Vasily Ivanovich: - Petya devices?
Petya: Eight!
Vasily Ivanovich: Why eight?
Petya: what equipment?
And now serious. I didn't want to mention here Bronnikova, but since I first learned this information from his lectures, you will have. There are so-called "morphological field": for example, if you take two pencils from the same batch, made from a single piece of wood, with the same chemical composition stylus, etc. to Spread them as far as possible (
the more the better) and powstancow one of them, the second certain way will react to it (Bronnikov says
will light). It's about the interaction between the elements in the transfer pair.
Next. Actually, the tube output of orgone is just a conductor to supply current to the transmitter: what's the point in the waveguide for the radiation energy that passes through any obstacles and does not have any time delay? Much more effective was to make it of copper, but copper tend to be covered with a patina, though noble looks, but the silver in this sense, aesthetic. It's about the interaction Radionics and transmitter.
The ability of boosters to increase the power of orgone is due, most likely, the mass initially incorporated in the device orgonite. Less able to strengthen more, probably just the opposite, to not claim for this reason'ts. Otherwise, he would have made a more powerful model more compact in size than less powerful. Yes, technically it is not difficult to make amplifiers and ATG 12, but weigh they will respectively
A little negativity. For the past 2.5 months I every day make sure that Welz elementary tries to "hide an awl in a sack." If I hadn't read his biography, I would seriously think that he does not understand what he is talking about. And he's blowing a mist where similar fog no longer, in principle, years 5-6. Its instruments and without this copy, and copy very successfully (photo resemble children's puzzles from the series "find 10 differences"), regardless of whether he reveals "his" know-how or not.
Another interesting point. Over 10 years of successful sales do not even create a dedicated forum for your devices - is it conceivable for Americans, which even can cook teaches not mother or grandmother, and teachers on special courses?
Something is not right here, agree<
