Hello,
At what kind of branbran the subject? At lower frequency higher amplitude. But I read a research article in which it was compared. And found that Gamma and HyperGamma the waves have still more power. HyperGamma exceeds the slow wave and the amplitude, not just frequency. And linking (combining) neurons the effect of a 40Hz capable (theoretically) to cause completely insane voltage. Whether 1, or 10 kV. It can be removed from the brain, if you force all the cells to work coherently. What can you say? Still, for the manifestation of your intents and affirmations, it is necessary to radiate powerful energy thought form. Otherwise it will remain samomoderirovanie. Well, if you have the intent and thought form, then it is the mental impact on reality, that is, magic.
The greatest power of the EEG signal?
Why? That is, the ramp beating the current nor any without magic. Quotes: from Zen "In Zen is not effort," from the bondage of "spiritual violence". In the sense of the existing capacity is sufficient potions - match the power of thought is still not to smoke, but to change the likelihood that someone will raise for you, very possible!
Кнут
SKAT does not have a particularly high level of consciousness
As, for example, the transmission line, where power is even higher. You did, I would say, incorrect comparison. Quotes from Zen and the Kabbalah? And Many respected Kabbalists say that Magical acts with the Kabbalah is a perversion and blasphemy. It is not Kabbalah. Zen-Buddhists? So they are Magic, are, doing? I thought up all life in their Samadhi, or anywhere else... any abuse is when the man's whole life makes the hemorrhoid in the "Lotus Position"? And die in 40 years. A monstrous Crowley, being, by the way, a drug addict, lived to a ripe old age, so to speak.
To make contactless change in the physical World, not having enough mental power, no one can and never.
Even the increased likelihood you're talking about, requires the creation of thought-forms with a certain density of information. And dense information creates a powerful consciousness. And I took from quantum physics (since we are talking about probabilities), and not from the teachings of the shamans of Chukotka.
Кнут
Идущая вперед
- Been thanked: 6 times
and if the impact is not consistent with the laws of the universe that this impact along with the impact just removed - like a cancer....Кнут wrote:still, for the manifestation of your intents and affirmations, it is necessary to radiate powerful energy thought form. Otherwise it will remain samomoderirovanie. Well, if you have the intent and thought form, then it is the mental impact on reality, that is, magic.
