Opensource projects, eh ... I was curious. Today held an experiment. Connected the headphone output of your player with the input of the sound card on the laptop. Launched on the player Massage the brain in plackowska format, and ten minutes recorded audio file. Then viewed the spectrogram. On the topic of frequencies, I can say that either Nero wave editor drives, or it shows that there is( with errors on the record with the path of my sound card). A spectrogram revealed frequency just above 20 kHz. that is, even more than the passport. Then took the wav-ing a file, in the Flack was written when I transfer a copy of the source code. Look the same.. the spectrogram Range is basically the same. But. The density of the spectrogram in wav is much wider.. So signal loss is evident..
So, is the CD, which has not yet got...
And ntreskit that cost 4,5 and bought 8 gigs of music that you can listen to good quality...(([/img]
