Do not need anything special to do - machine will work well even in the case of almost complete loss of hearing in one (both) ear.Каляев И. wrote:Hello.
Please tell me how to use MM if one ear hears approximately two times worse than the other??? Maybe you need to change the balance to even out the sound or makes no sense at all to use a 1.5 MM on ear?
Popular questions and answers (FAQ)
Recently bought InnerPulse + ColorTrack glasses. For the past two weeks doing every day for 30-40 minutes. Beginning with the alpha sessions. I bought this device since the last time, became irritable, and my friend advised it to me as the best way to relax and calm down. And I really it helps, but I have this problem: during the sessions I feel very cold, and the room temperature is 26 degrees. I now spend a session lying down under a warm blanket, but it's not much help. Try using autosuggestion to induce a feeling of warmth, but leaves only a feeling of heat in the solar plexus, and in other parts of the body the sensation of cold soon increases. At the end of the session, the sensation of cold is only 20-30 minutes. Please advise what can be done about it. Sessions I listen to: r01-r06, p02, i02.
The only advice is to continue to do next (under the covers) - things will get better soon. Most likely you have too activated sympathetic nervous system.Тата wrote:recently Bought InnerPulse + ColorTrack glasses. For the past two weeks doing every day for 30-40 minutes. Beginning with the alpha sessions. I bought this device since the last time, became irritable, and my friend advised it to me as the best way to relax and calm down. And I really it helps, but I have this problem: during the sessions I feel very cold, and the room temperature is 26 degrees. I now spend a session lying down under a warm blanket, but it's not much help. Try using autosuggestion to induce a feeling of warmth, but leaves only a feeling of heat in the solar plexus, and in other parts of the body the sensation of cold soon increases. At the end of the session, the sensation of cold is only 20-30 minutes. Please advise what can be done about it. Sessions I listen to: r01-r06, p02, i02.
Yes, You are right! There were also a second wire. Excuse me, pleaseАндрей Кабанков wrote:Points connected with the machine wire Jack-Jack,used for connecting audio equipment.You have included should be 2,look in the bag,there are a lot of pockets.The one with the bend-points for bend just for convenience.But will fit any.We will give you a cord with the new order,but most likely you have it already should be.(It was in a bag along with sunglasses,at that time ,when we sent your order)
Tell me, how to run sessions in addition to or independently with other listening devices. What to choose in mm (which team)?
Ната13
The previous one - that's me! The issue is likely to Andrei Patrushev, or all who can comment. Started on mm with the alpha sessions as recommended. Doing 5 days. Can't say that something has changed for the better. Understand that too little time has passed, but the changes are there - I became more lethargic, but still the mood swings (that burst of joy is unclear, the irritated). Moreover, the state of sullenness and irritation, moments possess me so much, that it becomes somehow prickles
. My husband is also involved, and in my experience it sounds like one of mine. I think that's going to say: "What have you slipped me?" Do a day for 30-40 minutes. Morning and evening we listen to different alpha session. I don't know, maybe the stars are wrong, or the General situation with the crisis, or all of the matter in mm (as the saying goes: "the healing always comes aggravation"). What say you, people? Who started with mm? Can spit on the built-in session and to start with Petrushevsky? Or is it just the adjustment period? Please help me!
This is a normal period of adaptation and processing negative experiences.Keep on practising,soon pochuvstvuete change.During the session try to relax and about what not to think, or at least to think about pleasant and happy!!!!Ната13 wrote:Previous one - that's me! The issue is likely to Andrei Patrushev, or all who can comment. Started on mm with the alpha sessions as recommended. Doing 5 days. Can't say that something has changed for the better. Understand that too little time has passed, but the changes are there - I became more lethargic, but still the mood swings (that burst of joy is unclear, the irritated). Moreover, the state of sullenness and irritation, moments possess me so much, that it becomes somehow prickles. My husband is also involved, and in my experience it sounds like one of mine. I think that's going to say: "What have you slipped me?" Do a day for 30-40 minutes. Morning and evening we listen to different alpha session. I don't know, maybe the stars are wrong, or the General situation with the crisis, or all of the matter in mm (as the saying goes: "the healing always comes aggravation"). What say you, people? Who started with mm? Can spit on the built-in session and to start with Petrushevsky? Or is it just the adjustment period? Please help me!
