Page 132 of 133
Advice from Andrei Patrushev
Posted: Wed Feb 13, 2019 2:11
by Ксеника
Andrey V., Hello!
Listen to "Conductor" 12 times (first course) today, I heard "the music of the spheres", if you can describe...Listening through headphones with a range of 14-20 something there I do not remember, but on the recommendations 20-20:) (sorry, I write immediately after listening, I can't now remember what Hertz or whatever..) the Question actually here in what is in my head the sound of the spheres appeared or are these sounds have on the disk? Just until today I didn't hear them... very very high pitched noises are pleasant and kind of melodic, his name is somewhere up to the light, back into reality is very difficult today, I wanted to stay there... but understand that it is necessary... body and in return felt differently today... tomorrow I'll try to gather my thoughts and write how exactly can someone come in handy...In General: whether these sounds on disk? and that to me is it? What should I do? This is normally a "fly away"(I liked it very much) and how to understand it?
Posted: Wed Feb 13, 2019 9:13
Станислав112,
Healing 3, perhaps, in this case, would be more effective, but do not forget about physical activity - "movement is life".
Posted: Wed Feb 13, 2019 9:17
Ксеника wrote: ↑Wed Feb 13, 2019 2:11
Listen through headphones with a range of 14-20 something they don't remember
You gave the best fur.
High-pitched sounds on the drive there, and they charge the brain with energy, and the brain likes it. So, most likely, the "music of the spheres" is a joint product of the disc and your brain.
Posted: Wed Feb 13, 2019 22:47
by Ксеника
Андрей Патрушев wrote: ↑Wed Feb 13, 2019 9:17
Andrey Vadimovich, thank you for your answer
Well, apparently, my brain drive very much, made friends here, and the writing came from
Posted: Fri Mar 08, 2019 12:54
by ДенЛаден
All kind time of day. Andrey Vadimovich, I wanted to know what might experience this reaction when you enter a state of mental silence (emptiness), then itching on my face starts though as sharp as glass wool face stuck, and sometimes (not always) the eyelids begin to tremble, of course it interferes with meditation, before this was not observed for themselves. Could you recommend/suggest how to neutralise such a reaction?
P. S: right now, trying to master meditation Joe Dispenza
"the transition to a new state of existence."
Posted: Fri Mar 08, 2019 13:03
Posted: Fri Mar 08, 2019 13:20
by ДенЛаден
Thank You Andrew Vadimovich
Posted: Mon Mar 18, 2019 21:04
by митек
Andrew, good day!
I have friends the Germans the cat. interested in your technology (after my stories...
There are problems with anxiety, panic attacks, depression.
The problem seems quite serious.
What would you recommend from your products? Based on the fact that they are not native speakers of the language and culture too.
Thanks in advance
Dmitry
Posted: Mon Mar 18, 2019 22:18
MiTekHello.
What Russian well, the Germans - death.
Posted: Tue Mar 19, 2019 1:42
by митек
Андрей Патрушев wrote: ↑Mon Mar 18, 2019 22:18
MiTekHello.
Posted: Sun Mar 24, 2019 13:36
by ДенЛаден
Good day to all. In General, I understand how to remove the "vivaldis" itching of the face. Everything was very simple - it is necessary to start breathing deeply and itching disappears, is probably due to the fact that during meditation sometimes freeze, literally, with the breath (it becomes barely and surface), before such was not, but here is evident. So if someone will face with such a phenomenon as "vivaldis" itching on the face (during meditation), begin to breathe deeper, vot.
Posted: Thu Apr 18, 2019 11:06
by Сапфо
Hello, Andrey Vadimovich! If you take a break between classes with discs not 2 days and 3 days, "fitness" will be gone, that is the effect reduced?
And as far as reduced efficiency, if you listen to the disk is not 15 or 21 days, and less? Currently listening to "Abundance", after 10 times it became very boring to listen to, it seems, already know by heart
although it is not, the feeling is
Posted: Thu Apr 18, 2019 11:11
SapphoHello.
It is not a dogma but a recommendation. First of all, listen to yourself. Maybe You just need to give yourself time to change.
You can even change the pose, with half-sitting, half lying on (or Vice versa) and suddenly to hear something new...
Posted: Thu Apr 18, 2019 12:00
by Сапфо
Thank you! I'll try a different sofa
sitting can't - my back hurts
Posted: Thu Apr 18, 2019 12:35
Sapphonot sitting and semi-sitting (almost lying) - resting on a soft pillow.
Posted: Fri Jul 12, 2019 17:56
by Рекс
Hello!
Is it possible to combine solar wind+song of chakramov one day and Healing 1/2 the next day?
Aim: to treat both the physical condition and psychological.
Previously tried only the Conductor 21 days (quite an interesting result)
Posted: Fri Jul 12, 2019 20:45
RexHello.
Song of chakramov - in one day, Healing 1, or 2 - on another day.
Posted: Sat Jul 13, 2019 15:11
by Рекс
Andrei Patrushevthank you! That was the plan. Just ask, before I forget: is it possible to combine in the same mode 1+1, song of chakramov (or 1/2 Healing) and Massage of the brain 2 or Endorphins 2? Just make a program for a long time and not just for myself)
Posted: Sat Jul 13, 2019 15:58
Rexanecdote:
In the market to sell the parrot. His feet bound by rope. The seller explains to the buyer:
- if you pull the rope, then the parrot says Hello, and if for this, it says, "up to date".
Buyer:
- but if to pull from both?
Parrot:
- fool, I'm going to fall!
Posted: Sat Jul 13, 2019 16:20
by Рекс
Andrei Patrushev,
the analogy about too much clear, I just don't know what can be combined . I only know that Endorphins MM2 and 2 together is not worth listening)
Posted: Sat Jul 13, 2019 16:55
Rexjust MM2 and Endorphins - beta session (and, again, can be "together" listening) and Healing 1 and 2 and the Song of Chakramov (by the way, the same thing, in fact, that Исцеление1) is an alpha session. Meaning throw it all in one pile no.
Please read
is closely.
Posted: Sun Jul 14, 2019 23:57
by ДенЛаден
Hello Andrei V., good day. I now wonder whether "Conductor" to interfere with the cleanliness of the Delta in one day?
Posted: Mon Jul 15, 2019 0:45
by benladenHello.
All, of course, depends on the goals, but, in General, is not recommended.
Posted: Mon Jul 15, 2019 16:52
by Рекс
Oh, in any case not going to mess to do)
I'm a dunce, read the message and understood that incorrectly expressed. Just too far ahead of time, I have a peccadillo
For the file the link separate thanks!
Posted: Fri Aug 09, 2019 12:09
by ДенЛаден
All the good time. Andrey Makarevich I wanted to find out whether theta rhythms to stimulate the visualization in humans, I mean after class, not during meditation?
