CD "brain Massage"
Listened to mm in human. 15х15х15. So I'm alive or active , but something like that appears. That's what is most interesting is that people treat you differently. Begin to relate without masks, as is, say what he wanted to say. Or are they dumber, not smarter steel=))))))))). Or is it again my paranoia))) In General, a lot of pluses. The confidence that you're smart, can learn anything you want. Indeed, this disc earned the brains. After some time I repeat 21x21.
- Has thanked: 4 times
- Been thanked: 10 times
Re: Disk "Massage brain"
in General the ROM is super! my memory improved,I began to think more deeply,to delve into the details,in General the head became clearer.thanks for the disc!
the second part of this CD may be? ie, more powerful. or is it custom order?
Good day,dear .
Day 4 today listen to the disk drive **MM**
Listen to this morning .then after sometimes an hour to sleep.
The status is normal .
And still listen to Mozart(2 hours unable to listen to and in parallel to do something and do not get bored ,but only encourages) early classics did not particularly like.
A question for Andrew From unusual --the pleasant heat coming from the bottom of the feet to the knee????]what is it?
- Has thanked: 134 times
- Been thanked: 556 times
- Contact:
This is your senses.ЯестьЯ wrote:a Question for Andrew From unusual --the pleasant heat coming from the bottom of the feet to the knee????]what is it?
Thank you for your answerАндрей Патрушев wrote:This is your senses.ЯестьЯ wrote:a Question for Andrew From unusual --the pleasant heat coming from the bottom of the feet to the knee????]what is it?
The heat during the day is stored after listening.
What a feeling ...it's like that something you can explain????
- Contact:
Aastha
Well, lots of things to explain...
For example, the stress and switch from the sympathetic NS parasympathetic.
Thank you.Андрей Патрушев wrote:Aastha
've read.
Sympathetic nervous system mediates the body's response of the "fight or flight" (Strengthens the organs, mobilizes the body in emergency situations, increases the waste of energy resources).
So, if under the influence of impulses arriving on sympathetic nerves, are becoming more frequent and stronger contractions of the heart, increases blood pressure, expands the pupil, the pulse arriving at the fiber p. n. p., cause slowing and weakening of the heart rate, lowers blood pressure, narrowing of the pupil.
This means the nervous system goes into body's regeneration ?
- Contact:
Aastha
Well, in a balanced body cycle simpatika-parasimpatic is around 90 minutes. In conditions of constant stress simpatika prevails almost constantly (even at night), which greatly exhausts the body. With the ever-active simpatica feet and hands are constantly cold and the quality of nighttime sleep is bad. When activated parasimpatic one sign is the warming of the hands and feet. When the normal cycle is restored, the health and the performance is significantly improved.
- Иван Славов
- Has thanked: 650 times
- Been thanked: 150 times
Listened yesterday for the first time MM2. A powerful thing. Pleased with the shortness of the track compared to MM1. While listening at some point both hemispheres began to throb - it's a very interesting feeling. Gives concentration and freshness /listened to late in the evening, after work, immediately after work/.
Because I haven't finished borrowing with Эндорфины2 /21 days, every day/ plan to combine /Эндорфины2 morning MM2 - night/ until it's done with E2, then the doctor TPP plan to combine.
- Contact:
Ivan Slavov
In my opinion, MM2 is not suitable for evening listening...
Read all branch. Can all here the writing about MM is attributed to MM2 and accordingly to ÌÍ2 on the Navigator? Mean recommendations.
Is there any sense after the course MM2/ÌÍ2 go immediately to the MM or better to make a pause between them?
- Contact:
MiTek
In principle, it is possible. It is only necessary to bear in mind that the action of MM2 is highly dependent on correct positioning of the headphones. If the result of weeks of listening to covers (and does not disappear at the end of this term) depression, apathy, etc., it is necessary to turn the headphones (right->left).
Hi Andrew! Please tell me,but I listened to the course of 15 days Massage brain 2, now pause of 15 days,and if in this pause
15. day, to listen to the disc Massage the brain 1?
- Contact:
Andreichenko
Hello.
Can.
Hello.
Can.
- Contact:
alecks
All my flash drives with audiostrobe, as there are many high. In principle, it is possible to deal with points, if you get bored just listen neither to harm nor good will.
- Contact:
No.Эксперт wrote:And the 2nd track Star Wanderer Massage and Brain are one and the same?
- Contact:
MiTek
No sooner than a month (after a stroke).
