Page 1 of 2
Mind machine Luma 10
Posted: Mon Oct 08, 2007 18:32
by Ална
Good time of day!
There are a lot of information, reviews about Interpuls.
What are the reviews about the Lume? Answer, please, who already enjoys!
I'm choosing between Lumos and Interpuls.
1) Interpuls more "cool" - that's understandable. But as stated in the catalog, the Lume is all that is needed. Those who use Lumos: you are missing the sessions that installed?
2) there is no Lume audiostrobe. As I understand it, the disks of Andrey Patrushev, you can listen without them (besides the Endorphins). Those who listen without audiostrobe: Yes effect (refers to the claims of the Conductor, the Healing, the solar wind)?
Dear users, please answer I want to make an order, but
I can not decide for several reasons. First, because I can't understand where session download. And as I understand from the forum when the fix is not so easy. Suddenly I can't do, or worse do will erase what is installed and hit program.
And the lume won't be as if nothing ends, then nothing is erased. And sessions Inprov in Lume initially more.
The breathing session I don't particularly need to, because she is doing breathing techniques and yoga.
But audiostrobe, of course, sorry (though on the forum I read that with him, too, the problems of Interpuls has)... But how could I without Endorphins...
Maybe you shouldn't "bother" to take the Lume with Colorstream?
I want a mind machine, but can not decide...
So sorry that I'm not in Moscow, and can't try different options.
Really looking forward to Your responses and tips!
Posted: Mon Oct 08, 2007 19:26
by Путешественник
Alna:
1) For the purposes of ordinary sessions will be enough for sure, everything is basically there already.
2) Drives without strobe must act anyway. With audiostrobe Interpulse no problems noticed.
With the injection sessions problems should arise, the phone device (when available COM port), too, the difficulties will not arise. To erase the preset session are only two ways to reflash the device (does not work since the firmware is not available) and hammer
The main advantage of Innerpulse that session, you can program your own, or to control the stimulation parameters from the console. If this desire You will have, then you can easily take and Lum.
Posted: Mon Oct 08, 2007 19:29
by Владимир Никонов 2
Audiostrobe - the important thing. Of course, if the machine to buy and audiostrobe disks
www.mindmachine.ru/audiostrobe/special_offer.htm
I have all the disks are, therefore, choosing a great for listening. Listen mindmachine more audiostrobe drives than session. Built-in sessions is enough, even nothing to upload. Their is more than enough.
Pay attention to the machine
MindSpa -
www.avstim.ru
It supports audiostrobe, convenient and practical. The only sessions in it a bit and colored glasses will not connect. And in my opinion it is better than the Luma as standard.
Posted: Mon Oct 08, 2007 22:04
by Ална
Traveler, Your note reassured me. If so, then the scales with the Interpuls begins to win over to their side!
Posted: Mon Oct 08, 2007 22:06
by Ална
Никонов Владимир wrote:Pay attention to the MindSpa machine -
www.avstim.ru
Thank you! I'll have a look.
about Majd machine
Posted: Thu Nov 26, 2009 3:35
by Сергей Слепченко
Purely by chance I work on this website.Heard a lot about these machines but somehow it all fell on deaf ears,and then I read and was interested.So I wanted to make an order for the LUMA characteristics seems to be like everyone else.I have only one question:after all the brain washing and all skills with the machine,then you can without a car all of these skills are purchased with the machine powered?Or with this machine for life.[color=black][/color][size=12][/size]
Posted: Thu Nov 26, 2009 12:21
by Dimas
Sergey Slepchenko
Mind-machine is a machine that allows you to learn, means that in the future You can enter the desired state of consciousness without the device.
Posted: Thu Dec 03, 2009 14:47
by Марика
Hello!
Yesterday I bought Luma, turned on the first program, it seems r01, somehow the light was coming only from the right led in the glasses. This is as it should be or defective glasses got?
Posted: Thu Dec 03, 2009 14:52
by Dimas
Marika
The light should go of all the diodes,check all the connections please.
Posted: Thu Dec 03, 2009 16:06
by Guest
Марика wrote:hi All!
There are three options:
- insert the plug as follows from points (sometimes it is necessary to twist),
- it seems - with a strong stress strong functional imbalance of the hemispheres of the brain
- really broken.
The last two differenziata by observing points on the part (not wearing) - if actually flashing only one point, it is the third option, if all the second.
Posted: Thu Dec 03, 2009 23:38
by Нетрезвый Сурдопереводчик
most likely stress. the so it was two weeks from the start(MM are 1.5 years).left eye generally didn't see the light.now I see
Posted: Thu Dec 03, 2009 23:41
Luma is easier,of course,InnerPulse .70% laid down in SP features,I think most would not use.
Posted: Fri Dec 04, 2009 15:04
by Марика
Thanks to all for the tips! Stress was not
. Yesterday I rearranged the contacts, tweak the brightness, already blinking both points. Left neponyatki - during the session (put P1 and P2) there are times when the glasses cease to blink for a while. Again speculated - and it is necessary or is it just because of the level of light put somewhere in the middle?
And yet - I watched some time light flashing, then the eyes themselves locked-that is, as if "close" from all the flashes, you only ever see the light background, without flares, if this deliberately to remove the block, again visible flashing. Maybe it's the brain itself so close?
Posted: Fri Dec 04, 2009 15:05
by Марика
The Elder Waldemar
Lom bought first because of the price, and secondly that very little time is to these practices and only in the evening, a reluctance to study the long and "poking around" at different options.
Posted: Fri Dec 04, 2009 15:06
by Dimas
Marika
Provided program.
This is normal.
Posted: Fri Dec 04, 2009 15:07
by Марика
Within two days, I attended 3 sessions. Interesting, but is there such that there was no increase in the frequency of the pulsations, we want something in tune, smooth and quiet. And then just get used to it, then changed the rhythm.
Posted: Fri Dec 04, 2009 21:22
Марика wrote:And yet - I watched some time light flashing, then the eyes themselves locked-that is, as if "close" from all the flashes, you only ever see the light background, without flares, if this deliberately to remove the block, again visible flashing. Maybe it's the brain itself so close?
This is just an experiment, or You session, too, with open eyes see???
Posted: Sun Dec 06, 2009 2:10
Марика wrote:the Elder Waldemar
well, we all have little time for practice.and then,comes the objective limit for such training.the body will not be allowed "to be greedy".I would not argue.price--Yes,in principle, Luma-budget version of Novapro.I have Innerpulse,in this mountain setting,you need only a practicing psychotherapist.in the default settings and everything works.
Posted: Mon Dec 07, 2009 14:02
by Марика
Andrei Patrushev
no experiments with new devices
. Look, as it should be, with my eyes closed. Just noticed this interesting effect of "curtains" in the brain - he abstrahierte light flashes, and such curtains up to complete darkness. Not for long though, which is a pity.
Posted: Wed Dec 09, 2009 3:32
by the way,what in Люме10 session "gamma-improvement"?
Posted: Wed Dec 09, 2009 13:39
Старец Вольдемар wrote:by the way,what in Люме10 session "gamma-improvement"?
For joy.
Posted: Wed Dec 09, 2009 15:15
improvement of joy?great
thank you
Posted: Fri Dec 11, 2009 1:55
by Ойген
What can you say about a set of programs on the Lume? For the novice - rolled?
Posted: Fri Dec 11, 2009 16:48
and for advanced also
if audiostrobe use
S not planned,it very.
where are the results ?
Posted: Fri Dec 11, 2009 19:36
by Альберттт
so all the rave about say. )) but not a single opinion about the success . in the work. the study of something . etc. who have positive and negative results of this mass experiment ?
