Audio for IC.
м-р Фримэн
Post by м-р Фримэн » Sun Nov 21, 2010 18:41
1. 1. Michael, is there any audio command to bind the device to the host?
2. If not then how to do it is to take an instrument in hand and say that I am now your master?
3. How long do I need to turn tracks with commands for that device moved in the desired mode, for example cleaning the room or some other?
4. And how then to return to its original position?
5. By the way, and what it's original position, i.e. in which mode is the device in the sale – purchase?
6. When using the demo tracks they need to scroll to obtain the effect, or just once, and then wait for their attack?
7. What gives scrolling through SK of Petrushevskaja "conductor" compared to the usual listening through headphones and, what is the best option to start using this drive?
8. How much time is required for cleaning the premises, say 10m2?
9. Is it possible to clean a 3-room apartment, holding a device in one room or better each room separately?
10. I do not quite understand what track you run to transfer IC to mode purposes, let's say I have a goal recorded on paper and audio, I can have them to let immediately on a device or I need to run one of the commands of the 1st paragraph?
11. If I understand correctly the commands of item 2 "Management of probabilities" i.e. the tracks is necessary when it is already clear a event course of development, which need to either energise or de-energize?
12. And that's what the "activate processes in the current probability of not changing route" is not quite understand?
13. Still very tight is inserted and pulled out from a minijack connector, and for the first time do not put, thought that is defective (I'm usually lucky), until he used force, is this normal?
I apologize for the abundance of questions, just one thing, when this study without the device detached, so to speak, and another when he showed up and lies beside him, and it is necessary to master. Here and sketched what came to mind, before I forget, also a piece of paper laid with the aim to study the device and learn it properly, and harmoniously to use... :oops:<
Post by Михаил_ » Sun Nov 21, 2010 20:08
1. not needed. The instrument it defines itself quietly, and as noted, usually before physical contact with hands. There were many specific cases, very clearly showing. Ie You bought it - You and the owner. If someone will lend stipulate when it will end temporary use. Just mentally.
2. Yes, the stage of the attunement is to be held in any way useful, just to sit 5-10 minutes with the device in two hands.
3. enough the 1st time, but to be effective such as cleaning, would be better if the track will work during the whole time of cleaning.
4. he will return at the end of the work.
5. starting position - symbiosis with the BJ and hearing the commands of the owner. + work on the last task, if not ended.
6. and so and so. many times more efficient a little.
7. better with the normal audio option if you have never used. In the UK it will work in the background and a little different, something stronger, something weaker.
8. depends on what is there before this room is "contaminated". Some of the rooms and so clean, some week will not help. If their own feelings on this point, I'd leave for two days.
9. better than each separately.
10.enough to put a piece of paper on the object table.
11. Yes, that's right.
12. this means that the processes will come more energy, but the route will not change.
13. unfortunately, now almost everything is made in China... other connectors do not sell, in the future we will give it more attention. But the problem in this.
м-р Фримэн
Post by м-р Фримэн » Sun Nov 21, 2010 20:39
Михаил_ wrote:10.enough to put a piece of paper on the object table.
Why is the command of the 1st paragraph?
Михаил_ wrote:12. this means that the processes will come more energy, but the route will not change.
Something still does not get it... i.e. you want that, events developed so-and-so and such-and-such direction and add energy to this event probability, making it impossible to take the alternative route, so what?
And than then it will differ from the team: "to supply power to the desired (chosen) positive probability, giving her energopodachi"? Maybe some example?
:oops:
Михаил_ wrote:13. unfortunately, now almost everything is made in China... other connectors do not sell, in the future we will give it more attention. But the problem in this.
Well it seems to work, heard played quietly through it, and in case of failure of the connector it will be possible to replace?
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Mon Nov 22, 2010 9:50
Opinion SK:
1. Team 1 point - for a more thorough wording details the intentions;
2. There are event probability, but it is dependent on the associated probabilities (e.g. "the imminent onset of winter in my region" depends on (is connected): by lowering air temperature, snowfall, etc.), so when activated, the "current processes" is supplied not so very probable, how much current (related) processes.
3. Audio is likely to replace hard, it is filled, but... don't always have to do this, the instrument will work correctly even if the audio just "in the zone" device (or in the ears, when working with the device in direct contact in Operator mode) to turn, of course, "silent running" from the UK will be heard, but not the point...
Sincerely, MAG.no
м-р Фримэн
Post by м-р Фримэн » Mon Nov 22, 2010 12:44
Thank You, MAG.no! Gradually clear up.
Маг.нет wrote:1. Team 1 point - for a more thorough wording details the intentions;
And that means a more careful formulation, i.e. these commands during playback help for yourself to formulate a precise and detailed goal? In other words, to understand what I really want?
Маг.нет wrote:device will work correctly even if the audio just "in the area of the device"
Even so, you can also loop the purpose of the recorded audio and the effect on force is the same as using the connector?
Still hope that this will not happen...
