Page 9 of 11
Re: Disk Исцеление2: Rainy Afternoon
Posted: Tue Feb 14, 2017 23:58
Buddha
It is quite possible.
Posted: Sun Feb 19, 2017 3:46
by Светочек
Friend of 47 years, doctors wanted to do surgery - fibroids. But she really did not want on the operating table, until the tears. Strong internal resistance she had.
Listened to it 21 times Healing 2, three days later I went to the ultrasound - fibroids no.
However, listening is not just. I am well versed in psychosomatics, looked at the possible underlying problems of her illness, made affirmations and affirmatsii...
Then she said that after this development there was a feeling that transformation has started. Went even stronger when listened to the recording...
In General, everything went well! :)
Thank You, Andrew! :o Your write the best and effective in all respects! :o
UPD
Complement to complete the picture. Possible underlying problems of the disease we found not just in conversation, and in the course of immersion in a trance (Erickson hipos), surfaced and worked through the situation without any complicated techniques, I would call it a 'facelift' :) . Had two massages.
Posted: Tue Feb 21, 2017 14:46
by АлександраД
Good afternoon, Andrey! Tell me, what would You recommend to listen in Oncology? We are all something, but I thought it would not hurt to listen to Your CDs. Which of the two Healings and how it is often better to listen and do you need to swap them with Explorer? Do I need to use when listening to sunglasses, with what color? Perhaps there something else You would advise in addition to these discs? Thank you for your answer.
Posted: Wed Feb 22, 2017 1:28
Alexandra
Hello.
First Conductor, the second any Healing (you can alternate). Glasses are not required.
Posted: Wed Feb 22, 2017 17:51
by АлександраД
Thank You, Andrew! That is, we can listen to each morning, the Conductor and every evening Healing? Do I need to take a break after every 15 days? Or you can listen to a few months in a row?
Posted: Wed Feb 22, 2017 18:18
Alexandra
The break is always better to do than not to do.
Harm without a break not be but of little use.
Program is better to alternate through the day.
Posted: Sat Feb 25, 2017 21:27
by Шамиль
МойКотВасСтесняется wrote: ... high frequency squeak in the beginning of the disk (including the purring) and at the very end? Works on me like a sword on the brain, the first few minutes physically very unpleasant, then got used.
Good day. Exactly the same reaction. If bormashenko drill the brain. Hear a sound like the squeak of lowercase transformers in Soviet tube TV. The middle class headphones Panasonic RP-HT460E-K. Drive today listened for the first time. The sample then put a simple in-ear earphones from the music player, there is also audible. It's certainly in me. I'll get used to it. Maybe just this drive and reduce my hypersensitivity to sounds. The disc itself is made with high quality of course, as the first discs.
Posted: Sat Feb 25, 2017 22:34
Шамиль wrote:Maybe just the disk and reduce my hypersensitivity to sounds.
And You, good health.
Hypersensitivity to sounds help to overcome drives the Massage of the Brain, Исцеление1, Star traveler (in descending order of effectiveness).
Posted: Mon Feb 27, 2017 0:40
by Позитив
Hi Andrew!
A year ago, we heard about your drives and have not betrayed to it value)
This year again met the information and decided to use it.
Listened Healing for 21 days, then 25 days the break was, listened to in the morning, immediately after waking up. While listening was conscious, and the body separately, previously never experienced!
I liked it, thank you for the invention. The most noticeable decrease in sleep time, slept for 6 hours, until then 7-8 hours.
Yesterday began the second time Healing, but today I saw and downloaded Исцеление2.
I need questions to pull in a whole. Interested in your opinion, is it 15 days Healing, and then 15 days Исцеление2?
To do 3 cycles of these 3 months.
Or is it overkill and better Исцеление2(as I understand it is more powerful) and Conductor for maximum effect is also 3 months.
