Brrr and brrrr again brrrАндрей Патрушев wrote:It's physically impossible.You just chose the mode "Clear", which is already loaded session are erased.
Then I do not understand anything, or so "good" was written FAQ on installation.
I connected machinko NOVA Pro 100 to my computer, checked it via the app.
The program told me that I have to masince there are 1000 segments = 100 sessions. Prior to that, I have no more sessions to mashinku never set.
Was somewhere the information that the built-in session cannot be erased.
I have created a list of 25 sessions (25 is the maximum which is in the window of the program), you have entered Your 14 sessions and an additional 11 from Photosonix, all the sessions I downloaded from the website of Psychotronic.
When you try to run the fix all these 25 sessions in the machine, the system issued the message - Output buffer too small for block. -> OK.
Then I began to add to the list in one session and loaded them into machinko team Download Session(Append).
After each download a separate session, in a specific window of the program indicated the reduction in the number of free segments and the number of sessions.
Before each subsequent download of a new session, I previously downloaded were deleted from the Windows programs list.
So I loaded up machinko 35 separate sessions, and after that, the program still showed that I machince is about 212 free segments.
So – or I did something impossible or this download of jammed built-in mashinku session (which was initially recorded upon delivery).
But I do remember that the forum was this information built – in session overwrite is impossible, and that machince there is additional free space which, optionally, you can add or remove a certain amount of new sessions
Check now – jammed if I preset session, I can not, because no device is, but remember that when scrolling through a section SPECIAL to machince, on the list are all supplied in the sale from P01 to P11, and then I installed with indices from P. 01 to P. 35, respectively.<
