How to be?
АСД
Post by АСД » Thu Jul 22, 2010 21:15
Сергей Владимирович. wrote:So what technologies are you going to reduce the degeneracy is removed by the spatial – temporal structures and change the human genome?
Using the technologies of designing structures that are based on the theory of Physical structures Yu. I. Kulakov. His monograph was published two years after writing the essay, which You so graciously quoted.
Сергей Владимирович. wrote:So I know about substantial, and about the relational theory of space-time.
To know about the theory and to own them are two different things. So I advise you to savvy. Can you provide links to the relevant literature. Because before you accuse someone, you have to thoroughly understand and do it competently and not engage in idle talk.
Post by Сергей Владимирович. » Thu Jul 22, 2010 22:46
Sergey. wrote(a):
Another proof that you are famously bred...
...It's just the most convenient theoretical model to describe the properties of the world
...hammer head people any pseudo-scientific nonsense, in which they a little that understand!
where are the Insights?
Space-time — physical model, supplementing the equal space of time, and thus creating new theoretical and physical design, called the space-time continuum. In accordance with the theory of relativity, the universe has three spatial dimensions and one temporal dimension. Space-time is continuous and from a mathematical point of view represents diversity, which is usually also endowed with Lorentzian metric.
The number of dimensions needed to describe the Universe, not completely defined. String theory (superstring), for example, required the presence of 10 (counting time), and now even 11 dimensions (in the framework of M-theory). It is assumed that additional (unobserved) 6 or 7 dimensions are folded (compactification) to the Planck size, so that experimentally they cannot be detected. It is expected, however, that these dimensions somehow manifest themselves on a macroscopic scale. In the old - boson - version of string theory requires 26-dimensional enclosing space-time; it is assumed that "extra" dimension of this theory also should or could (or have hope so) to be compactification first to 10, reduce thus to superstring theory, and then, as mentioned are slightly higher to the 4 normal dimensions.
Therefore, I repeat that the dimensions of space-time is a mere abstraction designed to describe and build a picture of the universe.
And in General, the dimensionality — number of independent parameters needed to describe the state of the object.
Example. To determine the position of the aircraft (aircraft in this case is not considered as a three-dimensional object, and as a point), you need to specify three coordinates in addition to latitude and longitude need to know the height at which it is located. Accordingly, the space in such models is three-dimensional. These three coordinates can be added a fourth (time) to describe not only the current position of the aircraft, but also of time. If you add to the model the orientation (roll, pitch, yaw) of the aircraft, then add three more coordinates corresponding abstract space of the model will be semiminims.
So what "fills" you here, Mr. ASD about changes in the structure and the dimension of space-time with his "wonderful pieces".
Now about the second question.
Well sorry if offended anyone! Just didn't know that there were some doctors of physical and mathematical Sciences, and just those who are at leisure to do nothing, as to study theoretical physics in General and physics of space-time in particular. But then you would understand what alarm you simply "spreads" and would look for no grammatical mistakes in his articles, and several additional.
...live, I live in N dimensions vortices of wills, a cyclone of thoughts, those who are funny we are with our children's vision with our step one line. Bryusov V. Ya.
Sincerely, S. V.<
Post by Guest » Fri Jul 23, 2010 2:27
Dare to speak as a consumer: throwing each other essays and reference to the physics textbooks, perhaps interesting only to the warring parties ( i.e. the two people ). Much more interesting would be for example instead of scattered about the theories of the universe, to explain how these theories are related to the material embodiment: a front Room for example. In other words, how fundamental science is reflected in the device Chamber. And it turns out the theory themselves, the cat in the bag itself. ( I'm asking You about the anatomy and physiology of the cat, and You tell me: life is the mode of existence of protein bodies ). Can't answer, so you wouldn't be trying to turn around in the aura of science. As the saying goes, what is theory if it cannot explain a child of five... And since then the ASD advocates a scientific approach, why not provide data about research their products using placebo ( make a batch of cards with no structures is not difficult right? ). I can certainly not see why the materials of the Parlor, then I'm sorry, but really tired of all this pain about winding us up or not. This experiment on myself I can not set: need sample for statistical reliability + placebo. :?