Posted: Mon Feb 27, 2017 1:13
Positive
Through the day to alternate Healing, or any Healing Guide.
viewtopic.php?f=8&t=2181
Posted: Mon Feb 27, 2017 1:47
by Позитив
Read full description of Explorer and chose Исцеление2/Conductor. Tomorrow morning I will download the Guide. (by the way thanks for the electronic version, to be able to purchase a Healing Star.the wanderer and Ultramesh on CD, barely found a used player)
The Conductor says that it is better every 3 days to listen to, if I understand correctly.
Or you can alternate 15days-Исцеление2 / 15days-Conductor and 3 times?
And the last question: if alternate drives through the day and what period to take a break?
Thank you.
Posted: Mon Feb 27, 2017 10:42
Позитив wrote:Or you can alternate 15days-Исцеление2 / 15days-Conductor and 3 times?
It is possible and so.
Позитив wrote:And the last question: if alternate drives through the day and what period to take a break?
When each typed 15 times - 15 days break.
Posted: Wed Mar 15, 2017 19:46
by Будда
Hello, Andrey! Tell me how to breed by the time Your programs and meal?
Do I have to comply with polarization headphone right-left?
Posted: Wed Mar 15, 2017 20:02
Buddha
Hello.
Будда wrote:Tell me how to breed by the time Your programs and meal?
Actually, this is the General rule, but not so critical.
Будда wrote:is it necessary to observe the polarization of headphones right or the left?
Yes, this is a very significant condition.
Posted: Wed Mar 22, 2017 1:55
by Гуфест
Andrew tell me the frequency of happiness in Hz is known?want musical instrument accordion to set decoy poshamanit)).
Posted: Wed Mar 22, 2017 8:11
Guest
Man differs from animals is very large variability. When trying to identify a spectrum of emotions, it turned out that each person has their own frequency.
Posted: Thu Mar 23, 2017 0:35
by Гуфест
Maybe ethnic? affiliation delineates.Did you do research?The original person was caught?))which is taken as the standard.One lady experimented with roses Dutch,they are all mixed in genotype,when given a verbal setup to change the color they change when given the installation impossible for rose to gain the color that is not in the genotype ,they died,grew up what the other with yellow flowers .That man is as subject to the laws.
Posted: Tue Apr 11, 2017 22:09
by Будда
Hello, Andrey! Was surprised to find that the 4th program Ultramega "Star Flight" has great potential of healing than the discs themselves are "healing." Can you comment on that?
Posted: Tue Apr 11, 2017 23:49
Buddha
And You, too!
On everyone not nazdravstvueshsya. :?
http://www.koob.ru/oconnor_joseph/iskusstvo_sis_mishlen
Posted: Thu Apr 13, 2017 13:12
by митек
Andrew please tell me, after a series of alternating of the day listening guide, day исцеление2, you can switch directly without pause to исцелению1 ?
The question arose because исцеление2 is, as I understand it, usilenny исцелением1.
Or another way to listen исцеление1 and then исцеление2? Are these drives independent?
thank you
Posted: Thu Apr 13, 2017 15:08
MiTek
Can.
митек wrote:the Question arose because исцеление2 is, as I understand it, usilenny исцелением1.
No, it's not - there's just shifted some accents and is dominated by other frequencies.
митек wrote:, Or another way to listen исцеление1 and then исцеление2? Are these drives independent?
Can.
Posted: Tue Apr 18, 2017 22:41
by Владимир Р.
Andrew, tell me whether this drive to listen to is not on the recommended scheme, and every day for one month, six months, year? Nothing bad will happen? Just this CD relaxes me well, I want to listen to every day.
Posted: Tue Apr 18, 2017 23:24
Vladimir R.
Bad-nothing will happen, but all good things end quickly - the drive will simply cease to act. :?
Posted: Thu Jul 06, 2017 16:47
by Андрей П
Andrew, can you help? I understand that you can listen on the scheme 1-15 days Healing\ Healing 2-15 days\Healing 1-15 days\Healing 2-15 days, etc. it Turns out that the break is needed for a specific program, and a total break from all the programs to do?
Posted: Thu Jul 06, 2017 16:52
Andrew P
Yes, the break is only for a specific program. You can still day - Iscelenie 1, the next day Healing 2, etc., then an interval of 15-20 days....
