Page 1 of 1
I kazhtsya, she broke down
Posted: Thu Apr 12, 2012 2:24
by просто Надя
Good night everybody!
please tell me how to be: my glasses don't work when I try to listen to audio strobe disc. Moreover, this strange behavior of points applies only to disks. Session loses as expected: and flashes and makes noise.
Tried to play all the discs which I bought, glasses no one does not react. Audio listen gates not the first day, therefore, the option with the incorrect wiring and setting the wrong mode is excluded.
I understand that MM thing with a fine organization, so the old working method of resurrection things (drop it on the floor and let the leg) is not used.
I bought a MM a month ago. Tell me how to bring my baby to life? Maybe MM can somehow be healed?
Hope for Your speedy help!
Re: I kazhtsya, she broke down
Posted: Thu Apr 12, 2012 2:43
by просто Надя
absolutely, because of headphone sound is
Posted: Thu Apr 12, 2012 2:51
by просто Надя
okay, thank you!
Posted: Thu Apr 12, 2012 10:15
just Nadia
Hello.
Try to put maximum volume on the player and see (nothing wearing :)) - will respond to the points or not. If not, then burned audiostrobe-decoder - send to the office for repair, or exchange under warranty.
Posted: Thu Apr 12, 2012 10:43
by просто Надя
Andrew, I tried everything before to get help.
Thank you for your prompt answers! Will have to pass.
Posted: Thu Apr 12, 2012 10:51
by Андрей Кабанков
just Nadia,drove to the office,if not working will change.
According to statistics,99% of the time in the office everything works :)
Posted: Fri Apr 13, 2012 9:24
just Nadia
And what is your device? If Navigator, remove glasses, headphones and power supply, then two times to turn off and turn on the device (you can just remove the battery and insert back). Attach sunglasses and headphones all work.
Posted: Fri Apr 13, 2012 19:18
by просто Надя
I have a Nova Pro 100. Could it be the reason that I lost the disk not through the player and through the PC (player no)?
Posted: Fri Apr 13, 2012 19:35
просто Надя wrote:I have a Nova Pro 100. Could it be the reason that I lost the disk not through the player and through the PC (player no)?
Yes, it can. Built-in sound cards are usually poorly reproduce high. Try the EQ in the player to raise a maximum of the last strip.
Posted: Fri Apr 13, 2012 20:58
by просто Надя
will. Andrew, thank you for Your professionalism! For drives separately shake hands )
Posted: Mon Apr 16, 2012 11:00
by просто Надя
Friends, thank you all for the help! You were right about the computer - player everything works )