Post by Guest » Fri Jul 23, 2010 2:55
Previous post of mine.
Mirta
Post by Маг.нет » Fri Jul 23, 2010 7:30
S. V. was not convinced... Much juggling of points of view. The world is more diverse than the postulates of the theory of RELATIVITY. And physics in Your sayings... But here's judgments and charges in full. Should stop the distortion of the monotony of Your GUILTY position.
Agree not a physicist, and not everything is clear from the scientific approach, but it is a description of one of the abstract models. A CHAMBER WORK! But how to explain this model or the other is not so important for physics.
Finish this...
Sincerely, MAG.no
Новик
Post by Новик » Fri Jul 23, 2010 11:58
And I'm here for Sergey. but that criticism was constructional in the form of a dialogue, not recrimination.....
Then look and become at least something clearer about the parlor and their principles.....
PS.
ASD is also a man and can err no?
АСД
Post by АСД » Fri Jul 23, 2010 13:20
Сергей Владимирович. wrote:In accordance with the theory of relativity, the universe has three spatial dimensions and one temporal dimension. Space-time is continuous and from a mathematical point of view represents diversity, which is usually also endowed with Lorentzian metric.
SRT and GRT are not able to describe the structure of the universe and this issue has been widely discussed even in the popular press. This is indicated by the appearance in the description of entities such as dark energy and dark matter. About them nothing of physics can not yet say. So the search for a new scientific paradigm, which would be able to go beyond the existing theoretical descriptions. The continuity of space - time is discrete in the quantum world there is hardly.
Сергей Владимирович. wrote:The number of dimensions needed to describe the Universe, not completely defined. String theory (superstring), for example, required the presence of 10 (counting time), and now even 11 dimensions (in the framework of M-theory). It is assumed that additional (unobserved) 6 or 7 dimensions are folded (compactification) to the Planck size, so that experimentally they cannot be detected. It is expected, however, that these dimensions somehow manifest themselves on a macroscopic scale.
In string theory (superstring), too many problems and unresolved issues. There is a good overview of Professor Vladimirov "Space-time: explicit and hidden rsmemory" M: 2010. In it, he well examines the main problems of modern physics. Here he mentions the Theory of Physical Structures Kulakov as a promising new paradigm that can give the new description in physics and has found a new mathematical apparatus - binary geometry.
Of course, any theory has limitations and should be until, until there is a new, more complete description. With time and TFS will relinquish their positions to new directions and paradigms, but at this stage it gives us the ability to predict the qualities of our developed technologies and serves as a good mathematical model for moving forward.
Сергей Владимирович. wrote:So what "fills" you here, Mr. ASD about changes in the structure and the dimension of space-time with his "wonderful pieces".
So I "poured"? Let's be more specific.<
АСД
Post by АСД » Fri Jul 23, 2010 13:23
Гость wrote:And since then the ASD advocates a scientific approach, why not provide data about research their products using placebo ( make a batch of cards with no structures is not difficult right? ). I can certainly not see why the materials of the Parlor, then I'm sorry, but really tired of all this pain about winding us up or not. This experiment on myself I can not set: need sample for statistical reliability + placebo.
Why the need for an experiment with a placebo? What question YOU want to answer?
Post by Михаил_ » Fri Jul 23, 2010 14:43
Guest, for some experiments, placebo-cards (no matter working or not), we need not only "empty" card, you also need to group the testers did not know what exactly they explore + to map (or other constructs) is not soderjanie logos and names, and was not individualized (like any other mass product), otherwise will be created a link (as the link to the site on the Internet), which is also how it works, though weaker than a true parlor (or other similar device). Some detail is described in the book of Karl Welz (see the section on Radionics) and very easily checked for proposed they folk experiments.
Incidentally, in a placebo coming from the tuning of consciousness on a particular object there is a share from this link. (i.e., from work products via the infusion of consciousness on it). Clean checks will require a complete ignorance of the subjects characteristics of the studied devices, the dissimilarity of the samples and dummies for industrial design and other complex conditions.
Even in this case, in the information world, where physicists seriously studied the properties of entangled particles and other physicists writing about the holographic world, there is a linking (formation of connections) between related objects that somehow starts to work. This is most clearly known for the transmission of intuitive feelings between close friends.
