Disk A. Patrushev, "Journey to inner worlds"
мишель
Re: Disk A. Patrushev, "Journey to inner worlds"
Post by мишель » Wed Jul 19, 2017 19:47
Tell me ,and I bought it in electronic format and listen from a laptop through headphones. It's not right? Need with player etc. Thank you.
Has thanked: 134 times
Been thanked: 556 times
Post by Андрей Патрушев » Wed Jul 19, 2017 21:14
Michelle
it all depends on the quality of your sound card.
ЯестьЯ
Has thanked: 16 times
Been thanked: 1 time
Post by ЯестьЯ » Fri Dec 21, 2018 19:53
Andrei Patrushev, **Stimulation of theta brain wave gives us access directly into the subconscious. This way you can bypass the conscious mind, which often performs the role of "filter"**- and if, immediately after listening to the FPGA without a break to start affirmations?
Post by Андрей Патрушев » Fri Dec 21, 2018 20:57
AasthaYes , some time the afterglow persisted, so affirmation will be "to go" is better. :)
ЯестьЯ
Post by ЯестьЯ » Fri Dec 21, 2018 22:04
Андрей Патрушев wrote: ↑
Post by Andrey Patrushev " Fri Dec 21, 2018 20:57
Aesta, Yes, some time the afterglow persisted, so affirmation will be "to go" is better.
Thanks for the reply.But if supraliminal-entry "Connecting to Universal Higher Knowledge" to put after a Trip to VN.worlds..?
Post by Андрей Патрушев » Fri Dec 21, 2018 23:23
Aasthaeverything exactly the same. :)
ВадимН
Has thanked: 4 times
Post by ВадимН » Fri Jan 04, 2019 5:49
Andrew, good day.
Greatly reduces the effect of listening to the FDA, if you listen to without glasses, only in the headphones?
Post by Андрей Патрушев » Fri Jan 04, 2019 10:27
Vadimstrongly (remains of interest 30%).
ВадимН
Post by ВадимН » Sun Jan 13, 2019 19:14
Not planning to do PVM without audiostrobe? And not all machine is, and want to try...
Post by Андрей Патрушев » Sun Jan 13, 2019 19:38
Vadimand what's the problem? Well, you have no decoder - listen just.
ВадимН
Post by ВадимН » Mon Jan 14, 2019 6:40
And the sense to listen just so, if the effect is 30% percent?
Post by Андрей Патрушев » Mon Jan 14, 2019 10:18
VadimI don't understand what You want.
ВадимН
Post by ВадимН » Mon Jan 14, 2019 10:54
then I don't understand what You want.
At the moment the disc PVM gives 100% effect when listening with the glasses. So I ask, are there any plans to make the drive PVM without audiostrobe to get the same 100% effect, but listening to without glasses.
Post by Андрей Патрушев » Mon Jan 14, 2019 11:51
Vadimit's impossible. :? The main effect always gives light (whatever the network is no chattering).
But everything is relative. Just assign 100% of the sound program and light let him go already over 100%. :wink:
ВадимН
Post by ВадимН » Tue Jan 15, 2019 3:32
Andrew, and the Journey through inner worlds and Исцеление2 combinable?
Post by Андрей Патрушев » Tue Jan 15, 2019 9:56
Vadimquite.
Post Reply
