And what tell about the second ASD, which is cheaper? How does it work? Why you never advised.
The UKE Selishcheva
The UKE Selishcheva
As in other Wbah based on the creation of devices of actualization of Being a Kid-Star is based on the basic properties of energy hubs, which allows them to accomplish a range of tasks related to the restoration of live energy space, and living systems. In addition to the basic functions of all devices of concentration of energy, UAB is unique in nature to help the person to develop in a New Time and "contribute to a more harmonious passage of the event Horizon. Device updating being formed by three Fibonacci spirals, in the plane of the circle, and out of Runes, located in the center of the device, with a dot inside, which has the function of actualization of the fullness of New life that includes rational and irrational aspects. The strength and power of the device actualization of the New being are determined by size: the minimum size is given by the need of lack of contact of the turns; the maximum size is the Creation itself.
This type of Waba suggested earlier on the forum.
You need to proceed from their needs and capabilities. To work and home in a small apartment this unit is quite nice.
The UKE Selishcheva
Radius of over 40 meters
The UKE Selishcheva
Alfiya, good day! Want loved ones to buy: n UAB pendant+ bracelet Uke, and uke house plan - fulleren-crystal... Every member of the family.... What are necessary information and whether the optimal combination?
The UKE Selishcheva
Good day!
You expect the UKE for each family member? Or one house per family? You need to send your wishes on the stones (if you want crystal stones) or color of beads to crystal and I will clarify the stock.
The UKE Selishcheva
Question to Alfie. Battery Reich at UAB "El-Star" is only red or are other colors? I would like neutral white. Just the network available one photo of UAB "El-Star" on her battery of Reich red.
The question of the administration of the site, is it possible to bring UAB "El-Star"? In price it is not.
The UKE Selishcheva
Hello! In the model ASD El a star accumulator, Reich no. There are stars, and the upper balls for fixing the design, they are hollow inside.
The UKE Selishcheva
Colors options: red, gold, metallic.
The UKE Selishcheva
UAB El star El Kid-Star is essentially one and the same. The difference in power and coverage area.
The UKE Selishcheva
Hello, Alfiya! Acquired UAB "El-Star" . In the center of the device fixed the runes so they do not move, this is as it should be? They should always be there or you can still try to move?
The UKE Selishcheva
Hello!
Better to leave them as is. As it should be. They complement the action Uaba their properties. These are the basic Runes are very useful for life. The value of each we discussed on the first pages of this forum.
The UKE Selishcheva
I just saw the pictures on the website that runes can be swapped. I have fixed so that you will not pry. In addition, there are two more runes in the set with UAB. They also wanted to put in the center is fixed by the manufacturer, to experience the difference of exposure.
p.s.Adhesive 3M terrible force.
The UKE Selishcheva
Two additional you put it next to the existing, no substitution. Let all three at once will work.
The UKE Selishcheva
I have two runes glued one on top, the other from the bottom. So could all be involved. I want to feel them one by one.
Actually when I bought UAB I based it on your post.
And I have to be not removable. I don't like it.
The UKE Selishcheva
Will pass on your comments to the author.
The UKE Selishcheva
Good day!
I want to share my experience of using UAB "EL-KID-STAR" from March 2019.
The house has 2 units on different floors (about their action can not say anything - and before everything was normal).
One stands on the street near the habitat of quail, chickens, dogs.
With the birds all right, rush, healthy (but nothing to compare with, since they appeared simultaneously with the UAB). But the dog had in August to do the surgery, removed the uterus - inflammation.
But what happens to rats - do not understand! They not only go, but to successfully breed and live in Wabam! Struggle in all ways - the grass, catch, etc. - is still there. And such plump, smooth. Maybe they have "highly spiritual" high vibrations?