Post by Маг.нет » Mon Nov 22, 2010 13:26
м-р Фримэн wrote:what does a more careful formulation, i.e. these commands during playback help for yourself to formulate a precise and detailed goal? In other words, to understand what I really want?
These programs record the "detail" - the tendency, the Aim (Object of change), etc. from common mental language.
м-р Фримэн wrote:Even so you can also loop the purpose of the recorded audio and the effect on force is the same as using the connector?
"Mental transaction" it is sometimes better electric when you work with SK, managing Operator often primary (higher priority) "external control" through the player, unless otherwise set by the Operator (Owner of SK).
Sincerely, MAG.no
Post by Маг.нет » Mon Nov 22, 2010 14:10
Маг.нет wrote:These programs record the "detail" - the tendency, the Aim (Object of change), etc. from common mental language.
For example, you can think about choosing the color of the car I want orange, not all the same white, now it's black... decided To make this thread to highlight the element of intent (in this example, the color of the car) and it is possible to draw audioobraschenie SK, for fixation of their choice.
I think a clear example.
Sincerely, MAG.no
м-р Фримэн
Post by м-р Фримэн » Tue Nov 23, 2010 11:58
Thanks again for the reply, already more clear, i.e. helps to determine in detail, in this example, with the color of the car... got to try...
тишина
Post by тишина » Thu Dec 02, 2010 0:36
sorry for the stupid question - without the use of IC is not clear (at the forum INF-tsii not be found) - if I understand correctly the audio is fed into the IC via the connector, i.e. turn on the player and the cord headphone connect with SK?? The sound will not be heard at all, Right?? You can also listen to tracks in your headphones, passing through SK through the audio output: same driver, and so on, you can listen to, reinforcing with SK!!? Please explain.
Post by Михаил_ » Thu Dec 02, 2010 0:47
audio is fed through the connector. The sound is not heard or is very quiet... Instead of the cord used for headphone cord minijack-minijack, one end of the SC, the other in the player.
You can listen to naolinco, but you will need a splitter for the two lines that the sound was simultaneously in the UK and headphones.
м-р Фримэн
Post by м-р Фримэн » Thu Dec 02, 2010 12:50
An interesting observation when scrolling through audio СК1м, scroll through a PDA HP2210 – old, but it works. When you scroll to the audio commands to work with the room (cleaning, harmonization) every 40-60 minutes falls error "playback impossible" or the slider stops somewhere in the 80% write, it's like someone hit the pause button, then have to close and run it again. Recorded on tape the wording on the goal, launched in the UK, work is already more stable only a few times, I've gotten a playback error with an interval of 3-4 hours, then a few days without any problems until yesterday evening decided to put your ear to the device. And there is my "mantra" of some kind of beeping pulled the wire from the CPC and stunned the record was played in fast mode and accelerated pretty well, even though there is no such feature, then had to unload from RAM, that would eliminate this effect ... :shock:
Look forward to Your reviews, Michael.
Post by Михаил_ » Thu Dec 02, 2010 14:19
Well, sometimes .... :) what I can comment on. Sometimes technology quickly reacts. By the way the acceleration records, some considered an effective technique, because of the difference of the frequencies of the chakras. Ie where recorded, and where the processed frequency we kind of like different.
the technique can affect many factors.
for example, in the case of cleaning the premises, those entities that do not want to clean.In the case of working with the target - the subconscious mind.
м-р Фримэн
Post by м-р Фримэн » Thu Dec 02, 2010 15:12
Михаил_ wrote:for example, in the case of cleaning the premises, those entities that do not want to clean.
About the cleaning I had such suspicions, of course for purity of experiment it is necessary to another source to connect to the laptop, for example, I will try... does the phenomenon of play, that the essence still holds? And accordingly, you need to twist the Shoe until won't leave a problem with the playback? Unfortunately, the issue of sensornet I do seal do not really feel cleansed or not... :oops:
Михаил_ wrote:by the Way the acceleration records, some considered an effective technique
I.e. if this happens again, you can not ignore and leave as is?
By the way somebody already complained about a similar phenomenon with the time on the devices, think, Mage.no... it Turns out the device changes over time? Great!
Post by Михаил_ » Thu Dec 02, 2010 20:38
1.in fact, on the stability of a player can influence a lot of reasons, but something in the apartment or house may come from the neighborhood. Our colleague has a house.... .where constantly arriving, that they don't do :) well, the place is just there.
So maybe just to repeat on a schedule (not continuously) and still rely on the feeling. There are those who do. Well, not touch-sensitive, normal - fatigue, the pleasure of being in the room and so on.
2. if you repeat, you can try to leave it as is.
By the way will be interesting, if you try to speed up the entry as well and will tell you what the acceleration was in this case. It is still a moot point (there are several options, including the slowdown, not acceleration).
м-р Фримэн
Post by м-р Фримэн » Fri Dec 03, 2010 13:36
Thank You, Michael!
