Reviews about the effects of version 3.0
Post by Михаил_ » Sat Oct 23, 2010 21:14
In General, a few words about the products of different people.
I'm not only about their products, I generally about a variety of similar technologies.
Products may have a standardized due to the technology of production impacts.
In fact it often is. But why we get quite different effects sometimes?
here's an example:
http://openmagic.org/ph/showpost.php?p= ... stcount=69
and at the same time from the club of my forum(quoted anonymously because he did not ask permission of the author, and taken from a closed space, in principle the man there and then and for a long time):
"I don't understand. We all have something going on.
Wrote letters on БЖ2, waited 5 hours. Sitting with a bracelet that is already 3 hours and nothing."
later
"My wife gave a try. Says felt, but the effects were not observed. Slept with the bracelet. Wasps were weaker than usual, and in the morning not wanted to get up. Rather wanted to lie. "
and still later
"I started to act. Sparks from the hands went. 2 years already it was not them. "
and then
"Understood, what's wrong with dreams. I became a character in his dreams. Aware of myself, but seen from the outside. "
there were more, but a personal plan (from the same person), about the motivation, goals, emotional....
What am I?
When we work with ourselves and with the world, with information, unfortunately or fortunately, some clear analogies fits the computer theme.
If the computer is a program sensitive to the equipment, resources, installed drivers, in one case, it may work fine in the other - fail, the third very slow or not work correctly.
In the case of man all our experience,psychological state and health. These are the factors that affect the operation of the "new program". Of course there also should include an internal model of the world and nature, which greatly affects the performance of such things.
However, all this influence is only in the area shown factors (noticeable on feelings and events), any basis of that we can shoot at the same GDV - identical.
Yes, philosophy and epilogue.
I certainly understand that the range of prices from 0 to 100 for someone impressive, but fully functional version for 0, the line is justified. I found it absolutely not out of selfish motives. Over the last two days went 3pcs S++ (despite the fact that my working day is greatly higher "normalized"). For the meteorite, I are calculated with the owner of each bracelet. Links are ordered by the master - hand crafted. During this same time, I would have done 40 pieces 2.6 (for example) together with the coating. This lesson not only of those what I do, when passing a colleague in a more serial production the cost of time will remain proportionally the same.
Conclusions - for me it is more profitable to make some 2.6, no challenging questions than 3.0 S++ thing. By the way the same situation with all the bracelets series 2.x+ from larch, where the mass of time, manual labor and fuss with each link. Morally to do them is nice - I love things working is significantly more powerful and I like that someone will benefit. Ie there is an objective satisfaction made not as from a more "mass produced" things, but at the time - terribly expensive.
So don't think I sat down and for the sake of profits wrote a range of prices. All the "easy" profit goes to the products that can be made commercially and without manual labor, and it is just the least of the issues.
I think this question of high prices can be closed?<
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Sat Oct 23, 2010 22:17
Михаил_ wrote:Over the past two days went 3pcs S++
How much energy consumption increases the BJ action...
I walked up to 3.0 a little bit differently. Did not rash to draw a matrix on the bracelet (I admit, though not recklessly, but... isn 3.0 and now nothing to do:)the matrix can not be erased, simply "ingrained in the glass composition, but the effects... such shows watch:), so I think for good reason), so here's a bracelet, you first prepare yourself to manufacture 3.0 took at least an hour (MM ALTARIA, one of the disks of Andrey Patrushev, SP with a frequency of "ShamanicState") sank deep. Took a needle (after the smiled response to a comment about Mihaela a magnifying glass and a needle, everything was just so...) on BJ 2.0 caused (not simply applied, the matrix one took at least 20-30 minutes, some more, the tree resisted) 14 units 4 matrix svehu and bottom links, also on the reverse side. On the first day of "not mastered the half of it", although I had to sacrifice sleep, one link took about 2 hours. Put effects noticeable found. The evening repeated the training and continued again a sleepless night (good sources are "fed" at least sleep for 2 hours, not very noticeable), and then hand natrenirovannosti (although the index finger still has a "fixation" of this action) it went quickly, the morning finished with the thread. This time to wear the right did not, decided to continue charging, of course maybe what they were doing and more, but knew that only benefit so much effort and personal energy. Bracelet made with... piece of paper with the graphics of the matrix... the energy source of the plant world with printed matrix... a pair of amplifier Radionics setting up Trend "to highlight and convey the quality and pattern of the matrix"... SK+HF with the same job on paper, vampiresa transfer pair... and SP with the same transfer task with a "split crystal"... +the energy transfer from MS... here is such a compote. Made the bracelet with graphics matrix the transfers and is wrapped in aluminum foil, mandala noted "screen mode", repeated the second layer. This sandwich was placed on Skuce with the order of task shielding. Hours and all the appliances worked on this task. Decided to check the result of the feelings is really much work, moving all day from one extremity to the other immediately said "turning muscle", all of this has led to a "fully killed" in the evening (can mark the status as predcription, a drop of tea tree oil led me to order...). 3.0 Super-Lite said it took for the resource.
