The choice of audio to work with psychoactive programs
In your opinion, what should be the requirements to the equipment and headphones used in working with psychoactive programs?
infa aroma.ru
"Most important is the quality of the tracks. They should be for Khemi Sinha, 256 KB/s is obtained for each channel(right or left) will be activated for 128 KB/s And not a few important is the quality of the transmitted stereo signal, the audio! To check enough to create a stereo sound file and insert a sound - the sound positioning in shahmatno right channels, allegedly first the sound comes from the right channel , then left; and then put the left earphone in the ear, when in the right will sound, so if you are in the left ear will hear the echo sound from the right channel - output: audio equipment is not high quality and not fit for learning Hemi-sync! All this can happen because of the many any adapters that you use - usually the adapter with two plug(red and white) plugs on the input(output) under the plug is 3.5 mm. for various reasons... by the way, this may be due to poor quality(old) sound card. It is recommended to use sound card HD only !!! In them the many tests I did not reveal any distortion and the mix of channels! Everything else supposedly all sorts of MP3 players - you can listen, but the quality ....((( . Effect it is unlikely to be, and if it is more likely it's psychological or some piece coincidence Katori you're invisible."
http://rapidshare.com/files/193972961/_ ... _.mp3.html
http://depositfiles.com/ru/files/rbdkma7ep
file size 1.1 MB
хххххххххххххххххххххххххххххххххххххххххххххххх
what do you say? how this method deystvenno
file size 1.1 MB
Guys! You then decided to isolate themselves and communicate with themselves?
This topic is already there. http://www.mindmachine.ru/viewtopic.php?t=38
- Has thanked: 134 times
- Been thanked: 556 times
Re: Equipment
If it's white noise, it is easier to throw away...игорь007 wrote:on my laptop,Zvukovaya card gives this info. Good?
