Page 1 of 2
Question to users
Posted: Mon Oct 22, 2007 3:12
by Костя
All kind time of day.
The question is not only ancient, but also for beginners:)
I have already two years of constant congestion in my personal life and at work completely lost attention and focus. And then there was, of necessity, had to do with the language faculty. I'm afraid the efficiency of my brain to fall to zero.
One of the users solved similar problems using the instrument of the mind? What were the results?
Thank you all in advance for your answers:)
Kostya.
Re: Question to users
Posted: Mon Oct 22, 2007 9:09
Костя wrote:All good time of day.
Kostya.
When I started to use light and sound technology, the first thing I felt was significantly increased mental performance. I began to sleep well and became much calmer.
Posted: Mon Oct 22, 2007 11:49
by Dimas
Kostya
Yes,repeatedly increased the ability to kontsentrirovanija certain things (on the situation).Since now dominated by inner peace,much easier to absorb new material.
Posted: Mon Oct 22, 2007 11:54
by Развивающийся
I do quite a bit with CDs and MM (since June 2007) and very happy!!!
Involvement in work and study, piccilli in the classroom, increased kontsentratsiei attention in the study of any of the required material. Has become more reserved, without stress and finally learned to relax.
Started from Explorer. And in my opinion, this is a very good choice, despite the fact that initially wanted to increase concentration, attention and perseverance in the study to relax. Everything came naturally, after the course with the disc Explorer. Then I went to the course and other disks (in particular, to study Ultramag) and MM who just force the desired effect.
Posted: Mon Oct 22, 2007 15:53
by Димитрий
IMHO, MM has helped me in any way to control your emotions (more calmly began to refer to the news
). When you use the MM at work and when reading literature, the feeling that the information you have read or seen, is delayed somewhere in the subconscious, and to get her out of there not hard...
Posted: Mon Oct 22, 2007 20:40
by Костя
And the selection of the unit of the doubt. Andrew, in one of the forums I saw your post where I believe Mind Spa the most simple and quite a strong car. A screen at a time. whether it session and instructions are quite affordable to the average user? On the manufacturer's website refers to 12 sessions;if the session is complemented, it must be in memory...I think so:)
Thank you.
Posted: Mon Oct 22, 2007 20:52
by Костя
Thanks for all the answers:)
Posted: Mon Oct 22, 2007 22:16
Костя wrote:And the selection of the unit of the doubt. Andrew, in one of the forums I saw your post where I believe Mind Spa the most simple and quite a strong car. A screen at a time. whether it session and instructions are quite affordable to the average user? On the manufacturer's website refers to 12 sessions;if the session is complemented, it must be in memory...I think so:)
Thank you.
No, this machine anything more cannot be added.
Posted: Mon Oct 22, 2007 22:29
by Костя
And what if when you select to offer the vehicle drives?
Posted: Mon Oct 22, 2007 22:30
by Костя
Order form
MindSpa with white points - 6750 RUB.
MindSpa complete with two glasses , blue and white - 7550 RUB..
We recommend to order together with mindmachine MindSpa - audiostrobe drives for her.
Posted: Tue Oct 23, 2007 0:05
by Алексей
I was also interested in this question - how apparatus work Your disks. And yet - why should I trust the contents of the disks? And if the programming is for ulterior purposes? Where is the guarantee that this is not?
Posted: Tue Oct 23, 2007 8:40
by Лилка
Алексей wrote:And yet - why should I trust the contents of the disks? And if the programming is for ulterior purposes? Where is the guarantee that this is not?
pancake, and what for then here the whole poem on each disc, their action and results???
Posted: Tue Oct 23, 2007 13:52
by Князевский
Sure, Kostya, to believe there are any who can not, all enemies
And MM better Innerpulse to take it easy, I personally think so.
Posted: Tue Oct 23, 2007 14:21
Алексей wrote:I was also interested in this question - how apparatus work Your disks. And yet - why should I trust the contents of the disks? And if the programming is for ulterior purposes? Where is the guarantee that this is not?
On some of my discs are recorded signals audiostrobe that control blinking points (on masinag have special decoders for such disks).
You should not trust the contents of the discs. One hundred percent guarantee can be given only public insurance (and even then, only in the fact that free will be buried).
This question is often asked, so I really wonder how You think:
- what's the worst that can happen to You when listening to CDs?
- what are You most afraid of (which You can zaprogrammirovat)?
- that You could convince that these drives safe?
- understand whether You are good enough in modern psychoacoustic technology to be able to identify them all on some disk?
- do You watch TV?
- if you look, how You determine that such views are safe for Your psyche?
- do You play computer games?
- if you play, how You determine what these games are safe for Your mind?
- What book has influenced Your worldview the most? What do You think - why? Can You give an absolute guarantee that everything that You read there is true to reality? And really?
- How open to You was the purpose for which programmed You parents and teachers? And for them?
And how do You feel now (what drives You to it took)?
Posted: Tue Oct 23, 2007 15:19
by Князевский
Again I'll put...