But the price, the price chosen by the manufacturer for reasons of his own, but... demand creates supply.
Sincerely, MAG.no<
рыжая
Has thanked: 34 times
Been thanked: 46 times
Post by рыжая » Sat Oct 23, 2010 22:42
MAG. no, I'm trying to find the appropriate words...
Well, actually, it's cool! :ay
Post by Маг.нет » Sat Oct 23, 2010 22:54
Михаил_ wrote:Just can't not to note the work done.
Thank you! Very grateful for the offer and for the 3.0. Also at the time of manufacture "decided the old problem", the output of 3.0 gave a result on the long-posed question.
Sincerely, MAG.no
рыжая
Post by рыжая » Sat Oct 23, 2010 23:11
Маг.нет wrote:
рыжая wrote:MAG. no, I'm trying to find the appropriate words...
This is the answer to Your question....
Sincerely, MAG.no
Hmmm, interesting happened. Congratulations. You have done work worthy of respect, at least.
оуаакун
Post by оуаакун » Sun Oct 24, 2010 1:57
Михаил_ wrote:but fully functional version for 0, the line is justified.
I need high frequency bracelet, which is unavailable to me. And full health 1.0 and 2.0, I have no doubt. Only RF there.
Михаил_ wrote:I Think this question of high prices can be closed?
Can. :)
Post by Михаил_ » Sun Oct 24, 2010 3:01
Can. :)
1. high frequency bangle is 2.8.
2. 3.0 out of doubt Vysokochistye bracelet, but he is also ... do not even know how to say something, say super-high frequency. The fact that he was speaking in one of the available systems of terms tends to place man in the bizarre position of the assemblage point, about what is happening that allows him to perceive and work with what is happening (the position not involved in the "game").
3. 3.0 Lite like available to all (I hope I won't regret this frivolity until at least it has generated far more positive than questions.
it can be used not only as an RF source, but as a serious coach of the right hemisphere. Check.
4. if we are talking about the unavailability of older versions 3.0 --- well, change something in life, either do it yourself based on what is already given. Many pieces of the light for example
5. if we are talking about unavailability 2.8.... I can't help you, but consider (or re-seen), that if something really need the money are in fact those abnormal ways (sometimes literally out of nowhere).
6. 2.8 and 3.0 are very different things.
7. in 1.0 and 2.0 RF IS. And proven practices. But only if You can out eat :) in other words, if the initial experience to pull yourself to the treble and there to keep independently obtained, then BJ 1.0 pull out of their channels you need energy.
It tested not only me many times.
On the practices.
8. since the receipt of the RF through, or receiving money from non-existent to today source it's all one thing - work on yourself and situations (that still work), then consider "my League" trying to be lazy a little.
9. do not believe that man can be something inaccessible that it can represent consciousness. Is that something unreasonable (the cost of time and effort is not justified) is the fact. Ie then I would say (correctly), "the acquisition of HF-version for me is not justified."<
оуаакун
Post by оуаакун » Sun Oct 24, 2010 3:48
Михаил_ wrote:3. 3.0 Lite like available to all (I hope I won't regret this frivolity until at least it has generated far more positive than questions.
Checked. 2 bracelet on tonight. Went cautiously, as the intoxication began. Got a little aggressive.
Then the little glitches started.:)
And the state like a dream.
It is now 3 hours, removed, and the condition still holds.
Михаил_ wrote:7. in 1.0 and 2.0 RF IS. And proven practices. But only if You can out "eat" in other words, if the initial experience to pull yourself to the treble and there to keep yourself received, BJ 1.0 pull out of their channels you need energy.
On the practices.
I need the bracelet pulled himself. Supposedly 3.0 L.
With 1.0 it doesn't work (turns a little, but I have powerful.)
Then I'll add bracelets 3.0 L gradually.
Дмитрий_999
Post by Дмитрий_999 » Sun Oct 24, 2010 11:56
Michael Hello! A number of questions.
Михаил_ wrote:2.8 and 3.0 are very different things.
On the other hand
Михаил_ wrote:3.0 undoubtedly Vysokochistye bracelet, but he is also ... do not even know how to say something, say super-high frequency
1.Does it make sense to obtain a quality experience to go from 2.8 to 3.0
2.What's the difference in 3.0 when you add a "meteor protomatter"
3.And what's the difference when adding "built-in power source extremely high power"
Post by Михаил_ » Sun Oct 24, 2010 12:32
1. no, it's a different experience. Or let's say, 2.8 can be avoided, in principle, it is not a problem. But the experience is different. As the view from inside and from outside-will always be a different picture.