The paradox is that some tests require those products do not seem to use it, not tried and probably not going :) to try. Ie, the purpose apparently any publicity, or the ability to rant online (especially anonymously).
The topics enough feedback on the work equipment, excluding pure placebo, on the other hand these products always work together with the totality of other factors and front of the objective researcher faces a difficult task of dividing the influencing factors. The manufacturer has made a number of studies, published them, people tried it, got the results, wrote reviews, others go on their trail. Everything is fine.
One does not satisfy these things - well not easier just passing through? out the network writes that the new model of the iPhone unstuck, contains spots on the screen and bad reception, if you take in hand the case as a whole.
However, the manufacturer said it's fine :) and people continue to buy it for big money, for the brand.
What no one is running to restore order and justice? And because the giant company it's kind of useless, and fans can cast aside anything. And here is relatively safe (at least I think so).
Lyrical remark about psychology in the network.
In ancient times in Russia was not a full-fledged Internet, and little he was. But there was a loose and informal network of Fido (Fidonet) Made by enthusiasts all over the world. Through it, you can transfer email and were counterparts of the thematic forums - ehokonferentsii, both international and Russian.
The most interesting that lived all it's completely the personal funds of private participants in the network.
.... what is the story I remembered? :)
and here's what. In the echomail areas for the first time, then formed the rules of conduct and the moderators who are watching the absence of gross violations and hassles. Fig-behaved and unruly was just off for some time. But such was always. So. The most interesting that full-time city vstrechah, it was perfectly lovely, civilized men, completely together on my own way and talked with his adversaries in disputes, with whom in the network they came almost to blows (and no matter for what reason). Back then was discovered psychological phenomenon anonymous communication manifested many online.
Since then, little has changed, only the means for communication are slightly different, the operating system DOS and Windows, most, well, some other details and psychology of communication all the same.
I since then adhere to the ideas of strict moderation - in violation of the uniform abutment of group communication on the street will get you know where and you know it. If the network is to give excessive freedom passes into permissiveness rudeness and assaults.
(2:5020/303, 2:5020/302 Hub) :)<
Мирта
Post by Мирта » Fri Jul 23, 2010 15:30
Михаил_ wrote: the Paradox is that some tests require those products do not seem to use it, not tried and probably not going :) to try. Ie, the purpose apparently any publicity, or the ability to rant online (especially anonymously).
If the network is to give excessive freedom passes into permissiveness rudeness and assaults. (2:5020/303, 2:5020/302 Hub) :)
Anonymous wrote:Previous post of mine.
Mirta
Michael, before you accuse others of rudeness and assaults, ought to be elementary careful. By the way, the two of us user of the parlor I, not You.
ASD, why placebo-controlled tests: are You serious? Do not know? To separate flies from cutlets. How to do Michael wrote. Why specifically me – from philanthropic motives wanted You to get rid of constant attacks on the inadequacy of the evidence base. You've personally not tired in talking without adding anything new on the forum? It will be at least able to give the normal link to the study that covers most of the questions on the effectiveness of products, not breeding demagoguery on theoretical topics related to the final product is incomprehensible to anyone except You link. Knowledge in this case IMHO better faith.
PS Normal study – a randomized, double-blind, placebo-controlled study. az
Post by Михаил_ » Fri Jul 23, 2010 16:31
Myrtle, if you carefully read my post, it will be seen that the first part of comment about the problems of the test on the placebo, if you hold it quite clear - i.e., should not be the similarity of design to a serial product, otherwise there is some connection in the image. For example, such coupling occurs during the charging part of bracelets from the party on бж1.0 - similar bracelets of the same material and the same batch of them have some resonance to them appears weak-weak бж1.0. In fact, this phenomenon is found everywhere and is most often used in advertising to link any of food products in an environmentally pleasant painting
ie the question of the competent division of pacifiers and the workpiece in the case of information active products itself is a difficulty.
the second part of the message and lyrical, dedicated to the cries of "we are bred" in General, not your post in particular.
And about the presence or lack of parlor You don't know anything :)although the subject goes much wider than only the parlor and the problem of change the current scientific paradigm which includes postulate about the untouchability of the sacred dogmas.
