ColorTrack glasses where to fix
Good afternoon. ColorTrack glasses ,stopped working the led.Where can be repaired? Ekaterinburg.Thank you for any help.
- Has thanked: 1 time
- Been thanked: 182 times
- Contact:
Re: ColorTrack glasses where to fix
Can be repaired in Moscow with us.
Try pressing button increase the brightness of points a few seconds is often that brightness removed to zero, and it is perceived as a failure, although you just need to increase the brightness of the zero position.
Tried that, even changed the connection cable,the result is zero.The feeling that the diodes came to an end because they then would blink then stop blinking and slowly faded.
- Contact:
Definitely not the case for diodes, as their resource is not comparable with the life of the glasses.
And in Your opinion , what could be the reason and what should I do? Points are not dropped not wet at all were treated very carefully.
- Contact:
I think the most simple and effective is to send them to us for diagnostics and repair. You can also turn to your local professional electronics.
A specialist to repair them is easy, we have engaged in this our engineer and Navigator. Send for repair to the manufacturer is expensive, subject to postage at the new rate.
Understand ,and where to send address details?
- Contact:
129329, Moscow, Kolskaya street building 1 building 3 , LLC "Computer"
tel 499-180-99-52
tel 499-180-99-52
