disc-Hypnosis + private set.
либрексен
Post by либрексен » Sun Jun 28, 2009 2:56
Thanks for the reply Andrew. How do you feel about the BWG and presets them available online?
Post by Андрей Патрушев » Sun Jun 28, 2009 11:12
либрексен wrote:Thanks for the reply Andrew. How do you feel about the BWG and presets them available online?
To the BWG presets and I am not him. :)
Post by Guest » Sat Aug 01, 2009 22:16
Question to Andrew.
What can You say about the combination of listening to Your CD "Music for hypnosis and self-hypnosis" and at the same time reading "the Healing set" In Sytin?
Maybe you recommend other drives from Your series on the background listening which you can use vision(reading moods or affirmations).
Thank you!
Andrew from Omsk.
Post by Андрей Патрушев » Mon Aug 03, 2009 14:38
Anonymous wrote:the Question to Andrew.
Thank you!
Andrew from Omsk.
To your health! :)
Giprotrans (Theta meditation).
Дрю Генныч
Post by Дрю Генныч » Sat Aug 08, 2009 20:00
This again Andrew from Omsk(only after registration :) )
Andrew, please explain briefly the procedure: you must first listen to the wheels for introduction of the brain to the desired state (how long?), and then start reading; you can also simultaneously start listening to CDs and reading moods? :)
Post by Андрей Патрушев » Sun Aug 09, 2009 17:24
Дрю Генныч wrote:This again Andrew from Omsk(only after registration :) )
I could go either way. :)
While listening it is optimal to start in the 6th minute.
Дрю Генныч
Post by Дрю Генныч » Wed Sep 02, 2009 20:30
Andrew,Hello! :)
There is a question: if I plan for one evening to practice a few audio sessions,what the interval should be between them? Obviously,the brain must rest , to be distracted from the previous session before proceeding to the next.
Thank you very much for the answer! :)
Post by Андрей Патрушев » Thu Sep 03, 2009 13:03
Дрю Генныч wrote:Andrey,Hello! :)
Hello!
Three hours :?
Ванчез
Post by Ванчез » Mon Sep 14, 2009 19:05
I think that's also to do self hypnosis, but the question appeared. There is a CD "Hypnotic trance" from the theta meditation is the ROM this theme "music for hypnosis and self-hypnosis".
Specific questions:
CD "music for hypnosis and self-hypnosis" also enters into a state of theta waves. Well, ie can I use it and then some realties the disk from theta series(well, suddenly).
Which one is more effective or what you want to use for self-hypnosis? And generally than they differ? :)
Post by Андрей Патрушев » Tue Sep 15, 2009 16:38
Ванчез wrote:I was thinking also to do self hypnosis, but the question appeared. There is a CD "Hypnotic trance" from the theta meditation is the ROM this theme "music for hypnosis and self-hypnosis".
Specific questions:
Music for hypnosis and self-Hypnosis is the alpha drive. Should start with it for 3 weeks...
Дрю Генныч
Post by Дрю Генныч » Wed Sep 16, 2009 20:10
Hello,Andrey! :)
Your opinion about Psi-Technology & Latentframe Products ?
Thank you very much! :)
Post by Guest » Wed Sep 16, 2009 21:22
drew give me a link to their products or sites, and if even they do not know ;)
Post by Андрей Патрушев » Thu Sep 17, 2009 12:38
Дрю Генныч wrote:hi Andrea! :)
Man is free when he has a choice, provided the choice he makes himself... :?
АндрейН
Post by АндрейН » Fri Oct 08, 2010 8:58
Good day, and drive with self-hypnosis more effective for a couple of hours before bedtime to listen to, or just at bedtime ?
Or in the morning immediately after sleep ?
Just finished listening to disc Explorer, can from in hypnosis go ?
Post by Андрей Патрушев » Fri Oct 08, 2010 9:24
Andrein
CD with self-hypnosis more effective to listen to in the afternoon, and so after listening it was not necessary to do work requiring concentration and driving.
You can go directly to this disc.
АндрейН
Post by АндрейН » Fri Oct 08, 2010 14:57
Andrew and still effectively before going to bed to listen, or is it better to leave 2 hours after listening to sleep.
Post by Андрей Патрушев » Fri Oct 08, 2010 15:21
АндрейН wrote:Andrew but all the same effectively before going to bed to listen, or is it better to leave 2 hours after listening to sleep.
If trouble falling asleep does not occur before bedtime, if there is, within 3-4 hours.
СтАвР
Re: disk-Hypnosis + private set.
Post by СтАвР » Tue Aug 27, 2013 17:41
why when listening to the disc is starting to hurt right hemisphere?
Post by Андрей Патрушев » Tue Aug 27, 2013 21:08
СтАвР
Post by СтАвР » Wed Aug 28, 2013 1:15
Yes, actually it was only with this drive, with the Navigator all the rules, citirano :?
maybe just the goal itself during hypnosis affects :?
Post by Андрей Патрушев » Wed Aug 28, 2013 8:15
СтАвР wrote:maybe just the goal itself during hypnosis affects
Yes, it can be. You have to be very precise and accurate in terms of wording.
СтАвР
Post by СтАвР » Wed Aug 28, 2013 19:52
well, think that can be corrected
thank you :)
Тимур И
Post by Тимур И » Sun Sep 15, 2013 15:46
Hi I want to ask You this question. Can I use the installation to achieve awakening without physical movement of the body? If for example I give myself this: "When waking from sleep, my body remains completely without movement". And yet, not too long formula? Or maybe like something shorter you can display the meaning of the installation?
Post by Андрей Патрушев » Sun Sep 15, 2013 19:20
Timur And
Hello.
Importantly, You arranged it. You can, for example, - "upon awakening my body one minute motionless"...
Тимур И
Post by Тимур И » Mon Sep 16, 2013 13:18
Thank you. You are right, I like it and did not think that it is possible and easier)
