Page 1 of 1
Who can help with the repair of the NOVA PRO?
Posted: Mon Jul 07, 2008 14:04
by Табби
Good day! I have a mind machine NOVA PRO 100 (bought in USA), but there is a problem: the machine stopped working. Can someone tell me who to contact to repair? Thank you
Re: Who can help with the repair of the NOVA PRO?
Posted: Mon Jul 07, 2008 14:40
by Андрей Кабанков
Табби wrote:Good day! I have a mind machine NOVA PRO 100 (bought in USA), but there is a problem: the machine stopped working. Can someone tell me who to contact to repair? Thank you
The manufacturer can contact
PHOTOSONIX
2420 Gundry Avenue
Signal Hill, California
90755
Toll Free Number: 1-800-258-2566
International Telephone: 562-981-8800
Fax: 562-981-8810
Email:
info@PHOTOSONIX.com
Posted: Mon Jul 07, 2008 14:49
by Табби
Thank you! And here in Yekaterinburg, someone can help?[/quote]
Posted: Wed Jul 09, 2008 11:16
Табби wrote:Thank you! And here in Yekaterinburg, someone can help?
[/quote]
And You have determined that it at You broke? There is a possibility that You drained the battery, or did this several times and You have it "died". In this case, the device will not work even from the network (by the way, there should be checked) until you change the battery (or just throw).
PS Batteries are on sale there for Gagarin (near Lenin Ave.)
Posted: Mon Sep 15, 2008 23:14
by Торит
Андрей Патрушев wrote:Табби wrote:Thank you! And here in Yekaterinburg, someone can help?
PS Batteries are on sale there for Gagarin (near Lenin Ave.) [/quote]
I have a similar problem with the inner pulse: the batteries are dead and also flowed inside the machine. After the replacement, MM is no longer included in any way. It is possible to do anything (warranty repair for example) or what to hope?
Posted: Tue Sep 16, 2008 9:10
by Андрей Кабанков
This is not a case of warranty.
Posted: Tue Sep 16, 2008 15:07
by Сергей_А
I Have a similar problem with the inner pulse: the batteries are dead and also flowed inside the machine. After the replacement, MM is no longer included in any way. It is possible to do anything (warranty repair for example) or what to hope?
Do not insert more batteries and not plugged in. If not a warranty repair, you can try to take to any repair shop for electronics (life technology, honeycomb phones). But the main thing on sharazhki not to run...
Posted: Mon Nov 17, 2008 5:35
by гость X
Андрей Патрушев wrote:There is a possibility that You drained the battery, or did this several times and You have it "died". In this case, the device will not work even from the network (by the way, there should be checked) until you change the battery (or just throw).
Soviet engineering genius.
Current batteries, and dying batteries in devices for poltyschi have.e. just should not exist as a class.
Posted: Mon Nov 17, 2008 11:22
by Александр1
guest X do you shovels genius.
Current batteries are a sign of the Chinese sherpotreb.
Posted: Mon Nov 17, 2008 12:31
by гость X
the sherpotreb
It is strange that no one this case is not surprising. All reacted, as if it should be.
What kind of batteries are such that cannot be safely discharged? Nonsense.
No, maybe someone that level of quality usual, do not dare to insist...
Posted: Mon Nov 17, 2008 13:09
гость X wrote:the sherpotreb
The battery, like any other thing that requires careful and proper treatment. Acid batteries (even cheap, though expensive) really do not like full discharge
on a regular basis.
For example, in my machine the same exact battery worked for 10(!) years. By the way, in the message Tabby doesn't say how much he worked his machine with this battery.
As for batteries, their every purchases based on their perceptions of feasibility.
Posted: Mon Nov 17, 2008 14:11
by Dimas
Yeah,at least the Chinese batteries,even Hawaiian...in iPhone to insert the accum from Taiwan and pray that he is not rushed in the pocket,and if it blows up, sure,iPhone Chinese shirpotreb(although it is "native" assembled in China:))))))))iron logic...
Posted: Mon Dec 15, 2008 0:20
by Ростислав
By the way batacosa which came with innerpulse Chinese I have worked for a maximum of 4 hours max! Suggest it is better to durasel to fork out for 2 weeks also and still alive! Well, or the batteries are good to take!
