Page 1 of 1
Posted: Sun Mar 01, 2009 17:44
by вход
Hello!
Friendly, to anyone with a question. You want to buy a mind machine, in order to study, rest, and prepare themselves to certain actions. BUT there is a need in playing your music assortment.
So, what does the machine function so-called adapter or Converter? I mean that by connecting the same MP3 player using a mind machine to play music with superimposed range of the machine. While looking for such an option.
Posted: Sun Mar 01, 2009 18:05
by Андрей Кабанков
вход wrote:hi All!
To any model, you can connect an external audio source.
Listen to the session,accompanying her favorite music.
It is recommended that the volume level of the session to 15% of the volume myziki.
Read more here
http://www.mindmachine.ru/viewtopic.php?t=94&start=0
Posted: Sun Mar 01, 2009 18:15
by вход
Андрей Кабанков wrote:вход wrote:To any model, you can connect an external audio source.
Okay, thanks
I understand you yourself use the car..? Say, the session occurs in the audible range or mixed with music? That is, I want to present the process as it happens.
And the sessions are programmed, right? If so, is there a software for Mac?
Posted: Sun Mar 01, 2009 18:21
by Андрей Кабанков
In the machine already have the session written by professionals.You can adjust their duration in line with the duration of the song.
There is software for writing your own sessions,writing them is easy,just need to know what to write.It is much more difficult
To do that ,without having proper knowledge is not advised.
About Mac I don't know.
All of course occurs at carrier frequencies in the audible range.
Posted: Sun Mar 01, 2009 18:42
by вход
So just to write session won't of course, but in the future will be useful. Soft paid as I understand from the link to the article is of course worse. But in General the answers received and thanks for that. I would take.
Posted: Sun Mar 01, 2009 20:58
by Андрей Кабанков
Posted: Sun Mar 01, 2009 21:10
by вход
Posted: Mon Mar 02, 2009 2:47
by вход
Andrew, here you are a competent person on the issue MM. I had a thought; a person perceives a sound in the range of 16 Hz to 22 thousand kilo-Hertz, so do basically headphones with similar ranges. Of course for foodies and professionals, there are exceptions, take the same Ultrasone - there is a very good model at a good price. And even these headphones are not lose such a range as for example; 1, 2.5, 0.25 Hz, etc.
It is logical to assume that the same session for deep relaxation will simply be ineffective due to a lack of functionality of the headphones. Of course I could be wrong, because specializers in another area, just compare and make a conclusion. What do you say?
Posted: Mon Mar 02, 2009 13:11
by Dimas
entrance
Podnimatel read about how binaural beats and You will understand that sound frequencies with binaural waves-are two different things.
Posted: Thu Apr 16, 2009 0:12
by чайник
Hello. I just found this information about MM, did not check the details, but I have a question - through the use of MM laid down listening to music, music, etc. things (i.e. sounds made by musical instruments) or something I don't understand. Thank you in advance.
PS For me the issue of principle - I don't listen to music for religious reasons.
Posted: Thu Apr 16, 2009 10:02
чайник wrote:Hello. I just found this information about MM, did not check the details, but I have a question - through the use of MM laid down listening to music, music, etc. things (i.e. sounds made by musical instruments) or something I don't understand. Thank you in advance.
No, the music is there can use any and only if you want. Technology is a pulsating sounds and light flashes.
Posted: Thu Apr 16, 2009 10:27
by Guest
чайник wrote:PS For me the issue of principle - I don't listen to music for religious reasons.
what you listen from the mind of the machine - can not be called music.... it just sounds.... sometimes they overlap, the sounds of nature...
there are discs in the catalog of the laboratory of Tomatis there yeah.... there on music (not songs tili tili Trali Vali and good quality relax music, binaural beats overlaid)
and what kind of religion is that which prohibits listening to the sounds produced by musical instruments????
or do you decided to score the music? in every religion of the world there are sounds (in Buddhism, when you sing the mantra om is always used bells, drums and other various instruments... in Catholicism it is a body....and so on....
what religion is this which prohibits listening to the sounds produced by musical instruments????
going forward
Posted: Mon Apr 20, 2009 4:01
by Абай
Hello dear!
Very interesting! Stumbled on info about MM. Decided to buy it. Advise what model to buy? I need to learn, and quick thinking. What is the effect, write it? Is it worth to buy?
Sincerely,
Abay
Posted: Mon Apr 20, 2009 11:20
by Dimas
Abay
For personal use is more suitable to model the inner Pulse points or premium Kolor track..and about the effects then the whole forum!:)
Posted: Mon Apr 20, 2009 20:29
by Иван2
... and when writing that session, he can write, it reminds me kind of...only seven notes, he can
Posted: Sun Jun 14, 2009 2:36
by андрей69
With mind machine, he probably will understand what nafik not need a religion which prohibits you to listen to music
In a couple of books on self-development a lot and quickly understand all at once,in the normal state, probably on the understanding of these knowledge and attitudes would take years.
