thick copper wire
+ангел
Post by +ангел » Wed Jun 16, 2010 14:47
Hi guys I suggest to pay attention to the quality of the manufactured instrument a few of my thoughts on these devices
the copper tape that you place around the crystal have on their edges to finish
sphere ( the secret is in these areas)and these areas should not be filled with epoxy resin and have to go outside and not be just chopped off the end of the copper wire and must contain strictly as many turns that you
seen in the photo that was posted Humpty-Baltay
and this time miss many builders spatial concentration
and we in the West
you use for the excitation flux coils Mobius
sources of digital signals which have a spectrum of harmonic and intermodulation distortion are not of natural character suggest the use of analog signal sources for example old analog tape recorders in which the recording is performed on a magnetic tape
and afemale cannot be used in selfish purposes
otherwise it can have no good consequences that we are already seeing the descriptions of those who use these devices
you better record on film a prayer for the good of all beings in all the worlds then feel
how changed the atmosphere around you
Post by Логик » Wed Jun 16, 2010 15:08
angel of light
You do what SP did? 8)
Анти3д
Post by Анти3д » Wed Jun 16, 2010 17:11
:D Yay! The crystals have arrived! Logic thank you!
When the crystals go?))) az
Has thanked: 125 times
Been thanked: 263 times
Post by Шалтай Балтай » Wed Jun 16, 2010 17:15
Логик wrote:2. how to find out, they increase the real output of orgone or not?
you amp has fastened, by the way?
plow?
Анти3д
Post by Анти3д » Wed Jun 16, 2010 17:29
Шалтай Балтай wrote:Welz have no crystals.
Read on one of the sites that crystal attracts positive life energy and rejects the negative. And organic attract any vitality, it makes no difference))
