The free exchange of resources for Self-development.
Post by Андрей Патрушев » Mon Jul 13, 2009 20:33
Егор Грысь wrote:Andrei Patrushev
Andrew! If easier, why are You still not done?
For example, I don't really know how to do it. And, as I understand it, the chip is not in the random number generator, namely the fact that his work directly influenced the thinking of the impact that registers their device. The same with their "magic" light.
Do such a thing (if it's actually easy), and I'm happy to buy it, and another one as a gift to someone, and, I think, many people also buy with pleasure (of course, if Your thing will not be too much to give mariinskoe), and still bought fellow citizens will be proud that we are not behind the Americans in terms of cool research (and I with them). However, for example, some domestic craftsmen (stupid I guess) make the mind-machine will be offered for sale, but for some reason other people are not very fact, they (these machines) favor and prefer merikanskie, although the latter is not deprived of some drawbacks (from user perspective).
By the way, I downloaded a Rainbow (free, the other not seen). Well, cool: the dots on the type of the screensaver "starry sky", multi-colored letters (like psycho tests and all sorts of methods of subconscious memory). And Shaw, You want to say, that responds to my mental impulses? (It would be cool, because they do no one reacts, even his own wife and children, not to mention about the cat and all the others :) ).
Again hoping for an answer. :) Thank you.
The idea is extremely simple and stripped in Russia. In 80-e years at ENEA was the pavilion, where everyone was tested for psychic abilities. On the primitive computers stood a primitive program, where RNG was directing the plane by squares. The test had to guess - where the airplane will move. Given a series of 20 moves and stats were counted. This idea was first worked out in the Institute of Serbia (if not mistaken) for the EEG equipment... (in General dlinna story...). The point is that the RNG is able to handle certain people with certain abilities (but not all and not always) when the RNG connected to a positive feedback in the form of a beautiful light bulb (the brain loves beautiful things), then things start to go better have more people...<
Егор Грысь
Post by Егор Грысь » Tue Jul 14, 2009 17:02
Thanks for the info. This is really interesting, and I didn't know that.
That is, if I understand You correctly, we are not talking about the mental impact on this little device, and it's just statistics "guesses"? Ie type simulator for the development of intuition, psychic abilities? I may not quite understand correctly the information on the Psyleron website:
"human intention and group dynamics can influence the behavior of quantum electronic devices known as Random Event Generators (REGs)" and further; "The Mind Lamp is a color-changing ambient device that can respond to human intention and group consciousness... ...designed to elicit a response from human consciousness") (quoting the website http://www.psyleron.com/).
But the answer to the main question, I have not received. The Americans make such thing and sell it (not sure how successfully), and domestic Kulibin know how it all works, but... don't want to do? can't? what's the catch?
If you do not want to mess with that, why not re-sell American products (at least with a minimum localization - Instruktsiya in Russian)?
And since the brain likes pretty lights - make Christmas tree garland (the amplitude of its swing, and even better with the cool knob on verhushku Christmas tree, sparkling and shimmering) with RNG and positive feedback, to the delight of children and their sober and cheerful ancestors... :D
Егор Грысь
Post by Егор Грысь » Tue Jul 14, 2009 17:20
Sorry, it seems only now began to "get it": I thought that we need some kind of sensor, sensitive to impact and transmits the signal to the system, and, it turns out that the PPP itself directly captures these effects (ie he is a "sensor", and the generated signal can be taken into account "mental momentum", so to speak, "including"). Ie, does "isolate" myself "mental momentum" (to separate it from "noise") is impossible (eg. to reinforce)? Hence, the momentum should be strong enough by itself...
Interesting, and you can somehow "escape" the RNG from the mental effects?
Егор Грысь
Post by Егор Грысь » Tue Jul 14, 2009 17:28
And interestingly, and computer randomizer (emulators) also catch this impact, i.e. the alignment of cards in the solitaire can be influenced by thought? :)
Post by Андрей Патрушев » Wed Jul 15, 2009 3:16
The computer, unfortunately, pseudo RNG works, although it seems very successful experiments at ENEA, have to work - that is controlled by the brain... But the fact that this device works "on the verge of a foul" - the RNG changes the color, but whether You feel something is not known...:? Simple generator RNG is a field-effect transistor (by the way, a similar methodology based technique Foll), so go ahead, Kulibin... :)
Good Luck Running!
Егор Грысь
Post by Егор Грысь » Wed Jul 15, 2009 13:49
Thank you, Andrew, for the interesting information, and enlighten a little on this topic. (At the same time I leafed through the information in the Internet about the method Foll (or Voll), which I never before heard: there electro diagnosis/therapy, and another interesting drug testing: the dependence of electrical resistance in the active (acupuncture) points to the drug (medicine) the patient picks up: if the one that is able to cure his disease - resistance is close to the norm, otherwise even more rejected. - You, probably, it is the latter meant).
Alas, I'm not Kulibin... and therefore I would like to hear. the chief of transport shop... (in the sense of tovaroved or hto then decides about the procurement and assortment):
You can still expect to gain a beautiful light, which is so fond of the brain, from our store (your, of course, but in the sense of domestic) in the foreseeable future, or still have time to have MasterCard and dollarby to go cap in hand to uncle Sam and his delivery services?
художник
Post by художник » Sat Jul 18, 2009 1:03
<a href="http://narod.ru/disk/11033265000/%D0%92 ... tml">Вадим Ufimtsev Practical bioenergy (copy 2).djvu</a>
Fixed file
Артур К.