Viewing gear such Crime, CUPE and the highway Patrol make a person more aggressive (due to content)
View Full makes viewing the WHC more enjoyable and more meaningful in terms of quality and complexity of humor.
Viewing Himself directed in some cases speeds up the video camera.
Reading the classics makes you more dushevnosti.
Pornography excites
Breeding hamsters is accompanied by a smell
Breeding suckers is fraught with problems with the law
Breeding fish involves the supply of settled water
Lame food involves stomach problems
If you start to notice all of this and more is what is given to experience, you'll probably feel bad and what is good for you. And you can stop as soon as the idea (as gardeners) sahariana.
Would add that if in doubt it is better to abandon the purchase of CDs. So it will be safer for yourself and the developer drives and all who are with this business associated.
I wish you luck, and a good starting point is to understand yourself, your feelings.
Posted: Tue Oct 23, 2007 19:36
by Костя
Andrew, I asked only one question, and you have it for a galaxy of others noticed.
Order form
If you add a session is not possible, why offer audiostrobe drives???
Thank You, Kostya.
Posted: Tue Oct 23, 2007 20:20
by Костя
And if you take the inner Pulse, you can select them Glasses pvStim? (with open eyes)
Standard - $ 2000
Premium - 4000 R.
or only those specified in the configuration?
Posted: Wed Oct 24, 2007 1:03
by Алексей
You should not trust the contents of the discs. One hundred percent guarantee can be given only public insurance (and even then, only that you free buried).
Not funny
the - lose yourself
the fact that I program other people's thoughts are already unpleasant.
the experts
no
- do You watch TV?
Yes
intuitively
no
do not read
- How open to You was the purpose for which programmed You parents and teachers? And for them? And how do You feel now (what drives You to it took)?
don't remember what I programmed teachers
disks? there are a number of issues, I want to understand.
Posted: Wed Oct 24, 2007 9:25
Костя wrote:Andrew, I asked only one question, and you have it for a galaxy of others noticed.
Order form
Thank You, Kostya.
Yes, I said, that You did not notice.
) In MindSpa have a decoder audiostrobe that controls the flashing of the points. In fact, discs are recorded at different sessions (one for each).
Something emoticons are not put...
Posted: Wed Oct 24, 2007 9:43
Алексей wrote:You should not trust the contents of the discs. One hundred percent guarantee can be given only public insurance (and even then, only that you free buried).
Not funny
the - lose yourself
the experts
no
- do You watch TV?
Yes
intuitively
no
do not read
Thanks for the replies!
Now, in order:
Really not funny...
If You start to seriously engage with the disks, I guarantee You that You'll "lose" yourself...
with programming other people's thoughts You have to accept it as yours and without discs on each step occurs (however, after sessions with disk Explorer, this situation may change...)
Currently I just are a large (in all senses) a specialist in these matters...
If You really, honestly, trust your instincts, these drives You do not need.
After studying with drives, unfortunately, do not understand, on the contrary, You have a huge number of new questions can be (scary thought), I will start to read books...
So, from Your responses, it appears that You have nothing to worry about discs, because You don't need them.
Good luck running!<
Posted: Wed Oct 24, 2007 11:58
by Алексей
Dear Andrew!
The sarcasm about reading books I do not understand, I meant that I do not read fiction, now try flipping a guy, if that's what You meant, but Oh well.
100% gut doesn't trust anybody.
The question still remains open - can You use Your disks to program people to commit certain actions? If Yes, then how to make sure that there is nothing that could harm me and others?
I have, of course, there is no reason not to trust You, but ...
Especially because I belong to the citizens of this city with great affection.
I am really interested in Your rims.
Can you give the phone? And I feel that in this way the conversation could drag on for weeks.
krdbox@yandex.ru
Posted: Wed Oct 24, 2007 11:59
by Pavel
On the contrary, from the responses this guy shows that he has issues, who and small truck (though as we all
Posted: Wed Oct 24, 2007 12:07
by Pavel
Алексей wrote:Can you give the phone? And I feel that in this way the conversation could drag on for weeks.
easier to get and purchase a single drive for reviewing.
Oh, that's the idea!
To provide some drive to explore then return it.
It would be cool, listened to it - liked it - bought the original, test drive returned to the store. Of course this service can only provide, say, in Moscow.
Posted: Wed Oct 24, 2007 13:32
by Алексей
The question is not - will like or not like. And that can cause harm or not. By the way, someone asked a question about karma. Or there are things not discussed?
Posted: Wed Oct 24, 2007 15:13
by Джедай
In my opinion, the difficulty lies in the fact that objectively prove the inability of the injury is impossible.
Firstly, the concept of "harm" is sometimes very subjective - for example, to prevent the awareness of painful memories for someone - good, and someone - harm.
The second is the result of any impact depends greatly on who is affected - there, the Newton, the Apple has arrived, and he made the discovery, and the other would be cursed for an hour then
From my point of view, the most convincing would be to provide full information on the contents of the disc - targets, methods, technologies, texts, etc. after Receiving this information I could with a high probability to make a correct conclusion about the safety and effectiveness of the impact disk use to me.