2. there is a pure "tuning fork" that enhances the effectiveness of the bracelet, see the story about the rainbow.
3. in fact, this right cannot be worn. Seriously. Ie at least some time training with a couple of Lite version homemade. The real difference is that when working with the processes will be more efficient, because You can "jump" a bit higher.
Actually I replaced Basil S NV S++ and for him it was quite a shock, although it's got used for a few days. I think experimenting for yourself is possible, but just to put on SE++ is not necessary.
Well, another difference with this version is that it now is not available. I think it will to equip the production cycle earlier than a month shorter for the new year will probably.
Дмитрий_999
Post by Дмитрий_999 » Sun Oct 24, 2010 17:12
Михаил_ wrote:see the story about the rainbow
Where to look however , not realized.
Post by Михаил_ » Sun Oct 24, 2010 18:12
um.... this is my paragraff, it is really no, sorry... I guess now I have to publish it here, I'm in the club have to describe myself, please forgive me, here they are negative effects from 3.0 :) I got the impression that if the story is written somewhere, then this is enough (it already is)... is still need a reference and in this case it is also necessary to copy, as the link will not open.
A second.
Post by Михаил_ » Sun Oct 24, 2010 18:22
in General, the story concerns not obsessive desires have no anchor for our attention. Ie those that we in fact "do not care" and we do not expect that they Oplotnica (well for example because it is not realistic at this point in time), think about the shift of this kind in his order wrote Dimas?
Although it's as always subjective....
the story is this:
there is one relative, sometimes Kuraray for me(a student), wanted his neck a piece of meteorite.... well, I explained to him that in the first place - bummer, and secondly - it crumbles easily and makes no sense - it will fall off and so on.
As a result, he succeeded to the link from S++. Well, with flooded piece in the link. (it loaded of course he went and engraved.... just had one with the marriage of wood, on which I trained.
In General, while I chatted with him, told him stories slightly rock the picture of the world in terms of stability, chatted about all and Sundry and the impact of words on what is happening. For example how the kids next to us gave her friend on your birthday "rainbow"(the girl came, said, "I give you a rainbow" a rainbow then and there...) on a clear day. Parents poulybalsya, then took 2 minutes, the rain and came out in the sky a lot of rainbows at the same time.
In General, how it ended....
yesterday, resorted to me at night - "are you sssso mayyyy made?!". -"???"
He remembered glauci the evening with the dog the story about the rainbow and thought "that would be a rainbow to see, but today probably will not work, it's dark".... and saw.... night rainbow around the moon halo. A neighbor also saw - I was very surprised... very....
two minutes say hung.
PS the bracelets he wears - he fears them, the artifacts do not believe and all that....
as I understand it until he himself can understand how he relates the incident to score and be considered a coincidence, believe and count for a good development of events or to try to forget and to get rid of such manifestations in their lives, i.e. to make possible that more occurred. Ie he is both kind and funny and ... scary... and at the same time want to go back to a stable and just world where these jokes didn't happen....
Yes... and talking about rainbows, too, began out of nowhere - it before it started having weird dreams and very vivid. Well, apparently he caught something of what he was carrying or spit in his hands earlier..... here is a subconscious of it and began to push strongly to have a link.<
Дмитрий_999
Post by Дмитрий_999 » Sun Oct 24, 2010 18:41
Michael, and yet, if of course not a secret – what is the "built-in energy source extremely high power" in SE++ - interesting..
Олег27
Post by Олег27 » Sun Oct 24, 2010 18:59
Метхуселах wrote:Michael, and yet, if of course not a secret – what is the "built-in energy source extremely high power" in SE++ - interesting..
Join the question and what is the difference with S++?
Дмитрий_999
Post by Дмитрий_999 » Sun Oct 24, 2010 20:08
The description says
SE+ This is the high tech version
And You already write
SE++
It is already a better option? Or a typo?
Мистраль
Post by Мистраль » Sun Oct 24, 2010 20:41
Hello MAG.no.You wrote that struck the matrix 3.0 Sri-1 and got something spectacular!Could You describe the result?
Post by Маг.нет » Sun Oct 24, 2010 21:35
Мистраль wrote:caused matrix 3.0 Sri-1 and got something spectacular!