Ната13
Ната13
With a guide can set goals for listening.GuestDrives A. Patrushev to combine with sessions is not necessary.To listen to separately,if the disc recorded audiostrobe signal may include a mm mode decoder and listen through it,and you can just listen to CDs through your headphones with audio media.
What drives A. Patrushev with audiostrobe? In the "Healing" is? So I can't figure out how to reduce the time of wire through a mm. Why, then, write that mm is the effeciency? But if the disk is full audiostrobe, how to run it, I do not understand.Just press PLAY? Then the embedded session to run in parallel, and I want a separate disk to listen to.Dimas wrote:Gostinici A. Patrushev to combine with sessions is not necessary.To listen to separately,if the disc recorded audiostrobe signal may include a mm mode decoder and listen through it,and you can just listen to CDs through your headphones with audio media.
Found already on the forum that "Healing" SS gate. Th so my glasses don't blink? Where are the instructions specific how to listen audiostrobe on mm? Where to tyknut what to press?Guest wrote:
And what You did to machine no instruction in Russian???Anonymous wrote:Found already on the forum that "Healing" SS gate. Th so my glasses don't blink? Where are the instructions specific how to listen audiostrobe on mm? Where to tyknut what to press?Guest wrote:
игорь_123454321
Technical question
All models (including positioning as new) connect to a computer via COM port. He is already 3 years old not used in computers. How do you explain it? How to connect to a computer that does not have a COM port
Hello dear!
Help to deal with the issue. About a month ago I bought InnerPulse + glasses of premium white, used, was used, and only recently started to notice that when setting the brightness level on the small led in the left eye is brighter than the right. when you listen to audiostrobe drives that give more brightness and everything is fine, but when you just want to relax and brightness make less the fact is that, the left LEDs continue to flash, and right just don't burn. or for a little more brightness still left eye shines brighter than the right, which sometimes prevents relaxation. Although it seems to be sometimes in some parts of the sessions, both eyes Shine with the same brightness
Prompt please - whether it should all work, and different brightness spelled out in the sessions, or is it a glitch or any problem?
Thank you in advance for the clarification.
This is not a defect and not the design of the sessions, and especially the schematics. Most often this can be remedied through the options menu - there you can change the ratio of brightness on the eyes.Anonymous wrote:Good day dear!
Ната13
My mind-machine???
Ната13
Yes, through her I have bought mm. So only to send? I thought maybe everything is just corny and there's some magic button (or magic combination of clicks) to click - and BAM!- all right. Well, apparently, I'm naiveDimas wrote:Ната13
Send the device to us by mail or you can contact Irina Yakovenko (she lives in Kiev),her contacts You can find on this forum or in the BUY section of this website,and through it to give us.We'll see what happened with Your device and will send You a new one.
Ната13
Well, if we knew why,we could click on the button.full set do not need to send only the device and glasses.From the network do not have to listen.You must first charge the device,only then start work.Actually,judging from Your description,it says that You have just drained the batteries.Please CAREFULLY read the last page of Your instruction manual.And don't forget,if You have glasses color Track,the brightness on the instrument should ALWAYS be set at maximum.Brightness adjustment is performed on the glasses by pressing and holding the LOWER button.
Ната13
Dima, You know, yesterday I turned it on (a couple of days were very busy and hands to mm is not reached), and it worked!Dimas wrote:Well, if we knew why,we could click on the button.full set do not need to send only the device and glasses.From the network do not have to listen.You must first charge the device,only then start work.Actually,judging from Your description,it says that You have just drained the batteries.Please CAREFULLY read the last page of Your instruction manual.And don't forget,if You have glasses color Track,the brightness on the instrument should ALWAYS be set at maximum.Brightness adjustment is performed on the glasses by pressing and holding the LOWER button.
P. S. It would be a shame if I sent You to the end not understanding that the problems, in General, and no
