Help for newbies
I'm a little confused.
What is the amps. what is the role of MM itself, and what the different drives?
- Князевский
Re: Help for newbies
MM coach (shows) the brainГенерал wrote:I'm a little confused.
drives the same, but MM is more diverse,and included with the discs more accurately.
it is a pity to spend money immediately? buy rims A. Patrushev, as you feel that it's not...b - take MM.
That there a bit in another problem, that you have written that" complex discs"... Maybe somewhere painted complexes? But if I turn the program on MM "SLEEP (SLEEP)" and start listening to "energetic"?
This something is the essence of what drives what sessions so to speak supposed to work? Or alternately listening session on MM, and then the wheels Patrushev. The old somewhere is about?
And MM take it already settled 100%, you only have to choose the right wheels which are more as you stated "more accurately would be to train the brain".
The above example is only to more clearly describe the situation.
Dear General,
Each disc, as each session MM-the product is self-sufficient (he product can be successful or unsuccessful, as well as ACC. You or Vice-versa). In any way (literally - through line-MM) disks, and session MM - should not in any case - best-case scenario - get "blurry effect", and as a rule no noticeable effect. What drives are coming, "complete with MM" means only that MM can perform the functions of audiostrobe decoder for discs, i.e. to reproduce in addition to the audio discs "visual" program coded on the same drives.
I.e. in the General case - drives - on the one hand, potentially more technically perfect, the other-from MM you more options, in addition, it can be programmed yourself (well, it's still need to learn - but there are many examples).
Morality is starting to engage, start with what ever one. Once you feel the effect of it will be possible to move further - according to their own feelings and, of course, not the forum.
hi all.I'm sick of toxic encephalopathy-manganese parkinsonism.go bad and talking bad.sick since 1999.tried a variety of treatment regimens.the result is zero.as well as traditional medicine can not help you,you have to look for a way out.brought me at the end of October 2007. mm inner pulse+ 6дисков and.Patrushev.I started with drives,day 21-Yes,21 days-rest.the result is less sleep,to the end of the hearing, discs day 17-18 slightly gets better walking and talking,but not much,and then during the rest gained is lost.though take and do not rest.therefore, the question immediately arises-how to keep accumulated?and 2nd question,is it possible during the holidays to listen to a session of the mm. who knows the answer.thank you.
- Has thanked: 134 times
- Been thanked: 556 times
- Contact:
According to our latest research mode 15 15 more effective. And this applies to a particular disk. Therefore, interruptions can and can not do. The alpha session, alternating, you can do every day.юрий м. wrote:hi all.I'm sick of toxic encephalopathy-manganese parkinsonism.go bad and talking bad.sick since 1999.tried a variety of treatment regimens.the result is zero.as well as traditional medicine can not help you,you have to look for a way out.brought me at the end of October 2007. mm inner pulse+ 6дисков and.Patrushev.I started with drives,day 21-Yes,21 days-rest.the result is less sleep,to the end of the hearing, discs day 17-18 slightly gets better walking and talking,but not much,and then during the rest gained is lost.though take and do not rest.therefore, the question immediately arises-how to keep accumulated?and 2nd question,is it possible during the holidays to listen to a session of the mm. who knows the answer.thank you.
Try to change the owl idea about Your condition. Not "I'm sick and ...", and I need to learn how to do that and then... Use affirmations and affirmatsii.
- Contact:
1. Yes - independent.Инесса wrote:Andrei Patrushev
Good morning Andrew!
Explain please: the dark villager:
1. MM and the disks are independent of each arc sources effects on the brain
2. What bugged disks on the computer on music.center, etc.
3. How to combine work and MM disc
2. Muz.center, etc.
3. On some discs recorded program controlling the operation mindmachine (these programs do not affect the listening on the normal means of reproduction).