It's hard to argue that it is only by these institutions could cause "explosive" situations, maybe I'm-3.0 as it was involved, but immediately (within 30 minutes after application matrix 3.0) began to happen lightning-fast events that can be called "emotional outburst" in the environment, at the same time I absolutely is not concerned, I only watched, but in an interesting state, as a "movie":), popcorn and coke just not enough:). There were several instances of scandals in my (and isn) presence, and so extraordinary that earlier this was not observed, participants in the scandals have very good relations, some of friendly and is currently not allowed in relation to each other. Notably, several scandals of various lengths, explosive character between different people by the end of the day, all the incidents have been exhausted, all participants on the following day fell in with the "unusual flu", the temperature of 38-39, aching bones breaking muscle, reminiscent of old injury pain, interestingly to "recovered," many do without medication and some procedures. Funny flu. There is a silver lining. In the process of the scandals were allowed many years of both personal and working problems of the participants, the situations were only the catalysts for the processes. While ISS's left on in the workplace, see...
Sincerely, MAG.no
Post by Михаил_ » Sun Oct 24, 2010 23:33
a secret, a secret... a terrible secret :)
and the difference here is how time in it, actually, to be precise, in the material. SE+will be of the specific alloy with special coatings.
And source.... well, let's say. Welz read? on the topic of antientropy or whatever it is called? think it was discussed once on the forum.
In General, if a certain ...thing to satisfy a certain energy to a certain value, its natural dispersion will be less than the capacity of influx and it (the object) will not lose the most "charge". Like eternal batteries.
Actually while we are talking about an open system, i.e. on the external inflow of energy resonance. Although depending on what frame of reference to look (or what model).
So any energy-active object can be "eaten" if it feels greater its ability to self-support. I.e. a lot at once. All BJ have the protection and regeneration of such cases. However, here we are talking about something else. We are talking about what the bracelet will have prezerakou, namely in the sense of artificial saturation energy of the same quality as all 3.0, but to such a high level that "prozhirat" it will be unrealistic. Ie, very highly charged subject, any consumption will regenerate itself. Using a special composition, a special method of saturation and a special way to "return" to the operator.
АК
Post by АК » Mon Oct 25, 2010 0:08
Вадим Перелыгин wrote:
АК wrote:Well, that is, if I understand correctly, You believe that You and the other elementary deceiving, exploiting the naivety and gullibility?
Well, what could be clearer! I honestly expressed my feeling! It can't be slander (false statement), because it is my personal feeling!
It may not be "nonsense" (according to Mikhail), because I'm healthy.
I'm not trying to manipulate the audience, but I think a lot of people have similar feelings.
And I don't know why about Michael and his products can only write good or no!
It's pure totalitarianism in its worst form, when even you can feel just how nice Misha or "in bed!" It is sad to be cowardly, a spiritual slave! :(
Vadim, thanks for the explanation. I personally have positive experience with BJ.
Well, different people - different experience, what else to say.
And about totalitarianism... In my opinion is the right of Michael to set the format of the discussion in "their" topics. Anything bad do not see this.
On the other hand, as I understand it, nobody will prevent to open a topic in "Talk about everything" with a critical discussion of BJ or any other products. This topic is for svoym even something interesting.
Илюшик
Post by Илюшик » Mon Oct 25, 2010 0:19
Strange somehow.:? In my opinion all devices and not only this site "work", only designed for different users, on taste and color as they say. Well that Russian German death etc. :) The point of fooling users?) For the sake of profit? And what about karma? :)))
рыжая
Post by рыжая » Mon Oct 25, 2010 0:20
Eh, people do not believe, I do believe. Here with me today a funny thing happened, well I PM is I will not write, for one simple reason, that happens to me is my truth and I see no reason to be ashamed of. :)
And another story on the subject of bracelets. Those who do not believe can not read.
Go to work today. Before it looked on a bracelet 3.0 that are not worn two days and said to wear, not to wear. Let me explain, the first few days socks bracelet 3.0 among other things, were associated with the influx of jobs. Wore, I had on two things, charged as 1.0. Sitting at the bus stop, not bothering anyone. Slow car in front of me, there sits a man, and something wants from me. I sit, clap eyelashes. And then jumps in front of me, literally me, completely obscuring some grandfather and this man: You said that it should, now your room will write. And first him: Not understand that she's your daughter? I'm interested in it. First left, second barely had time to say thank you, jumped on the bus and drove off. Given the situation that the person can be beaten in broad daylight and no one will stop...let's just Say, I regard it as the protection, of the slightest potential danger. Nice.... :)
Новик
Post by Новик » Mon Oct 25, 2010 0:32
red
It is right :)
I have a similar story... only then it was 3 nights and I met 3 "Gopnik" 8)
Post by Михаил_ » Mon Oct 25, 2010 0:41
To beat? person? in бж3.0? to do this, he must subconsciously want it ... :) or fear it as a possible scenario...
But what really happens? well, what morals....
рыжая
Post by рыжая » Mon Oct 25, 2010 0:44
Новик wrote: I have a similar story... only then it was 3 nights and I met 3 "Gopnik" 8)
Yes, but I see here a connection with the bracelet. :) And you, what happened?
