Sedona Method
Post by Андрей Патрушев » Sun Apr 19, 2009 15:58
Ильхом Т. wrote:
Андрей Патрушев wrote:
Anonymous wrote:Cuba I downloaded the book, according to this source and do ... And on what source we should be doing ? :)
Yeah - the direct source. :)
Then I wonder how You realized from this book - what happens to Your feelings as a result of using the method?
Well, I think that this fact(take the example of any lack, any) should not cause feelings, both positive and negative, should not be invoked a desire to change it, and this fact loses its importance ... And what really should be ?
Well, if scrap :) to read the whole book - here is my article:
http://www.yugzone.ru/psy/sedona.htm
Ильхом Т.
Post by Ильхом Т. » Sun Apr 19, 2009 16:07
My question is does this refer to ?
do Not think that the use of the method man becomes like a emotionless doll, on the contrary, you regain the ability to feel strong and pure emotion, as in childhood, but not "preceives" to them for a long time.
I.e. feelings, desires and thoughts they will be executed, but they will not be as "authoritative" and will not be constantly spinning in your mind ? Do I understand correctly ?
Post by Андрей Патрушев » Sun Apr 19, 2009 16:09
Ильхом Т. wrote:my question is does this refer to ?
You are absolutely right. :) And because of this they finally begin to really work for You.
Ильхом Т.
Post by Ильхом Т. » Sun Apr 19, 2009 16:14
Ahh, of course !
And how to be with a sense of inner freedom, it has appeared, I have only once been accompanied by a kind of inner laughter and really felt some release, but it seems to be when the head comes a brilliant and very simple solution to the problem that troubled for a long time... But when you release the feeling that I'm working on at the moment, such feeling is not present and still felt some inner load !
Post by Андрей Патрушев » Sun Apr 19, 2009 16:21
Ahh, of course !
When the questions have been asked (and correctly set), the subconscious mind begins searching for answers. It is not always the answer comes at once... in addition, it is useful all the same, first to work on "basic emotions".
Ильхом Т.
Post by Ильхом Т. » Sun Apr 19, 2009 16:28
Ильхом Т. wrote:
Андрей Патрушев wrote: You are absolutely right. :)
Ahh, of course !
Okay, I'll try to wait and most importantly to hear the answers from the subconscious... sooner or later this technique is mastered, except that want and that desire to let go, too, fails! :) After three months, see what the results are. Thank You for the answers, good luck !
Эйси
Post by Эйси » Sun Apr 19, 2009 23:21
And I have experience the following. Started with the most basic emotions occur during the day, and when there was a time I thought about exploring, it worked. Initially it turned out with varying degrees of success, but when it became clear how the technique works and it is clear that it works, it's gone. When seen emotion I pay attention to it and begin to strengthen. Attention all directed at her. For example, if it's fear,I'm afraid, I think I'm afraid, but the main focus to keep on fear, because he is already with us, so let's not in hiding and let them all appear. Usually occurs in the body the same feeling, I have fear in my stomach. And here I'm exaggerating this fear and begin to feel in the abdomen, fear, stomach cramping. The mind tries to shift the attention to something else, you must try to look at the fear center. Then I begin to ask the question- "would I accept this feeling". At this time I look in the center of fear and invite him to enter me. That is, fear is energy, but we izbegaet and do not give part of yourself, although it is already in us. The main thing to watch in the centre of emotions and there comes a point when it becomes unbearable to endure. With fear I did so. One evening I felt a very total fear, I tried to work with him, but it was little bits, but this evening he appeared in the area of the belly, he was over the whole area of muscles. I worked with him, he raspall it as I could, but to be accepted he wouldn't. In the end, I got what felt fear in the abdomen as if podkovyrova. It is as the root of the tree vikorchovivat from the earth. And my fear as it shattered in the ground, but he still held tight to the roots. Two days later, I again felt fear, but he did not sit so firmly in the stomach. I began again to work with him, it was like a ball of gray energy in the abdomen. I began to accept it. Here I want to explain a little bit. With young and fresh emotions when I rabotat, they were either accepted or dispensed. Acceptance was similar to how the energy of emotions connected with me... in One word we are talking about integrity, this emotion is and she's already with me, but I can avoid her, ashamed of, to fear, to suppress, to actually separate themselves from the energy part, but what's the point, she's not going anywhere, so let them become a part of me, or rather not a part of me, part of it when we don't take them. Other emotions after acceptance wanted to let go, it felt right, I only had time to discuss the issues in any case for fastening. In case of acceptance I felt like the energy of negative emotions passed into positive energy,if you release something like flew out of me, a little grey energy. Then I realized that it is necessary to release, for example deep in the earth.