I rely on the feeling, in the end need to have ever develop...
About recording, it still only shuts up from time to time, acceleration effects were no longer apparent, but the night is young. :wink: The speed will try to determine memory being played in aimpleer-e, if they the results necessarily accomplish your goal.
Post by Михаил_ » Fri Dec 03, 2010 15:03
About the speed - in the UK it's flowers. I have a brand new working phone and jumps on +-2-20 hours back and forth. Already, quite frankly, sucks. And Basil complains that he has similarly behaving watches Citizen, when dressing 3.0 S++ - error to a day or more, and come back..... I suspect that the phone - he is on the table and it's fine. I take him in hand and he blatantly, right in front of me, unrolling, for example, +2.... I yet S++
four S-Ki in the legs, arms... hands do not reach to do yourself, just once.
Now, it might be good, but I got absolutely. I still synchronized with the normal flow of time (at least a conscious perception and body I in the present tense). So these jumps are prevented. Or you're told not to use the watch at all...
Here I sit and think how to set the program on the stabilizer, which will smooth out this effect for phone and hours.
Роман Н
Post by Роман Н » Sun Dec 05, 2010 14:20
Yesterday I decided to clean the room.Downloaded audio in Winamp, set the "reverse" connected to СК1М and went to bed.Woke up in the morning,and the player loses.Trying to run still quiet,re-download the file too, does not respond and all the buttons in the player active.Rebooted and it all went!Here's a situation!We will be watching.
I still can't understand why the link device when playing some audio files if he is already logged on to the host? Or I something not understand?
And is it possible when scrolling certain files yourself, use the transfer couple?
Post by Маг.нет » Sun Dec 05, 2010 15:29
Роман Н wrote:I still can't understand why the link device when playing some audio files if he is already logged on to the host? Or I something not understand?
1. The target exposure to either the Operator (default) or link (for install).
2. Transfer-pair instrument of UNILATERAL transfer of energy. Transfer to transmitter "local energy vampire", transfer-receiver - localization of "campirano" energy. For example, if the source SK and Target Operator, the use of the extra Transfer (without Transfer connection worse). The transfer increases the efficiency:
-when you need energy from somewhere to withdraw;
-when you need energy to manifest to locate without reference to the Operator, other people or to be able the place of the location to be changed (moving receiver).
Sincerely, MAG.no
м-р Фримэн
Post by м-р Фримэн » Fri Dec 10, 2010 18:28
Роман Н wrote:Yesterday decided to clean the room.Downloaded audio in Winamp, set the "reverse" connected to СК1М and went to bed.Woke up in the morning,and the player loses.Trying to run still quiet,re-download the file too, does not respond and all the buttons in the player active.Rebooted and it all went!
That's it, direct my case, then only the acceleration record is left... :wink: What you lose entry to your computer, laptop or even on how far from the instrument is the player?
Роман Н
Post by Роман Н » Fri Dec 10, 2010 21:26
Mr. Freeman
Lose on stats. compe, СК1М is in the immediate vicinity. And the comp's been acting started,already thinking about relocating the system,maybe a virus picked up,and maybe not accidentally this. :shock:
And also, can someone tell me is it possible to put on stage the cartridges from the modulator at the time of playing audio?
Post by Михаил_ » Fri Dec 10, 2010 22:25
not desirable, but in principle, if there is the recording mode on the subject, it is possible.
Роман Н
Post by Роман Н » Sat Dec 11, 2010 1:55
Michael
I mean not audio affirmations and goals bookish voice,for example "washing operator energy" on the table and let the cartridge "chakras" or maybe "luck" i.e. energy supplies power operator has already been modulated by a certain quality.Whether the effect of such combinations? Or all the same not to interfere with one another?
м-р Фримэн
Post by м-р Фримэн » Sat Dec 11, 2010 3:16
Роман Н wrote:Lose on stats. compe, СК1М is in the immediate vicinity.
It would be necessary to take away away and look for an optimal location for IC and PC. It helped me, blew a little further away and a little to another place and own records purposes turns already 3 days without interruption. I'll have more on the teams (cleaning, harmonization, etc.) to drive, to see how it will be in a new place.
Post by Михаил_ » Sat Dec 11, 2010 6:59
Novel N - in General I think it is better not to interfere, but if the effect you like, then you can use. If just to drive the SC in the copy, probably it is possible to erase or damage the cartridges, I'm not sure how proteinopathy two different programs storing and applying of information, there was no need to check.
Сатурн
Post by Сатурн » Fri Feb 25, 2011 14:42
Hello. 05.02. bought СК1м and two bracelets 2.0. . Set a goal with the help of the audio track sk1fixtarget.mp3,and decided to nourish energy with the help of the audio track sk1hfuture.mp3 the probability of the event, I have two questions;
1. whether apitite energy the probability, if there is no route at all or anything is not clear, there is only purpose.
2. how long can I turn the audio track sk1hfuture.mp3
