If the glasses are flashing as this happens in the sessions is right.This is quite a wide volume range.
Posted: Fri Feb 18, 2011 9:18
by Элина2011
Hello, Andrey! Start to explore Your drives. The first CD "Healing" took 15 days. Began to sleep better, more relaxed... . Now listen to the Journey of inner worlds. Tell me: 1.how many days should I listen to this disc? 2. after listening to appears dizzy, is this normal? Thank you
Posted: Fri Feb 18, 2011 10:15
Элина2011 wrote:hi Andrea! Start to explore Your drives. The first CD "Healing" took 15 days. Began to sleep better, more relaxed... . Now listen to the Journey of inner worlds. Tell me: 1.how many days should I listen to this disc? 2. after listening to appears dizzy, is this normal? Thank you
Hello.
1.For all disks the mode of operation of the same.
2.Yes, dizziness is normal for deep relaxation. Don't get up immediately, work with the hands, paraplegia muscles along the spine and neck, popularities.
Posted: Fri Mar 04, 2011 5:56
by Акелла
All kind time of day!
I have a question to the Source and knowledgeable!
Is there a need to listen to the 2nd track on the CD voyage say self-improvement or just the first 35 minutes ? In this state of drowsiness is not present and I will say more without CDA can safely from the car. The question arose because of the difficulty in getting to sleep later...especially after an evening of listening and for the purpose of rational use (set aside more than ) time!
For earlier thanks for answers and understanding!
Posted: Fri Mar 04, 2011 10:18
Hello. Akella,
The second track is made solely to Wake up. What's more, it somewhat reduces the effect of the first.
Posted: Sat Mar 05, 2011 1:25
by Акелла
Thanks Andrew,understood everything I will consider!
Posted: Sun Mar 20, 2011 23:24
by Муза
Андрей Патрушев wrote:
Идущая вперед wrote:
Андрей Кабанков wrote:for about 15 minutes right after work with this track (especially when working with audiostrobe), many dealing can manifest psychic abilities.
yeah... and then I sit and go nuts from these abilities....when you feel close to some unknown entity and I do not see it - because it is terrible so on the wall you want to climb and shakes.... especially when the apartment suddenly starts pounding for no reason, and vesch begin to move by themselves...and this fear he the inside... and anything with myself I can not...
Yes, a familiar picture... But there is still a Conductor...
Are you serious? neponyal...
Posted: Mon Mar 21, 2011 0:18
Muse
Do not worry - this is not all and not always.
Posted: Wed May 18, 2011 19:29
by 1Андрей1
Hello. I have a question. What would you recommend for people who have no opportunity to listen to a disc 15 days in a row because of work? I have no way calm, relaxed at work, listen to the track 40 minutes, even if I do rip I will be listening in MCE player. Evening at home on 21 at this time, as it is not recommended to listen to. Schedule I have a 4 through 4.
There are options? If Yes, what is the approximate listening mode and timing to be effective.
Posted: Wed May 18, 2011 21:47
1Андрей1
You can not row, and the third day (or every other day).
Posted: Wed May 18, 2011 22:17
by 1Андрей1
And the period is 15 days then move? ie I can listen to 30 calendar days, and in fact 15 times. So?
Posted: Wed May 18, 2011 22:50
1Андрей1
Actually need 15 times as much in one day You may have listened to, it is considered at a time.
Posted: Wed May 18, 2011 23:48
by 1Андрей1
Clear. Thank you.
A parallel question on the theta meditations. Usually 2 cups, covers a series of 5 CDs theta meditation? Or is it just for this CD?
Posted: Thu May 19, 2011 7:26
1Андрей1 wrote:is Clear. Thank you.
To all of the drives.
Posted: Fri May 20, 2011 16:47
by Павел2011
Hello.
Have ordered and received all 14 disks. Listened to "the Guide", "Healing...", "Music for meditation" "Massage brain" now listening to "Journey...". Revealed interesting thing: Spring to prepare the garden for potatoes, a piece of land digging with a shovel...in the evening back hurts. Before bedtime include "a Journey...", relax, go into trance and the body itself, without conscious installations, arching the spine (just like in gymnastics of Sitel "Solo for the spine"), sometimes very quickly, with turns in two or three dimensions, should focus on what is happening - the action stops. Switch the mind to something else (affirmations or something else) - again arches. Get up in the morning as a cucumber! When back pain is now the "action" automatic turns on when initial (3-4 minutes) immersion in trance with any disk and even without.
The first time something like this was when listening to the CD "Healing...". Then the vertebra back into place with such a click that makes your ears ringing! Thought the springs in the sofa - but no: it springs - polyurethane foam/polyester.
When listening to "Music..." also had a moment - went to a very intense flow of energy from the center of the right hand (listening to before bedtime, at 10 o'clock in the evening, and struck in the evening , around 17), the wife was stunned - a strong flow of heat. Truth of repetitions until there was no more, and the like.
Thanks To Andrei Patrushev! Whatever the drive - the new manifestation of their hidden inner abilities.
Posted: Fri May 20, 2011 18:09
Павел2011
Hello.
Discs are discs, but there is still the miracle-shovel - 10 times faster and it doesn't. I have five years of digging...
We have in the city is sold in every store.
Posted: Fri May 20, 2011 21:27
by Петрос
Андрей Патрушев wrote:Disks, discs, and there is a miracle shovel
something I do not understand how to listen to it
Posted: Fri May 20, 2011 22:30
by 1Андрей1
Posted: Fri May 20, 2011 23:50
Posted: Sat May 21, 2011 11:53
by Павел2011
Андрей Патрушев wrote:Павел2011
Hello.
Discs are discs, but there is still the miracle-shovel http://zhelezka24kids.forum2x2.ru/t372-topic - 10 times faster and it doesn't. I have five years of digging...
Thanks for the advice! Important now for me.
Posted: Fri Jul 15, 2011 13:26
by креатио
Andrew please tell me,when listening to a disc is it possible to do so:if it POPs up negative, as in the method of Silva quickly progovarivat mentally"erased,erased"and to hear more?Whether the desired effect?
Posted: Fri Jul 15, 2011 20:15
kreatio
"negative" is only a value judgment. In fact, it is the experience through which You You. In my opinion, to erase their own experience, at least, not sparingly... Use, for example, by the method of Ho'oponopono, or Sedona.
Posted: Fri Jul 15, 2011 21:14
by Сана
Andrew I have a question-how to listen to the disc.Read the whole forum,saw no response and no instructions.It is necessary ,as in the guide, in a state of relaxation,lying down ... etc.? it is necessary when listening to concentrate on the noise to drive away your thoughts? I can put the disc and not to concentrate on it to do their business?
Listened to three days.On the first day and track-pailos a state of euphoria.Join the other statements - the coincidence develops very well!
Posted: Fri Jul 15, 2011 21:42
Сана wrote:Andrew I have a question-how to listen to the disc.Read the whole forum,saw no response and no instructions.It is necessary ,as in the guide, in a state of relaxation,lying down ... etc.? it is necessary when listening to concentrate on the noise to drive away your thoughts? I can put the disc and not to concentrate on it to do their business?
Here's what not to do, is to ward off whatever it is. - Stay in the flow by looking at (stalking) your thoughts (whatever they were). A lot depends on Your goals: if you just relax and rest, it is lying; if you want the condition to work (of course, we mean "special" job) then only sitting with a straight back; for developments of this state, and access it at any moment, regardless of the situation - standing Aliyev.
Also , actually it is useless to listen to the disc and to do any other things...