Some people because of personal interests or fulfilling system-algorithm (drawing not their thoughts, but I think that doing "with all my heart), begin to fight windmills protecting the corpse artificially castrated science, where everything you need has always been, but time was out of the public eye, so as not to cause unnecessary questions from the masses. Now is not removed, because they have a transition period when you need to silently and gradually instill new, but not extreme.
Therefore, there are absolutely interesting things - some Federal statesman says that staying with the aliens, and who would not consider him crazy, but he is a figure with weight and it is somehow imprinted on the subconscious. The other person says in an interview with the history of its formation as a politician, plaiting to this any "potustoronnego" on TV different Doc. movies like "the call of the abyss", where everything is fiction, but every fiction there is some fiction.
Why is that?
This suggests that the strategy to change the basic paradigm is taken as inevitable (the old has become uncomfortable, or have other compelling reasons), and therefore, such products can easily find their way without significant resistance, although with some friction, since no one will officially remove the old from the scene, will wait until it is quiet transformirovalsya.
While there is a transition period will always be those who will be waving swords.
As for research - any study, especially with statistically significant sample and achieve the desired culture experiment is important to Finance investments. Think results something impact? I am sure that not a drop.
As I recall, on the website the FACE there are studies on laboratornih animals (mice, like not mistaken), so they are placebo is not available :)
But it's not interesting, and critics will still find something to complain about printing them is not the same, or the organization was not sufficiently "weighty" and the like.
No tests and the conclusion will not satisfy those who want to work-errant in defense of old truths. It energougolnaya position associated with systemic phenomena - those who are asking for this role, "Torquay" by the operation of one of the poles of the powers of this world, man is not quite himself, he becomes a conductor, not a person. Vaughn is full of examples in the news - one group disagree with one, he encountered a group disagree with others :) This suggests that the society is more alive and there are some processes.
There's an old good American Comedy "back to school". There is an entertaining history teacher in high school. About which main character says "you should not, a good teacher, he really cares, just to understand that...." :)
Attempts to defend or join the discussion here completely useless because they do not lead in the end to progress to any.
The attacking side will always remain unconvinced, what would be the conclusion were not presented.<
Мирта
Post by Мирта » Fri Jul 23, 2010 16:50
Михаил_ wrote: And about the presence or lack of parlor You don't know anything :)
You have repeatedly written here that I am not a user of the Parlor. What has changed?
АСД
Post by АСД » Fri Jul 23, 2010 19:51
Мирта wrote:ASD, why placebo-controlled tests: are You serious? Do not know? To separate flies from cutlets. How to do Michael wrote. Why specifically me – from philanthropic motives wanted You to get rid of constant attacks on the inadequacy of the evidence base. You've personally not tired in talking without adding anything new on the forum? It will be at least able to give the normal link to the study that covers most of the questions on the effectiveness of products, not breeding demagoguery on theoretical topics related to the final product is incomprehensible to anyone except You link.
Михаил_ wrote:As I recall, on the website the FACE there are studies on laboratory animals (mice, like not mistaken), so they are placebo is not available
Why can't I get rid of constant attack, Michael has convincingly shown.
A website is really quite of experimental results, excluding the effect of placebo. This and experiments on rats, showing the growth of anti-stress factor of 25 times, that experiments on enzymes, showing an increase in the sensitivity of enzymes more than 2 times, it experiments with blood, where the effect of normalization with the improvement of some indicators of leukocytes in 10 times. Take Ekonorm. When the vehicle is reduced FROM several times from the application Ekonorma or fuel savings of 20% where the placebo effect?
Or are You, Myrtle, I did not read these reports or they are not convincing for You. In either case, Michael is right. Your required experiments do not add to the credibility, but will require considerable time and resources. We are not interesting as we know that the placebo effect is not being. Therefore, we examine only those parties that offer us something new in the understanding of the processes of structural interactions.<
Фёст
Post by Фёст » Tue Jul 27, 2010 3:57
2 Andrey Kabakov :
"Today I returned to the parlor,which I passed on to fest for testing.
Turned out to be unclaimed."
The circumstances were such that in Kiev in either late June or July I could not get.
