Page 1 of 2
Track Andrey Patrushev and music with audiostrobe disks
Posted: Sat May 12, 2007 14:22
by Владимир Никонов 2
On our website
http://www.mu5ic.ru/meditation/ you can download the track Andrei Patrushev -
"Superbacana" see the folder "Superbacana" and music files with audiostrobe drives.
Files disc audiostrobe are presented in mp3 format, they can listen as normal music files but use in mp3 format c mindmachine impossible.
Any albums you can enjoy in its original format on our website
http://www.mindmachine.ru/audiostrobe/
Track Andrei Patrushev "Activate direct learning" -
http://www.mu5ic.ru/meditation/direct_learning.mp3
Posted: Mon May 14, 2007 13:38
by Раду Швец
Никонов Владимир wrote:On our website
http://www.mu5ic.ru/meditation/ you can download the track Andrei Patrushev - "Superbacana" - see the folder "Superbacana" and music files with audiostrobe drives.
Vladimir, where can I learn more information about this track?
Posted: Mon May 14, 2007 14:14
This is the track "Activate direct learning." About this technique you can learn from books Photochemie and my translation of the Chapter from the book Natural Perfection (in
www.koob.ru).
Posted: Mon May 14, 2007 14:40
Posted: Fri May 18, 2007 14:18
by evgeniya_
The track "Superbacana" is a track from disk Ultra brain?
Posted: Fri May 18, 2007 16:01
evgeniya_ wrote:the Track "Superbacana" is a track from disk Ultra brain?
No, Volodya confusion has made, calling him... so many people ask Me already...
This is a special track at the activation of the "Direct Training" with my navorotami.
Posted: Fri May 18, 2007 19:06
by evgeniya_
Cool that already navorotami
What disc is this track???
Posted: Fri May 18, 2007 21:21
evgeniya_ wrote:Cool that already navorotami
No one drive this track no.
Posted: Fri May 18, 2007 23:15
So I really messed up with links. Now a look.
In the folder "Superbacana" track "of Ultramega" -
http://www.mindmachine.ru/audio/ultramozg.htm (2 program).
And navorotami'm going to look for.
Posted: Wed May 23, 2007 22:00
Posted: Thu May 24, 2007 11:56
by Pavel
and now I can at night listening to this song very quickly in the morning to learn???
Posted: Thu May 24, 2007 12:28
In the beginning specially added 5 minutes neutral music, because the brain is tuned to external stimuli after approximately 6-9 minutes. The track is designed to work with mindmachine (no signal there). Preferably "cube" to read the methodology on Direct Training.
Posted: Thu Nov 13, 2008 16:11
by Евгешка
Hi Andrew,
and with some sessions from MM you can use this track to Activate "direct teaching"?
Thank you!
Posted: Sun Apr 19, 2009 14:01
by Максим Д.
Andrei Patrushev
And in Ekaterinburg wheels for sale ?
Posted: Sun Apr 19, 2009 14:04
Евгешка wrote:hi Andrew,
Thank you!
Hello.
L03
Posted: Sun Apr 19, 2009 14:05
Максим Д. wrote:Andrei Patrushev
No.
Andrew
Posted: Fri Aug 21, 2009 17:08
by РИНАТКО
Hello Andrew, listened to your CD "Ultramesh" I was knocked out!!!Just super but I have a question, these tracks can be converted to MP3 format so the player could fill?
Posted: Thu Sep 24, 2009 18:12
by иван_IV
L03
Hello, Andrey.
Decided to do a mix for home use from the session L03 and track "Activation direct teaching"...
A number of questions that I hope will help you to choose better option.
1) the Original session L03 about 51 minutes, in the description of the session said that "the suggestion most effective after the first 12 minutes of the session".
I stand before a choice:
a) the opening 5 minute "Intro", after it starts the session, 12 minutes of which overlay your trek with navorotami.
b) Reduce the playing time of a session (the machine allows to reduce to about 15 minutes a session) and received a shortened version I mix my schedule, starting from the moment when the track start to sound Sabarmati.
2) For the track "Activate direct learning" is applied only starsignal from "ukorochenniy" session L03. As I understand it, the track is not just a "hiss" recorded... if you mix with sound session, you will hear only words of suggestion, and the quieter the sound will be muted.
In the end the choice of three options: 1A, 1B and 2... Which one is preferable?
Posted: Fri Sep 25, 2009 18:10
by Агент Смит
Hello, Andrey.
Subscribe to the issue иван_IV and want to Supplement them with a couple of other options:
1) to Impose a 7-minute silence at the beginning of the track to the start of navorotov went just 12 minutes from the beginning of the session.
2) Copy 2 more times a piece of music and insert it in the beginning, you get 13.5 minutes - almost what we need, but what about the Author?
Posted: Mon Sep 28, 2009 18:52
by Guest
Agent Smith
It seems to mix will have to deal... without prompting...
Leads to thinking only what the track looks like one... with a Preface, by the process of suggestion and return to normal...
But, mix it with the session, you will have to cut... Because what's the point after went 12-minute session L03 to hear: "Take a comfortable position..."
In General neponyatka...
Posted: Fri Mar 12, 2010 19:33
by Сергей_Л
Andrei Patrushev
tell me, now the web for file storage is laid out mass copies of your discs.
what is the difference to the user running the license or a copy ?
PS. I haven't tried, so ask an experienced.
Posted: Fri Mar 12, 2010 21:44
by Новик
If FLACe is the difference or what
Posted: Wed Mar 17, 2010 20:02
by Эмиль
Сергей_Л wrote:what is the difference to the user running the license or a copy ?
The difference, I think, is that money drives the creators won't get, but otherwise, on your conscience, what drives You use. However, as they say, you can't get something totally free, something else will be required from you, not now, then later.
Posted: Wed Mar 17, 2010 23:56
by Андрей Кабанков
Сергей_Л wrote:Andrei Patrushev
Neither Andrei Patrushev,nor we have on file sharing not put.We can guarantee only the quality of the original discs.Information about the quality and origin of the files out download, we do not have.
Posted: Mon May 31, 2010 15:28
by Guest
Сергей_Л wrote:tell me now the web for file storage is laid out mass copies of your discs.
Support Emil.
Disks created by the author is aimed at self-development, self-empowerment and discovering their own potential.
People who download music from the network, or otherwise aware of the fact that the author who created the tool it self will not receive appropriate remuneration for their work.
And that, above all, psychologically uncomfortable. Any spiritual development is closely associated with the moral aspects of personality. Man cannot develop without having a high moral quality.
Take, for example Yoga - one of the most sophisticated systems of spiritual growth. The first two stupenei Yama and Niyama is the moral ethics of relationships of the individual with himself and his environment. Without striving to abide by these principles, people can take all sorts of poses and practicipate, indefinitely meditation -a significant and sustainable fruit he will not get progress in spiritual development will not. Because inside he is weak, having a tendency for freebies. For freebies in all.
The tendency for freebies this neglect yourself. Because in this case its development is not worth nothing in two senses: in as downloaded it for free, or in the moral, as it will not be appreciated, especially yourself.
