Theta meditation
- Has thanked: 134 times
- Been thanked: 556 times
kroshkin
There is always high frequency, but audiostrobe signal no.
Re: CDs Theta Meditation
That is, the flashing points when listening to theta meditation (except for PVM) useless? or is it still makes sense to listen to MM?
kroshkin
Yes, useless.
However, as safe (because the rhythm is missing) - can be for fun.
Yes, useless.
- Иван Славов
- Has thanked: 650 times
- Been thanked: 150 times
Re: Theta meditation
How many years have all atlasgal exercise with the Theta-ROM /in addition to the FDA does with a series of Theta drives Andrei Vadimovich practically engaged/. Started with Concentration. And despite the seemingly good opyt with alpha - more from the first lessons /in addition to listen to the do and concentration on something/ started out such a horror... Phew,
After 4-5 classes all settled down and were normal /not done yet with 15дневнего course/. Combined with Healing /at different times of the day, 3 hour minimum between listening observe/.
Think then continue with Deconcentration or Creative visualization, it is very interesting will there be more unpleasant moments.
Ignat.
No, it only enhances the effect and provides optimal conditions for this exercise. Directly to the training necessary to perform any exercise in visualization.
Hello, Andrey. Bought your CDs a long time ago, but unfortunately forgot about them. Recently found and decided to start with theta meditation, because in parallel I read a book about this type of meditation. Included closer to night, "Deconcentration" and listened to the entire session without special conditions have shut it down. And I couldn't sleep literally till morning. We finally got to sleep - in and had a few nightmares of the weak.
Please tell me all is as it should be? Read the rest of this topic, found related posts.
Advise, where to start, so the result was more tangible, which disks need to listen to the system 15 through 15?
will Pichat
Hello.
Yes, it is in the theta - alpha without pre-training.
Better to start with a Guide and Healing (can be alternated through the day).
Hello.
Well, suppose that I begin to work on these drives. In addition to the lucid dreams what do you feel should be? Yes, I also read in the tape of this topic that you can in the morning to use one of the drives for productivity? For increased learnability and memorability - Ultramesh.Андрей Патрушев wrote:will Pichat
Hello.
Who should?Пичат wrote:in Addition to the lucid dreams what do you feel should be?
Yes, 2nd track Star Wanderer.Пичат wrote:Yes, I read the tape what is possible in the morning to use one of the drives for productivity?
You are absolutely right.Пичат wrote:For increased learnability and memorability - Ultramesh.
Hello, Andrey! The question arose, do Your programs "habituation effect" and if so, how it is expressed (in particular for CDs Theta meditation) complement question: what happens if you listen to 1 disc 21/21 15/15/15 or not, but let's say 50 times in a row?
Second question: should I be afraid of astral? After all the descriptions of people, the first output may be accompanied by intense fear. Noticed that with the disc concentration, the body becomes weightless and almost ethereal, minute on the 20th
Buddha
Hello.
Hello.
The body gets used to everything. The effect is to reduce efficiency.Будда wrote:have a question, do Your programs "habituation effect" and if so, how it is expressed (in particular for CDs Theta meditation)
Nothing will happen - "no horse, no checkers."Будда wrote:what happens if you listen to 1 disc 21/21 15/15/15 or not, but let's say 50 times in a row?
Well, that being said, - "who had studied". I was very sick as a child, and quite often came out spontaneously. But since I didn't know what to be afraid of, just wondered - a lot of new sensations and impressions.Будда wrote:the Second question is: should I be afraid of astral? After all the descriptions of people, the first output may be accompanied by intense fear. Noticed that with the disc concentration, the body becomes weightless and almost ethereal, minute on the 20th
Hello, Andrey! Please tell me what programs Theta meditation, if a person falls asleep while listening? About hypno program, you said that people in any case to hear the setup, but as with the effect in other programs.
And another question: which of the CDs Theta meditation more suited for otdyha nervous system and relaxation?
Buddha
Hello.
Hello.
The reduction of a night's sleep.Будда wrote:please Tell me what programs Theta meditation, if a person falls asleep while listening?
CDs theta meditation can arrange the corresponding state of the brain. If You do nothing, the body naturally goes to sleep.Будда wrote:About hypno program, you said that people in any case to hear the setup, but as with the effect in other programs.
Deconcentration and Giprotrans.Будда wrote:which drives Theta meditation more suited for otdyha nervous system and relaxation?
Re:
Hello! Good day!
In 2013, listened to healing 1 21 × 21 in 21 × 21 2015 endorphins, in 2016 the stars of the traveler and 15х15х15 21x21, massage of the brain also 15х15х15 and 21x21 and healing-2 21x21. It's time to go to Theta?
That is, there is no need to take a break and go to the next drive or we should take a break?Андрей Патрушев wrote:No.Олександр wrote:Question: do I Have after listening to the deconcentration of 15 days to make a break of 15 days before the display.
Where here it is possible to include Inner voyage interesting?Андрей Патрушев wrote:the Scheme is simple:
- deconcentration;
- lucid dreaming;
- hypno-TRANS;
- creative visualization;
- concentration.
Anywhere is another story.Эксперт wrote:Where here it is possible to include Inner voyage interesting?
Expert
This is from your features depends. Some (the majority) - normally, and the other then can't sleep....
Andrey Vadimovich! There is a need to do a combined session for MM for visualization of spoken affirmations.
Is it possible to use "Creative visualization" in MP3 and T_Hypnos.ses ?
Affirmations recorded with your voice too in MP3
the Anagnostou
Better to just Anuco.ses
the Anagnostou
You can, of course, but a better visualization at the alpha level.
