Page 1 of 1
InnerPulse. Cal. slowing down the breathing sessions.
Posted: Sat Jan 09, 2010 16:45
by Дубосарский Виктор
Hello!
I have a couple of questions:
1. Can't change cal. slowing down the breathing sessions. The default is 1.5 and I would like more. After the 10-second countdown, press SELECT a few times, but OPL does not appear. Does anyone know what could be wrong?
2. Can InnerPulse to fill a custom breathing session? If Yes, where them to take?
Thanks in advance for the answer.
Sincerely yours, Victor.
Posted: Sun Jan 10, 2010 1:55
by Нетрезвый Сурдопереводчик
start the countdown is not necessary.the "down" button to get oPl and set up.
custom breathing sessions you can't put
Posted: Fri Jan 22, 2010 0:04
by n
Simpler to write session
Code: Select all
;breath
1 0:00.5 0.25 bb IN 43 50 85 0 none 0 none 0
2 0:15.0 PSu 7.83 43 24.0 IN 50 85 85 none none 8 10
3 0:01.0 PCh 15.0 48 1 IN 50 28 85 0 none none 10
4 0:07.0 PCh 13.0 60 5 IN 50 14 85 none 0 none 10
5 0:PCh 01.0 15.0 IN 5 48 50 28 100 none 0 none 10
6 0:43 PSu 15.0 24.0 7.83 IN 50 85 85 none none 0 10
7 0:01.0 10.0 PSu 48 CR 50 28 100 none 0 none 10
8 0:05.0 PCh 8.5 CR 5 60 85 50 14 0 none none 10
9 0:01.0 10.0 PSu 48 CR 50 28 100 none 0 none 10
10 0:43 PSu 7.83 15.0 22.0 IN the 50 85 85 none none 8 12
11 0:01.0 15.0 IN PSu 60 50 28 100 none none 0 12
12 0:PCh 10.0 13.0 54 5 IN 50 14 85 none none 0 12
13 0:01.0 15.0 IN PSu 60 50 28 100 none none 0 12
14 0:43 PSu 22.0 15.0 7.83 IN 50 85 85 none none 0 12
15 0:01.0 PSu 10.0 CR 60 50 28 100 none none 0 12
16 0:PCh 10.0 8.5 54 5 CR 14 85 50 none none 0 12
17 0:01.0 PSu 10.0 CR 60 50 28 100 none none 0 12
18 0:43 PSu 7.83 15.0 26.0 IN 50 85 85 none none 8 15
19 0:02.0 PSu IN 50 15.0 60 28 100 none none 0 15
20 0:PCh 10.0 13.0 54 5 IN 50 14 85 none none 0 15
21 0:02.0 PSu IN 50 15.0 60 28 100 none none 0 15
22 0:43 PSu 15.0 26.0 7.83 IN 50 85 85 none none 0 15
23 0:02.0 PSu 10.0 CR 60 50 28 100 none none 0 15
24 0:PCh 10.0 8.5 54 5 CR 14 85 50 none none 0 15
25 0:02.0 PSu 10.0 CR 60 50 28 100 none none 0 15
26 0:04.0 PSu 7.83 43 10.0 IN 50 85 85 none none 12 15
27 0:03.0 13.0 PSu 32 IN 50 14 85 none none 0 15
28 0:04.0 PSu 7.83 43 10.0 IN 50 85 85 none none 0 15
29 0:03.0 13.0 PSu 32 IN 50 14 85 none none 0 15
30 0:04.0 PSu 7.83 43 10.0 IN 50 85 85 none none 0 15
31 0:15.0 12.0 PSu 36 IN 87 14 100 none none 0 15
32 0:04.0 10.0 7.83 PSu 43 IN 50 85 85 none none 0 15
33 0:03.0 PSu IN 7.5 32 50 14 85 none none 0 15
34 0:04.0 10.0 7.83 PSu 43 IN 50 85 85 none none 0 15
35 0:03.0 PSu IN 7.5 32 50 14 85 none none 0 15
36 0:04.0 7 43 10.0 PSu.83 IN a 50 85 85 none none 0 15
37 0:15.0 PSu IN 7.5 32 50 14 85 none none 0 15
38 0:30.0 PSu 7.83 43 13.0 IN 50 0 85 none none 2 7
39 0:30.0 PSu IN 7.83 13.0 40 50 0 85 7 0 none none
40 0:00.5 43 bb IN 26.0 7.0 50 0 85 0 0 none none
A piece of viloma pranayama
Code: Select all
breath_3_3
1 0:00.5 0.25 PSu IN 43 50 85 0 none 0 none 0
2 0:04.0 PSu 7.83 43 10.0 IN 50 85 85 none none 12 15
3 0:02.0 13.0 PSu 32 IN 50 14 85 none none 0 15
4 0:04.0 PSu 7.83 43 10.0 IN 50 85 85 none none 0 15
5 0:02.0 13.0 PSu 32 IN 50 14 85 none none 0 15
6 0:04.0 PSu 7.83 43 10.0 IN 50 85 85 none none 0 15
7 0:40 13.0 15.0 PSu IN 87 14 100 none none 0 15
8 0:04.0 10.0 7.83 PSu 43 IN 50 85 85 none none 0 15
9 0:02.0 PSu IN 7.5 32 50 14 85 none none 0 15
10 0:43 PSu 04.0 10.0 7.83 IN 50 85 85 none none 0 15
11 0:02.0 PSu IN 7.5 32 50 14 85 none none 0 15
12 0:43 PSu 04.0 10.0 7.83 IN 50 85 85 none none 0 15
13 0:15.0 PSu IN 7.5 32 50 14 85 none none 0 15
14 0:00.5 43 7.0 38.0 PSu IN 87 0 100 none none 0 0
