Page 1 of 1
Question to Andrey Patrushev Moods+
Posted: Wed Feb 24, 2010 23:15
by Баксторф
Dear Andrew. I have a set of G. N. Sytin. I would like to know what kind of music it is best to put on moods?
Posted: Fri Feb 26, 2010 0:34
by Новик
I'm not Andrew but my two cents to add.
And Satiny have been working for quite a long time.
Best combined with a mind machine.
Discs Andrew IMHO not ice :).Well, if you arrive then of course with self hypnosis.
The attitude needs to be written with his voice(this is mandatory), plus there are different things which you can add different gadgets:echo binaural beats, etc.
Posted: Fri Feb 26, 2010 2:18
by Соловей
Somewhere on the forum mentioned that Andrea Patrushev posted the entry for "direct teaching", there was recommended under which session to listen - may be appropriate, since the session can be adjusted.
Posted: Fri Feb 26, 2010 16:28
by Баксторф
Thanks for the tips. Where can I take these programs? What I can not find them anywhere.
Posted: Fri Feb 26, 2010 23:51
by Новик
Well, personally I use: Audiodeformator .
Very easy to use by :)
More like it there are opportunities Adobе Audition
PS.
But with a mind machine better :)
Posted: Sat Oct 23, 2010 22:28
by Валериус
Dear Andrei Patrushev.
Tell me, sytinskiy moods also better to apply under the scheme 15/15/15?
And if you can, tell me:
15/15/15 means
15 working days subject 15 break 15 work again, right? And then at what intervals on this topic?
Posted: Sun Oct 24, 2010 16:36
Валериус wrote:Tell me, sytinskiy moods also better to apply under the scheme 15/15/15?
It is to sytinu. :?
Валериус wrote:15/15/15 means
So.
Same.
Posted: Sun Oct 24, 2010 19:07
by Валериус
Thank you!
Posted: Sun Oct 31, 2010 14:47
by Дрю
Hello Andrew and forum members!
I recited attitude and want to combine it with your disk (bought all of Your CDs from you!!!).In the head until it's two options:
1) from one player to reproduce the mood, inserting the ear small headphones(tablets); with another player to play your disc(for example,hypnosis) in big headphones;;;but the ear canal is closed small headphones and may not have all the valuable waves reach the brain(as funny as it was read :-))
2) mix your ROM with a well read attitude(lost if properties of your disk when mixing?(Sound Forge 10))
Sytin says that the learning attitude you want to play them (read,listen) 4 (four) hours in a day!
9-10-page attitude I recite about 25-30 minutes, plan to start and end the day in the synthesis of spirit and your drive (1 hour) and the rest(up to 4 hours) to get listening in the car etc.
PS good moods, inspire, but some words(my opinion) it is better to replace(I'm healthy, head fullness, etc.
Sincerely, brothers and sisters!!!x 1000
Posted: Sun Oct 31, 2010 23:27
drew
You can drive with headphones, and the attitude of speakers.
And you can mix.
But the car can only vote.
Posted: Thu Nov 04, 2010 6:23
by Дрю
Hello,Andrey!
Whether correctly I have understood You - it is possible to MIX Your drive and own recordings of mood without loss of quality?(would be great! :ay ). And yet, how important is the quality of their own entries mood (MP3, wave).
In General,Andrew, what is the best way to combine Your drive with a well read attitude, without loss of quality and loss of efficiency? Tell me,please!bc
Thank you very much!!! :)
Posted: Thu Nov 04, 2010 12:18
drew
Yes, please - mix.
The fact that the mixer (in Adobe Audishn), depending on what is loaded first, puts the rest in the same format. Therefore, in order to avoid losses, naborot have to be in WAV (or go second). It is better to translate everything first in WAV 48000/32, and after mixing to return to 44100/16.
Good luck!
Posted: Thu Nov 04, 2010 15:55
by Дрю
Thank you very much,Andrew!