Post by Артур К. » Sun Aug 16, 2009 16:27
художник
Post by художник » Mon Aug 17, 2009 17:43
Symphony of the Senses 3cd/APE
“Composition, imbued with meditative calm, bear in mind that extend to the very threshold of perception and touch you deeply. Allow yourself to dissolve! Open up to this gentle sounds that help you relax, touch your heart, caress and
evoke dreams. All that you will experience thanks to the music that will carry you to the land of the senses. Give full rein to the imagination and your consciousness opens a new way of perceiving reality: positive and sensual.”
The full text of the description of the discs(and each track) in the archive
Simfonia.rar
Post by Guest » Wed Aug 19, 2009 19:41
artist
release a couple of tracks individually
Димитрий
Post by Димитрий » Thu Aug 27, 2009 20:40
Artist Musla - complete separation!!! az az az . Saying that, worth the time to download the whole archive. And those who are too lazy like me to do envelope Aare-MP3 - suggest the following prog - http://www.jrmediacenter.com/download.html
Tell me, do You have ischo is the same as such? :oops: :wink:
Артур К.
Post by Артур К. » Wed Oct 07, 2009 0:10
Please tell me literature about the "Laws of the universe," "Spiritual laws" On the website KUB dug , so much literature , and that he was not want to read.
Can someone read what books ? Advise ?
Димитрий
Post by Димитрий » Thu Oct 08, 2009 12:29
"The laws of the Universe" is 112 which? "Spiritual laws" is 12 which? Better than yoga, the book won't tell You, IMHO... Although I would also like to read...
Post by Guest » Sun Oct 18, 2009 19:25
http://torrents.ru/forum/viewtopic.php?t=2039507
Tanya the blacksmith of his own happiness
Psi-Technology & Products Latentframe (FLAC+MP3+EXE) 2009
Genre: hypnosis session
Release year: 2008-2009
Manufacturer : Russia and Ukraine
Description:
Your attention is presented the unique technology gipnosuggestevna suggestion. This technology can be used for the treatment of most pathological dependency. Such as: addiction, Smoking, gambling, obesity, etc. Also the technology gipnosuggestevna of suggestion can be used to overcome different kinds of phobias (fear of heights, fear of closed spaces, etc.) this list of applications does not end there. By and large, the scope of application of this technique is limited only by Your imagination. Using gipnosuggestevna of suggestion it is possible not only to cure disease but to get the quality that You previously had! For example, courage, will power, optimism, confidence!
Technology gipnosuggestevna of suggestion can be used for entertainment purposes. For example, to simulate the effect of some drugs and achieve the euphoric state (joy, bliss, euphoria, flight status, hallucinations, feelings of unreality and many others).
A unique feature of the technology gipnosuggestevna suggestion is to go through the whole Wellness course at home at your convenient time. With this, you'll be able to solve their most urgent problems and new perspective on life.
The main part of the course is to view a special Wellness sessions (suggestions) on your computer. Session data are the executable files that can be downloaded from our website. For the passage of the health course by the method of hypnosis you can use one of the following standard hypnotic sessions or make an individual order to solve specific nature.
These hypnotic suggestions are manufactured using advanced technology ANGMAR -32, which provides the most deeply entrenched of suggestion to the subconscious. Thus, inspires the program is perceived by the subconscious as its own that provides immediate execution.<
Димитрий
Post by Димитрий » Thu Nov 05, 2009 15:55
Anonymous wrote:http://torrents.ru/forum/viewtopic.php?t=2039507
...Yeah...Probably a cool thing... And no link in their profiles somewhere in the thread, not the torrent? :cry: :oops:
Post by Guest » Wed Nov 18, 2009 18:58
Егор Грысь wrote:Thanks for the info. This is really interesting, and I didn't know that.
If You are still interested in Mind Lamp, here on this site met information in Russian: http://www.mind-matter-effect.ru/
Искатель
Has thanked: 3 times
Post by Искатель » Fri Nov 20, 2009 20:18
http://cognitio.spb.ru/index.php?option ... &Itemid=17 there are exercises for the eyes..maybe someone will be interested :) This psychophysical training...
Андрис
Post by Андрис » Fri Dec 04, 2009 14:29
Offer experienced-those working in the PsA Audioprogram and their vozdeistvii will vistavit and discuss resource, a setting eat or think (formulirovka free) deceptive (for example I think are: http://www.sviyash.ru/, http://psy-wave.ru/, http://www.teron.fatal.ru/).
Post by Guest » Fri Dec 25, 2009 14:52
On Letitbit have the ability to remotely upload torrents, but you need to earn 0,25$ per day, if anyone is familiar poster can be asked to thanks and give the link
Post by Guest » Fri Dec 25, 2009 14:54
Андрис wrote:Offer experienced-those working in the PsA Audioprogram and their vozdeistvii will vistavit and discuss resource, a setting eat or think (formulirovka free) deceptive (for example I think are: http://www.sviyash.ru/, http://psy-wave.ru/, http://www.teron.fatal.ru/).
Sviâša - divorce, no effects no
Нетрезвый Сурдопереводчик
Post by Нетрезвый Сурдопереводчик » Fri Dec 25, 2009 23:51
in addition,he had already sort of decided to atone for all the sins :lol: :lol: :lol: .say,rides on the monasteries...would be better if the port had... az
Post by Guest » Sat Dec 26, 2009 0:59
"I'm the leader of the pack" Audio auditory training
Description http://www.teron.fatal.ru/tov_op/at_men_vojak_stai.php
http://letitbit.net/download/4143.4b67f ... a.rar.html
http://depositfiles.com/files/p7grdt9f2
Post by Guest » Tue Jan 05, 2010 23:44
An alternative view about Castaneda, the "DURA", Tin... :shock:
http://mindweapon.org/index.html
художник
Post by художник » Sun Jan 17, 2010 3:21
Anonymous wrote:Alternative opinion about Castaneda, the "DURA", Tin... :shock:
:evil: Each not by deeds, but by what he believes :) Or what he WANTS to believe
