I have a Photosonix NAVIGATOR stuck...
Post Reply
Мирас
Post by Мирас » Tue Jul 18, 2017 22:50
Minmachine NAVIGATOR Photosonix stuck and will not turn on I press the power button only the led lights up and all, how to reboot?
димыч
Has thanked: 7 times
Been thanked: 16 times
Re: I Have a NAVIGATOR Photosonix hung...
Post by димыч » Tue Jul 18, 2017 23:37
Batteries to get?
User avatar
Has thanked: 31 times
Been thanked: 129 times
Contact:
Post by к-13 » Wed Jul 19, 2017 0:13
Мирас wrote:Minmachine NAVIGATOR Photosonix stuck and will not turn on I press the power button only the led lights up and all, how to reboot?
But if charging stick and wait for 15 minutes?
Мирас
Post by Мирас » Wed Jul 19, 2017 10:50
Loaded, and pulled the battery to no avail...
Алексей Крячко__
Been thanked: 17 times
Post by Алексей Крячко__ » Wed Jul 19, 2017 11:05
If the AC adapter connected this occurs then..
You probably have the device set to programming. Then, when the enable indicator should illuminate on the top and there should be nothing on the screen. To get out of this situation after downloading the firmware in this device. The procedure is described
the instructions for programming
The latest version of firmware 2.00
https://yadi.sk/d/I4urQYFRqRpCp
Manual to the latest firmware versions (2.00 and 2.01) :
https://yadi.sk/i/cmMskfT1qV4Cm
Software for your computer to load the firmware in the instrument (version 2.1)
https://yadi.sk/d/XhnbI8H1mndVB
Мирас
Post by Мирас » Fri Jul 21, 2017 18:57
Алексей Крячко__ wrote:If with the AC adapter connected this occurs then..
My GPS is not detected in device Manager...
Has thanked: 134 times
Been thanked: 556 times
Contact:
Post by Андрей Патрушев » Mon Jul 24, 2017 9:23
Miras
And you case the flash drive is not lost (or put in crooked)?
Ольга Ковкова
Post by Ольга Ковкова » Mon Nov 13, 2017 18:20
What it means to me on any program the same squeak? spooky squeak((
Contact:
Post by Андрей Патрушев » Mon Nov 13, 2017 19:00
Olga Kovkova
The most simple and quick (and often helps) - remove the battery and reinsert it. If does not help, then do a reboot (see instructions). If that doesn't work, send me (to bring) to the office.
Алексей Крячко__
Post by Алексей Крячко__ » Sun Nov 19, 2017 20:36
Ольга Ковкова wrote:What do you mean I have to any program, the same squeak? spooky squeak((
Squeaking in headphones ? It can be if you headphones hooked up to the connector points. And would be a terrible squeak in the headphones, overload of the battery, it is possible the headphone output of the system. The first thing to do is to check the correctness of connection points and headphones.
Мирас
Post by Мирас » Fri Nov 24, 2017 10:48
Minmachine NAVIGATOR Photosonix hung, but I already said that. But the Board Alexey Kryachko__ did not help
I connected it to my computer, reflash program programmer2_1 and NO-TH-TH... After pereproshivka programmer2_1 does not define the device and it remained the same mode of thought... when you turn on indicator lights up (white led on the top) and nothing appears on the screen.
What to do in this case?
PS. by the way can you send the link(s) for a full list of drivers and then I set a disk with drivers was not.
User avatar
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Fri Nov 24, 2017 13:12
Мирас wrote:PS. by the way can you send the link(s) for a full list of drivers and then I set a disk with drivers was not.
It never happened. WHY WRITE HERE WHEN YOU HAVE A SPECIAL THEME?viewtopic.php?f=38&t=5320
That's about the update :Alexey Kryachko__
Алексей Крячко__ wrote:so, to summarize what I have at the moment :
About firmware 2.01 fixes : this firmware is programmed only in newly manufactured appliances, as it requires modifications of the hardware. Accordingly, in the previously released devices it makes no sense to write, so downloading it does not spread.
Difference 2.01 from 2.00 only possible to change the spectrum of the noise. Everything else is identical to version 2.00.
Алексей Крячко__ wrote:to change the firmware you need
1. download version 2.00 and unzip.
2. download the current program for updating the firmware (version 2.1)
3. to put a file embed_navigator_v200.bin there, where is the exe program file for flashing
4. edit the file f_write.txt instead of lines embed_navigator_v120.bin should be written embed_navigator_v200.bin
5. start navprog2n1.exe after set the device in programming mode and connect it to the USB, then turn on (on the device should be a blank screen, the backlight is lit and the orange led illuminated).
If you do not understand , call the office, we can help. You have not written what you have Navigator 1 second or a new (updated design)?<
Алексей Крячко__
Post by Алексей Крячко__ » Fri Nov 24, 2017 17:55
It was necessary to begin certainly with this :
ЛИЛИЯ-Р wrote: You have not written what you have Navigator 1 second or a new (updated design)?
Because if you flashed Navigator 2 the firmware listed (as I pointed out, assuming that you have the 1st option, because they are by far the most common), then of course it won't work and to determine if the programmer is not (because after you activate the firmware, even incorrect, it exits programming mode and communication with the computer of course does not support). Then the only option is to transfer the device programming mode and hardware to re-flash the correct firmware. But can be certainly something with the device (firmware just without some action itself is not reset). Write your email address in personal messages, we will understand what to do next.
Post Reply