Returning. I began to take this energy, but she didn't want to become a part of me, the tension was huge. I lit this kāmoke very much, but he did not become a part of me (for some reason, it seemed to me that it should become a part of me). Then I thought maybe he wants to let go, and once asked a question about the release I felt from the abdomen, the energy leapt in the region of the solar plexus, chyast slipped his even higher.
After that I a little forgot all about it, but after 2 days I caught myself on the thought that oblaci belly there was a lightness and has not arisen during this time of fear, but in a situation when I should be afraid of the energy of the stomach moves into the solar plexus. Now I was angry)))
Part of the anger proskachila to the top, and through the heart chakra in the throat area, is in process now.<
Ильхом Т.
Post by Ильхом Т. » Sun Apr 19, 2009 23:34
ЭйСи wrote:And I have experience the following. Started with the most basic emotions occur during the day, and when there was a time I thought about exploring, it worked. Initially it turned out with varying degrees of success, but when it became clear how the technique works and it is clear that it works, it's gone. When seen emotion I pay attention to it and begin to strengthen. Attention all directed at her. For example, if it's fear,I'm afraid, I think I'm afraid, but the main focus to keep on fear, because he is already with us, so let's not in hiding and let them all appear. Usually occurs in the body the same feeling, I have fear in my stomach. And here I'm exaggerating this fear and begin to feel in the abdomen, fear, stomach cramping. The mind tries to shift the attention to something else, you must try to look at the fear center. Then I begin to ask the question- "would I accept this feeling". At this time I look in the center of fear and invite him to enter me. That is, fear is energy, but we izbegaet and do not give part of yourself, although it is already in us. The main thing to watch in the centre of emotions and there comes a point when it becomes unbearable to endure. With fear I did so. One evening I felt a very total fear, I tried to work with him, but it was little bits, but this evening he appeared in the area of the belly, he was over the whole area of muscles. I worked with him, he raspall it as I could, but to be accepted he wouldn't. In the end, I got what felt fear in the abdomen as if podkovyrova. It is as the root of the tree vikorchovivat from the earth. And my fear as it shattered in the ground, but he still held tight to the roots. Two days later, I again felt fear, but he did not sit so firmly in the stomach. I began again to work with him, it was like a ball of gray energy in the abdomen. I began to accept it. Here I want to explain a little bit. With young and fresh emotions when I rabotat, they were either accepted or dispensed. Acceptance was similar to how the energy of emotions connected with me... in One word we are talking about integrity, this emotion is and she's already with me, but I can avoid her, ashamed of, to fear, to suppress, to actually separate themselves from the energy part, but what's the point, she's not going anywhere, so let them become a part of me, or rather not a part of me, part of it when we don't take them. Other emotions after acceptance wanted to let go, it felt right, I only had time to discuss the issues in any case for fastening. In case of acceptance I felt like the energy of negative emotions passed into positive energy,if you release something like flew out of me, a little grey energy. Then I realized that it is necessary to release, for example deep in the earth.
Thank you very much for the detailed explanation !!! As I understand feelings can be let go immediately, but then it takes time ... ?<
Эйси
Post by Эйси » Sun Apr 19, 2009 23:48
In my case, fear in the subconscious probatively, or rather were prepared for the study itself. It is logical to assume that deep-seated basic emotions from not being worked out. By the way I want to say that everything I wrote is my experience, but I do not claim that I do everything right, with all the consequent. And something else happens, that one blind man leads another)))
Actually, I would like to hear from experts about my experience.
PS There appeared thoughts about acceptance and letting go. It seems to me that what is accepted is withdrawn or uberhottie part of our nature, but the fact that is released and goes to the outside, it is external program, engram, thought forms, tips, sushnosti. In General, that I have been working with awareness, but this technique is the real key.
Thanks to the authors and to Andrew for the Golden key!
Post by Guest » Wed Apr 22, 2009 1:02
Everyone who understands English and wants to learn the Sedona method - suggest download audiokursy. Better to start with the basic (+ abundance/relationship/health) course, and then you can download a bunch of advanced courses.
The basic course is for torrent.ru and advanced courses are on the pirate bay.
Download, enjoy, are exempt :)
I owner not really gone... the Method is not particularly worked. The audio course! - Yes! It worked. The difference is that doing exercises together with the lecturer. And the book I just read about the exercises, but not really doing them.
