CD "brain Massage"
Эксперт
Has thanked: 3 times
Been thanked: 4 times
Re: Disk "Massage brain"
Post by Эксперт » Tue Aug 09, 2016 21:55
Listened to mm in human. 15х15х15. So I'm alive or active , but something like that appears. That's what is most interesting is that people treat you differently. Begin to relate without masks, as is, say what he wanted to say. Or are they dumber, not smarter steel=))))))))). Or is it again my paranoia))) In General, a lot of pluses. The confidence that you're smart, can learn anything you want. Indeed, this disc earned the brains. After some time I repeat 21x21.
Андрейлевченко
Has thanked: 4 times
Been thanked: 10 times
Post by Андрейлевченко » Mon Mar 13, 2017 23:30
in General the ROM is super! my memory improved,I began to think more deeply,to delve into the details,in General the head became clearer.thanks for the disc!
Андрейлевченко
Post by Андрейлевченко » Mon Mar 13, 2017 23:32
the second part of this CD may be? ie, more powerful. or is it custom order?
ЯестьЯ
Has thanked: 16 times
Been thanked: 1 time
Post by ЯестьЯ » Tue Apr 25, 2017 13:24
Good day,dear .
Day 4 today listen to the disk drive **MM**
Listen to this morning .then after sometimes an hour to sleep.
The status is normal .
And still listen to Mozart(2 hours unable to listen to and in parallel to do something and do not get bored ,but only encourages) early classics did not particularly like.
A question for Andrew From unusual --the pleasant heat coming from the bottom of the feet to the knee????]what is it?
Has thanked: 134 times
Been thanked: 556 times
Post by Андрей Патрушев » Tue Apr 25, 2017 13:38
ЯестьЯ wrote:a Question for Andrew From unusual --the pleasant heat coming from the bottom of the feet to the knee????]what is it?
This is your senses. :)
ЯестьЯ
Post by ЯестьЯ » Tue Apr 25, 2017 13:47
Thank you for your answer
:) The heat during the day is stored after listening.
What a feeling ...it's like that something you can explain???? :)
Post by Андрей Патрушев » Tue Apr 25, 2017 15:31
Aastha
Well, lots of things to explain... :?
For example, the stress and switch from the sympathetic NS parasympathetic.
ЯестьЯ
Post by ЯестьЯ » Tue Apr 25, 2017 15:57
Андрей Патрушев wrote:Aastha
Thank you.
've read.
Sympathetic nervous system mediates the body's response of the "fight or flight" (Strengthens the organs, mobilizes the body in emergency situations, increases the waste of energy resources).
So, if under the influence of impulses arriving on sympathetic nerves, are becoming more frequent and stronger contractions of the heart, increases blood pressure, expands the pupil, the pulse arriving at the fiber p. n. p., cause slowing and weakening of the heart rate, lowers blood pressure, narrowing of the pupil.
This means the nervous system goes into body's regeneration ?
Post by Андрей Патрушев » Tue Apr 25, 2017 16:08
Aastha
Well, in a balanced body cycle simpatika-parasimpatic is around 90 minutes. In conditions of constant stress simpatika prevails almost constantly (even at night), which greatly exhausts the body. With the ever-active simpatica feet and hands are constantly cold and the quality of nighttime sleep is bad. When activated parasimpatic one sign is the warming of the hands and feet. When the normal cycle is restored, the health and the performance is significantly improved.
ЯестьЯ
Post by ЯестьЯ » Tue Apr 25, 2017 16:21
Thank you for your answers.
I'll keep looking :)
User avatar
Иван Славов
Has thanked: 650 times
Been thanked: 150 times
Post by Иван Славов » Sat May 20, 2017 13:10
Listened yesterday for the first time MM2. A powerful thing. Pleased with the shortness of the track compared to MM1. While listening at some point both hemispheres began to throb - it's a very interesting feeling. Gives concentration and freshness /listened to late in the evening, after work, immediately after work/.
Because I haven't finished borrowing with Эндорфины2 /21 days, every day/ plan to combine /Эндорфины2 morning MM2 - night/ until it's done with E2, then the doctor TPP plan to combine.
Post by Андрей Патрушев » Sat May 20, 2017 14:18
Ivan Slavov
In my opinion, MM2 is not suitable for evening listening...
митек
Has thanked: 23 times
Been thanked: 15 times
Post by митек » Sun Jun 25, 2017 16:42
Read all branch. Can all here the writing about MM is attributed to MM2 and accordingly to ÌÍ2 on the Navigator? Mean recommendations.
Is there any sense after the course MM2/ÌÍ2 go immediately to the MM or better to make a pause between them?
Post by Андрей Патрушев » Mon Jun 26, 2017 13:12
MiTek
In principle, it is possible. It is only necessary to bear in mind that the action of MM2 is highly dependent on correct positioning of the headphones. If the result of weeks of listening to covers (and does not disappear at the end of this term) depression, apathy, etc., it is necessary to turn the headphones (right->left).
Андрейлевченко
Post by Андрейлевченко » Tue Sep 05, 2017 21:13
Hi Andrew! Please tell me,but I listened to the course of 15 days Massage brain 2, now pause of 15 days,and if in this pause
15. day, to listen to the disc Massage the brain 1?
Post by Андрей Патрушев » Tue Sep 05, 2017 23:35
Andreichenko
Hello.
Can.
алекккс
Post by алекккс » Sun Mar 11, 2018 18:28
Now Navigator points blink while listening VAF file(MM1). Throw in audiostrobe, or is it "noise" like this, and glasses don't want to use?
Post by Андрей Патрушев » Sun Mar 11, 2018 18:52
alecks
All my flash drives with audiostrobe, as there are many high. In principle, it is possible to deal with points, if you get bored just listen neither to harm nor good will.
Эксперт
Post by Эксперт » Sun Mar 25, 2018 20:55
And the 2nd track Star Wanderer Massage and Brain are one and the same? I think it's different sounds. :?
Post by Андрей Патрушев » Sun Mar 25, 2018 22:50
Эксперт wrote:And the 2nd track Star Wanderer Massage and Brain are one and the same?
No.
митек
Post by митек » Tue Aug 28, 2018 22:47
Andrew please tell me when can I start to listen to the massage of the brain after a stroke? My uncle happened 2 weeks ago. Now in rehab. He is 82 years old.
Thank you
Post by Андрей Патрушев » Tue Aug 28, 2018 23:59
MiTek
No sooner than a month (after a stroke).
митек
Post by митек » Wed Aug 29, 2018 0:42
Андрей Патрушев wrote:MiTek
thank you
Post Reply