Alas, was the case.
Alas, do not have sufficient amount of free time to wander around the country
plastic "wonders".
When You honorarily, I understand that You have in Kiev office.
And a chamber is ALWAYS there, not specifically transferred one eksemplar exclusively for testing.
I figured since this is Your official representative, then you can access it at any time and room he is always there. Once there was an agreement.
It turned out to be such a great problem and in Kiev there was only one parlor... And the one delivered was in a hurry fo mi. And back took... :)
Easy unfamiliar situation.
2 Merkaba :
This is what is "this type"?
You think I had to drop everything and lomanutsya to Kiev from Donetsk for Your piece of plastic to have happiness to use it?
I didn't think it was such a problem.
No one any time limits are established.
Seriously polinal that you can apply anytime, once agreed.
And it won both, Mikhalych...
Actually, I am in Kiev I will still.
And experiment desires is not lost.
Everything is in place.
As far as I understand, You no longer have representatives in Ukraine, only Kiev?
PS. Sergey, my respect, hats off!!...
Post by Андрей Кабанков » Tue Jul 27, 2010 10:11
fest
You can contact Irina,she would have sent you the parlor.
(I was replagal to do)
The room I was told that would not strain Irina this test,as it buys a chamber on the money to my agreements with you has nothing to do.
After reading your posts,after we agreed,I am somewhat more learned of you and have completely lost interest in you. Offer testing is no longer valid.
Фёст
Post by Фёст » Tue Jul 27, 2010 17:50
2 Andrey Kabakov :
"You can contact Irina,she would have sent you the parlor.
(I was replagal to do) " --
Here, sorry, misunderstood... It was just about "pick up in Kiev at the representative".
"After reading your posts,after we agreed,I am somewhat more learned of you and have completely lost interest in you. Offer testing is no longer valid." --
Who would doubt. :) What was required to prove, Amen.
Of interest to your people I have exclusively entomological.
Study in applications.
"And I will continue to do the same" © Vladimir Vysotsky
By the way, with testing of the "Parlor" did not grow together, but in my hands I got another of your "apparatus". They just chase me. People brought themselves. Rich in "positive" impressions.
Most certainly write. On the findings of the internal contents of the device and the reviews of people usawhich.
There is something to write about...
You know it's just a song!
Peace Be With You.
Post by Андрей Кабанков » Tue Jul 27, 2010 20:30
I have already written above that your opinion is not interesting to me.
This also applies to the parlor and any other products.
Not interested in your opinion on any issue :)
Post by Guest » Tue Jul 27, 2010 23:45
Андрей Кабанков wrote:I already wrote above that your opinion is not interesting to me.
And my opinion is not that interesting, probably! The reason is only financial interest, And all !!! The website turned to selling designer candles at an unrealistic price.
Narold fool, you can not endlessly! Business, as this site will die soon! And things like MM and Petrushevskii drives will lose distribution point!
Kabankov now wants not infinity, and the gelding Mlcu?
Where such an influx of junk?
Answer Kabankov!
Фёст
Post by Фёст » Wed Jul 28, 2010 4:59
Andrew, You are so wonderfully portrayed the naivety, I just checked! :)
Clear the stump, YOU my opinion is not interesting.
YOU my opinion, at least, annoying to those that hit the sales of plastic laparascopically.
YOU wonder that it did not exist.
This opinion, of the views of people not engaged, soberly looking at things and analyzing, and with a lot of publicity.
But it is interesting the comrades who are POTENTIALLY interested in purchasing your "miracle inventions", but fluctuate.
Here it is interesting and useful.
Post by Андрей Кабанков » Wed Jul 28, 2010 10:23
Assuming that we sell a bunch of junk that does not have you say any action,the business would have died long ago.I can not imagine how you can sell pacifiers with website forum with virtually no moderation.
My predictions-business will be developed successfully,there will be new and interesting developments related to technomagic and MM.
All will be well :)
Post by Андрей Кабанков » Wed Jul 28, 2010 10:35
fest
You are playing a positive role in terms of informing people about the existence of the product itself.Most simply do not know about the parlor. Learning about what they are thinking person not difficult to understand they need it or not.