Andrew - will get even more benefit :) Although already done a lot. Over all I will not, but for myself - Thank you!
With respect.
Fedor
Post by Guest » Wed Apr 22, 2009 2:14
Eishi, I'm definitely not an expert, but will Express my opinion:
Accept and release essentially the same thing - the two polarities of a single action, or rather inaction :) I think you just have to stop "keep", "don't let go," whatever it is and wherever it is not wanted - inside or out. Often after the answer to the question "Can you/I accept this feeling?" is already happening spontaneous release. And even more, I like to catch the thought/feeling -> watch for some of the most basic desires it evokes (approval, control, etc.) and let them go.
ФедорМ
Post by ФедорМ » Wed Apr 22, 2009 2:16
Oh! Forgot to log in - it my two posts were :)
With respect
Fedor
Ильхом Т.
Post by Ильхом Т. » Thu Apr 23, 2009 16:49
I'd like to listen to an audio course, but I understand English very bad, I would have been glad if transferred !!!
ФедорМ
Post by ФедорМ » Sun May 03, 2009 2:07
Anyone who understands English very suggest Living Truth, after the basic course the Sedona... I'm just stunned even... Cool! :roll:
Post by Андрей Патрушев » Sun May 03, 2009 13:00
ФедорМ wrote:anyone who understands English very suggest Living Truth, after the basic course the Sedona... I'm just stunned even... Cool! :roll:
What does that mean? :) The network links many, mostly for music and some Baptists... There is a book Living the Truth of Dr. Keith Ablow. :?
ФедорМ
Post by ФедорМ » Sun May 03, 2009 16:42
what does that mean? :) The network links many, mostly for music and some Baptists... There is a book Living the Truth of Dr. Keith Ablow. :?
Glad to have the opportunity to help something to :)
The link is on PirateBay:
Direct link to Living your truth course - http://thepiratebay.org/torrent/4154196 ... le_Dwoskin
The link to the resource thepiratebay.org
There choose to search "All" and drive in Sedona -> Search.
Get out links to basic course and advanced courses. I continue to deal with speed of problems will not be :)
If you do not know how to use torrents (though I doubt :)) - will tell :)
With respect.
Fedor
Post by Андрей Патрушев » Sun May 03, 2009 17:46
Ah, thank you! Only torrent our College server blocks... :(
Карил
Post by Карил » Sun May 03, 2009 19:48
Andrei Patrushev
How do you what is more effective Sedona method or feasibility study?
ФедорМ
Post by ФедорМ » Sun May 03, 2009 21:31
http://rapidshare.com/files/228708636/L ... h.rar.html
MD5: BB72912023DA6FA10F0F18B69858D4D2
Filled Rapidshare. Download :)
Thank you.
Fedor
Post by Андрей Патрушев » Wed May 06, 2009 17:15
ФедорМ wrote:http://rapidshare.com/files/228708636/L ... h.rar.html
Thank you.
Fedor
Thank You, Fyodor.
We still have only the limit to 100MB a day (not diarrhea, so a scrofula... :oops: ) - you can even three parts to break? :?
Post by Андрей Патрушев » Wed May 06, 2009 17:21
Карил wrote:Andrei Patrushev
Both are good - one faster, the second more universal...
For example, I do vocals, but the teacher today has no voice (and I don't know music, but with a voice well obesiance :)), quickly rattled point, and here You are - the voice immediately came!
"Man is free when he has a choice." :?
ФедорМ
Post by ФедорМ » Fri May 08, 2009 1:21
you can still into three parts to break? :?
First p-a-a-ashel! :)
1. Download Link: Click here to download file
http://rapidshare.com/files/230356650/L ... 1.rar.html
MD5: D2BF76CE740F26032779967948DC8728
ФедорМ
Post by ФедорМ » Fri May 08, 2009 1:54
Second http://rapidshare.com/files/230359996/L ... 2.rar.html
MD5: 55B5B15609031CA05B5F05D71C2077A7
ФедорМ
Post by ФедорМ » Fri May 08, 2009 2:07
Third http://rapidshare.com/files/230369387/L ... 3.rar.html
MD5: C8AA8EFEC90B5DF9532FE29BC664FF31
Татьяна
Post by Татьяна » Sun May 10, 2009 16:16
Good day! Thanks to Frank for the audio course.only I'm not good at English.
Andrew! Hope for You!Make .please.an audio course in Russian.
