Theta meditation
Has thanked: 134 times
Been thanked: 556 times
Contact:
Re: CDs Theta Meditation
Post by Андрей Патрушев » Thu Dec 26, 2013 21:41
kroshkin
There is always high frequency, but audiostrobe signal no.
крошкин
Post by крошкин » Fri Dec 27, 2013 0:50
That is, the flashing points when listening to theta meditation (except for PVM) useless? or is it still makes sense to listen to MM?
Contact:
Post by Андрей Патрушев » Fri Dec 27, 2013 0:51
kroshkin
Yes, useless. :? However, as safe (because the rhythm is missing) - can be for fun. :)
User avatar
Иван Славов
Has thanked: 650 times
Been thanked: 150 times
Re: Theta meditation
Post by Иван Славов » Mon Oct 31, 2016 12:34
How many years have all atlasgal exercise with the Theta-ROM /in addition to the FDA does with a series of Theta drives Andrei Vadimovich practically engaged/. Started with Concentration. And despite the seemingly good opyt with alpha - more from the first lessons /in addition to listen to the do and concentration on something/ started out such a horror... Phew, :shock:
After 4-5 classes all settled down and were normal /not done yet with 15дневнего course/. Combined with Healing /at different times of the day, 3 hour minimum between listening observe/.
Think then continue with Deconcentration or Creative visualization, it is very interesting will there be more unpleasant moments. :)
User avatar
Игнат.
Has thanked: 17 times
Been thanked: 4 times
Post by Игнат. » Sun Jan 01, 2017 16:32
Theta visualization trains the ability to visualize?
Contact:
Post by Андрей Патрушев » Sun Jan 01, 2017 16:41
Ignat.
No, it only enhances the effect and provides optimal conditions for this exercise. Directly to the training necessary to perform any exercise in visualization.
Пичат
Post by Пичат » Fri Jan 06, 2017 16:55
Hello, Andrey. Bought your CDs a long time ago, but unfortunately forgot about them. Recently found and decided to start with theta meditation, because in parallel I read a book about this type of meditation. Included closer to night, "Deconcentration" and listened to the entire session without special conditions have shut it down. And I couldn't sleep literally till morning. We finally got to sleep - in and had a few nightmares of the weak.
Please tell me all is as it should be? Read the rest of this topic, found related posts.
Advise, where to start, so the result was more tangible, which disks need to listen to the system 15 through 15?
Contact:
Post by Андрей Патрушев » Fri Jan 06, 2017 17:20
will Pichat
Hello.
Yes, it is in the theta - alpha without pre-training.
Better to start with a Guide and Healing (can be alternated through the day).
Пичат
Post by Пичат » Fri Jan 06, 2017 22:10
Андрей Патрушев wrote:will Pichat
Hello.
Well, suppose that I begin to work on these drives. In addition to the lucid dreams what do you feel should be? Yes, I also read in the tape of this topic that you can in the morning to use one of the drives for productivity? For increased learnability and memorability - Ultramesh.
Contact:
Post by Андрей Патрушев » Sat Jan 28, 2017 11:02
Пичат wrote:in Addition to the lucid dreams what do you feel should be?
Who should?
Пичат wrote:Yes, I read the tape what is possible in the morning to use one of the drives for productivity?
Yes, 2nd track Star Wanderer.
Пичат wrote:For increased learnability and memorability - Ultramesh.
You are absolutely right.
Будда
Has thanked: 2 times
Post by Будда » Mon Mar 27, 2017 20:19
Hello, Andrey! The question arose, do Your programs "habituation effect" and if so, how it is expressed (in particular for CDs Theta meditation) complement question: what happens if you listen to 1 disc 21/21 15/15/15 or not, but let's say 50 times in a row?
Second question: should I be afraid of astral? After all the descriptions of people, the first output may be accompanied by intense fear. Noticed that with the disc concentration, the body becomes weightless and almost ethereal, minute on the 20th
Contact:
Post by Андрей Патрушев » Mon Mar 27, 2017 21:32
Buddha
Hello.
Будда wrote:have a question, do Your programs "habituation effect" and if so, how it is expressed (in particular for CDs Theta meditation)
The body gets used to everything. The effect is to reduce efficiency. :?
Будда wrote:what happens if you listen to 1 disc 21/21 15/15/15 or not, but let's say 50 times in a row?
Nothing will happen - "no horse, no checkers." :)
Будда wrote:the Second question is: should I be afraid of astral? After all the descriptions of people, the first output may be accompanied by intense fear. Noticed that with the disc concentration, the body becomes weightless and almost ethereal, minute on the 20th
Well, that being said, - "who had studied". I was very sick as a child, and quite often came out spontaneously. But since I didn't know what to be afraid of, just wondered - a lot of new sensations and impressions.
Будда
Post by Будда » Thu Mar 30, 2017 1:52
Hello, Andrey! Please tell me what programs Theta meditation, if a person falls asleep while listening? About hypno program, you said that people in any case to hear the setup, but as with the effect in other programs.
And another question: which of the CDs Theta meditation more suited for otdyha nervous system and relaxation?
Contact:
Post by Андрей Патрушев » Thu Mar 30, 2017 11:03
Buddha
Hello.
Будда wrote:please Tell me what programs Theta meditation, if a person falls asleep while listening?
The reduction of a night's sleep. :)
Будда wrote:About hypno program, you said that people in any case to hear the setup, but as with the effect in other programs.
CDs theta meditation can arrange the corresponding state of the brain. If You do nothing, the body naturally goes to sleep.
Будда wrote:which drives Theta meditation more suited for otdyha nervous system and relaxation?
Deconcentration and Giprotrans.
Эксперт
Has thanked: 3 times
Re:
Post by Эксперт » Sun Aug 27, 2017 10:51
Hello! Good day!
In 2013, listened to healing 1 21 × 21 in 21 × 21 2015 endorphins, in 2016 the stars of the traveler and 15х15х15 21x21, massage of the brain also 15х15х15 and 21x21 and healing-2 21x21. It's time to go to Theta?
Олександр wrote:Question: do I Have after listening to the deconcentration of 15 days to make a break of 15 days before the display.
No.
That is, there is no need to take a break and go to the next drive or we should take a break?
Андрей Патрушев wrote:the Scheme is simple:
- deconcentration;
- lucid dreaming;
- hypno-TRANS;
- creative visualization;
- concentration.
Where here it is possible to include Inner voyage interesting?
Contact:
Post by Андрей Патрушев » Sun Aug 27, 2017 11:01
Эксперт wrote:Where here it is possible to include Inner voyage interesting?
Anywhere is another story. :)
Эксперт
Post by Эксперт » Sat Jan 13, 2018 12:50
DD! Is it possible to listen awake in the evening before bed?
Contact:
Post by Андрей Патрушев » Sat Jan 13, 2018 13:39
Expert
This is from your features depends. Some (the majority) - normally, and the other then can't sleep....
Анагност
Has thanked: 5 times
Post by Анагност » Wed May 23, 2018 19:11
Andrey Vadimovich! There is a need to do a combined session for MM for visualization of spoken affirmations.
Is it possible to use "Creative visualization" in MP3 and T_Hypnos.ses ?
Affirmations recorded with your voice too in MP3
Contact:
Post by Андрей Патрушев » Wed May 23, 2018 19:22
the Anagnostou
Better to just Anuco.ses
Анагност
Post by Анагност » Wed May 23, 2018 19:57
Can I use as an alternative to "my" option, or it can hurt?
Contact:
Post by Андрей Патрушев » Wed May 23, 2018 20:02
the Anagnostou
You can, of course, but a better visualization at the alpha level.
Post Reply