In this case, your opinion about the product seems insignificant.The forum has a lot of interesting people who expressed their attitude to the product,wrote reviews,based on them, a potential buyer can make a decision about the purchase.
МерКаБа
Post by МерКаБа » Wed Jul 28, 2010 11:49
These technologies should be developed and should be up to each person, so, our civilization has a chance to move on. IMHO.
Смелый
Post by Смелый » Thu Jul 29, 2010 3:27
Фёст wrote:Andrew, You are so wonderfully portrayed the naivety, I just checked! :)
Fest, modest to be tried? And that and rushing to admire the event that we visited the people "unbiased, soberly looking at things and analyzing, and with a lot of publicity". Here I would like to detail. Which means with a lot of publicity? Or who? Comrade! I have already mentioned. You have no idea how to the public forms the basis of this forum, funny and lame Your attempts someone in something to accuse. And Your predictions about dying forum.... Listen, a graduate of the biological faculty. You would go to their toads or frogs, You'll surely be in authority. As soon as you see Your inflated cheeks, wrinkled forehead, protruding ears and bulging eyes (so I imagine Your thought process), I immediately begin to applaud. Although.., however, stay. Always interesting to see another dropout and his antics about things, his consciousness is not available.
Фёст
Post by Фёст » Thu Jul 29, 2010 6:43
2 Andrey Kabakov :
"You play a positive role in terms of informing people about the existence of the product itself" --
Glad to be of service.
"Learning about what they are thinking person not difficult to understand they need it or not. "--
Doubly glad that many people helped deal with your "technomage". And many more will help. I solemnly promise
2 Bold :
"That means a lot of publicity? "--
It does mean that. What You do not understand? Googling the meaning of "publicity".
I specifically do not monitor, interest was not how many people read it the note about Your Scam. If You are interested can count. Vskidku thousand 15. In the real world - more, it is to the eye. And read continue.
"Fest, modest to be tried? And that and rushing to admire the event" --
Tried. Garbage... stay away on health. For an autograph, please in turn.
"You have no idea how to the public forms the basis of this forum, funny and lame Your attempts someone in something to accuse" --
Well aware of it. That "public" alternative thinking not interested. But apart from this audience there are people with more ordinary thinking, they are interested. And the majority of them.
"And Your predictions about dying forum.... "--
Snack, dear. I didn't say never. And I do not make predictions. I'm not Pasha Globa.
"Listen, a graduate of the biological faculty. You would go to their toads or frogs, You'll surely be in authority. As soon as you see Your inflated cheeks, wrinkled forehead, protruding ears and bulging eyes (so I imagine Your thought process), I immediately begin to applaud. "---
You're funny. Poor, but funny. Lift me up. ;)
Смелый
Post by Смелый » Thu Jul 29, 2010 9:32
God, how boring! Nothing changes in life. And even the appearance of blockheads of the type of fest that are not uplifting. Looking for similar hardcore, making their authority on the overthrow of people, thoughts, things, devices, knowledge, we have to admit that when we are still divided. And, accordingly, the assigned categories, will be placed in different places. Anyway fest, he told me neither the matchmaker nor the brother (and not the worst still man instance), but there is and its close surroundings. And also, on the loaf of sausage, not wanting to see, and its vegetable existence considers the only right one. True and he probably didn't get very far, but still you are in motion.
Gentlemen, the guests of the forum!
Let's raise your spirits. This should probably open a separate thread. Open Sportsbook, bet really will yourself to do not cash (that would not recognize gambling). The subject of rates will be different creatures, like Festa and the like. Each such type will assign a rating, the number of asterisks or other characters. Let's make bets on how long this person will last on the forum or number of posts, stupid posts, but whatever. How many more will appear. The only fuse should be in the lack of participants rate feelings of superiority, pride, and so on. Pure play. After all, when is the bug on the run people make bets, because none of them feels superior to cockroaches. And here come the people, with their worldview, and most importantly with their interests. Well, we recognize their right to behave like this. Because they have a different life experience and other knowledge. But also recognize the right, their appearance on the forum, to turn into our entertainment. It's nothing personal. Just a game.
As the saying goes: "it was evening, there was nothing to do".
